Results 1 to 9 of 9
Thread: Laser Alignment
    Active Member Gilly's Avatar
    Dec 2019
    Musquash , New Brunswick , CANADA
    Default Laser Alignment
    Hey all , I have a 2009 GS SE5 with 15000 klm's on it . The front tires are wearing on the insides . Right side more than the left side ( by quite a bit ) . Can someone tell me if a Laser Alignment will correct this . Thank you .... Gilly
    2009 Roadster SM5 , Silver and Black
    Houston
    A laser alignment will keep it from happening to your next set of tires but those are done.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Dec 2019
    Ok ... Thanks jcthorne , bike steers and tracks fine . Just wanted to know if the alignment would stop this for sure .
    Agreed. By the time you notice a problem, it is usually too late for the tires already installed. Get new tires and a Laser Alignment at the same time and you will probably be quite impressed with how bad it was before.
    Bryant, Arkansas
    Laser alignment and proper tire pressure will eliminate your tires cupping or poor wear
    Cruzr Joe
    Dec 2019
    Thanks for confirming that guys. And tire pressure is something I watch very close . And you right Ron , this is my second season on my Spyder and probably will see a big difference .
    Dec 2019
    Your right guys... three new tires and an alignment ... WOW ... what a difference . After an hours drive home , i looked at the front tires on the highway and they were even across the tread pattern . A good dark strip in the center of the tire . Just had to make a small adjustment on the belt and is good to go . Thanks guys
    May 2021
    Ontario
    Hello Gilly!! I just bought a 2008 SM5 with 26,000 kms on it. Never owned or drove a Spyder before but have been riding for 40 years. It passed the safety no troubles. I took my first longer ride the other day and I'm hearing a droning type noise from the front end. If it was a car I'd think wheel bearings but it might be tires/alignment. Don't think mechanics check alignment on a safety. Did you hear that type of noise on yours before tires/alignment? Or is it just normal noise for a Spyder? Nature of the beast type noise. Steers and tracks fine.
    Mar 2021
    Arizona high country
    what is typical cost for a user alignment?
    Thx
    Rick
