Results 1 to 6 of 6
    Active Member Texas Al's Avatar
    Jun 2017
    Azle TX
    Default Ryker Accessory Connections
    Hi all. Does the Ryker have accessory connection points like the F3 has?
    2021 900 Ace , Black & Gold
    Active Member poli's Avatar
    Feb 2019
    East Texas
    Two USB points inside "frunk".
    Spyder F3-S Special Series my traveling ride
    Ryker Rally modified for dual sport duty
    Honda Grom heavily modified for dual sport duty
    Ducati Scrambler Icon Dark my other traveling ride
    Jul 2020
    Florida
    Also has a spare two wire keyed power supply for accessories underneath the left light color panel. I used this to power two USB power ports mounted on the handlebar for my phone & dash cam, GPS and such.
    2020 Can Am Ryker Rally Sport Touring Edition
    Jun 2015
    Ritzville, Wa
    Quote Originally Posted by RykerRick View Post
    What light color panel are you referring to?
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Dec 2020
    IL
    The left removable panel by the headlight.
    Jul 2020
    Florida
    Quote Originally Posted by gkamer View Post
    Yes it the interchangeable panels that allows you to change out to different colors. If you remove the left one, you will see a wire lead plugged in. its towards the gas tank. its actually plugged into nothing, its just a holder for that accessory plug. Whats nice about it is that its power is shut off when you turn the motor off, so no chance of accidentally leaving something plugged it that power source and killing the battery. Slingmods sells the male plug that plugs into it.
