Results 1 to 14 of 14
    Mar 2021
    IL
    Default 2012 RT I smell gas
    I’ve put about 500 miles on this Rt. I smell gas when I first fill up to when it registers about a half tank. When the gas gauge triggers the low fuel warning lamp it take about 3 1/2 gallons to fill up. So the gas smell is when the tank is really full. Any thoughts?
    2012 RT , Replaced with Bahrain wires Red
    Bossier LoUiSiAna
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Nov 2018
    Waynesboro, PA
    that link is not working.
    LouW try using the search box top right side, put in Gas Smell and see what you get.
    My Spyder
    2012 RTL , Brown
    washington state
    do not over fill.
    2012 Spyder RT SE5 Brake pedal mod
    Sep 2017
    Durham,Maine
    time to do a bypass on your evap system!
    2012 RTL , Pearl
    Aug 2007
    Greeneville, TN
    Agreed. Anytime is a VERY GOOD time for a Canister-Ectomy on the 2008-2012 Spyders. Easy, cheap and might keep you from burning down...
    Idaho
    Burning down, or burning up!!
    Why is it when a house burns down the furniture burns up?
    Couldn't resist!!!
    2014 Copper RTS
    Nov 2015
    Chardon, OH
    Quote Originally Posted by LouW View Post
    Hey Lou, and welcome. The key to reducing gas smell is reducing the under body temperature, which reduces the fuel tank temperature, and getting rid of that charcoal canister that is probably saturated by now. As others have mentioned, do a Google/Forum search for the term canisterectomy. You'll see all about it. A perfect rainy day project, it will be safer, and it will allow better venting of your fuel tank which will allow you to fill it more fully. There could be just a hint of a smell on really hot days, but it lasts only briefly.
    Also, don’t put the pump nozzle all the way into the tank. Hold it slightly past the opening in the top of the tank. Otherwise, it clicks off too soon. 4.5 gallons from the low light to full is a typical number.
    Second, if your RT does not have them installed, do another search for the RT vent kit / RT scoop kit. If you have things that look like air scoops installed on the body panel under your mirrors, instead of the standard wind deflectors, then you already have them. If not, that kit, which came from BRP, will increase under body airflow and keep things much cooler - including the rider's package - which is always a plus.
    Once you determine what you already have on your RT and which direction you want to go, if you need more info don't hesitate to ask.
    Doug
    ”Freedom is not a loophole”
    I have pics of how I fixed mine .... no smell ....and NO fuel can get into the Evap cannister ..... good luck .... Mike
    Mar 2021
    IL
    Thanks everyone for your help. Looks like a Canister-Ectomy is on the surgery list.
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    Just by passed my evap yesterday. Will fill and ride today. Only question I have is: do you HAVE to put a gas filter on the vent line?
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    Quote Originally Posted by Bangorbob View Post
    IMO, no. It's a nice touch and I did when I did it on my old bike, but I personally don't consider it a necessity.
    2020 RTL SE6
    Aug 2007
    Greeneville, TN
    The answer is no. You don't have to. I did it because it keeps anything from getting into the line (probably not necessary). And since I think I may have been one of the 1st to do this, I wanted to monitor for any raw gasoline getting through the system. The clear fuel filter allowed me to do this.
    Jun 2018
    Pahrump NV
    Thanks to all.
