Results 1 to 6 of 6
Thread: 50,000 service
    Jun 2012
    geneva ny
    Default 50,000 service
    I have a 2017 RTL 50,000 miles. What servicing is needed, besides oil change of course ? Should I have my antifreeze changed? Thanks
    Feb 2012
    Spring City,Utah
    coolant and brake fluid should both be changed.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jan 2021
    Descanso, CA
    Air filter (easy). HCM filter (easy but use a torque wrench). Fuel filter (easy unless you have to replace hoses). And you're not going to like this but spark plugs. BajaRon can explain why.
    If you don't use an Oetiker clamp on the radiator hose, use a constant torque clamp.
    SpeedBleeders make changing brake fluid much easier.
    Good lighting makes everything much much easier.
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
    Apr 2021
    Ky
    After hearing HD's brake recall issues, I am all about changing brake fluid every other year, and hit the brakes hard enough to kick the abs pump in monthly. She let me ride her Spyder once and I couldn't tell weather the abs was kicking in.
    Jul 2014
    Mint Hill, NC
    Read pages 125-126 of your operator's guide as they list the complete required maintenance of your Spyder. What you elect to do or have done is entirely up to you.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Sep 2017
    INDIANA, USA
    Default Operators Guide
    If you have the operator guide for your Spyder, check out the 50,000 miles section. It has all the information that you need for your services. Also this is where you can find out what oils and fluids to use.
    Good Luck on Your Mission. ......
    ENJOY YOUR LIFE WITH A SPYDER
