Results 1 to 8 of 8
Thread: 'Mode' button
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    Default 'Mode' button
    does this actually change any tuning or only to activate the suggested shift points etc. for economy?
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    The later!
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Dec 2013
    Quote Originally Posted by rjinaz86323 View Post
    Besides providing suggessted shift points to optimise economical running, selecting ECO Mode does actually vary & 'de-sensitise' the throttle control a little to reduce the throttle opening rate on a linear scale from zero to 'Wide Open', so that WOT with ECO Mode selected is somewhat less than 'normal' WOT, if that makes sense to you?!
    If you search on ECO Mode, you should be able to find the graph that's floating around here from the early days of ECO Mode that BRP put out showing how the throttle input varies between ECO & 'normal' settings.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Northern Kalifornia
    To me, ECO mode simply reduces or retards the rapid acceleration which consumes more fuel than normal mode. The arrow indicates shift points at lower rpm's therby saving fuel. Don't become fixated on that arrow which indicates a shift point. Keep your eyes on the road and shift by feel. I'm in no hurry unless passing while going up hill and then I use normal mode and shift at hugh rpm's, however I run ECO mode 90% of the time. Saves ware and tear on everything.
    Peter is right on. Eco Mode shows suggested shift points and "detunes" a little bit. When it first came out, I faithfully run a one tank test to see how good it was. I obeyed the little green arrows for a couple hundred miles (1 tank). My gas savings were about one mile per gallon.
    Based on the fact that I don't like the computer telling me what to do, the aggravation of having to keep looking for the green arrows to shift, and the lack of any real benefits (pooey on 1 mpg savings), I don't use it ever.
    Jul 2014
    Mint Hill, NC
    Here's the graph of what the ECO mode does.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Mar 2015
    Indianapolis, IN
    Interesting that it drops WOT to 60%. That's more of an aggressive drop than I thought. Wow!
    Joshua
    2012 Victory Vision
    2016 Spyder F3S
    2019 Spyder RT Limited
    2016 F3S , Triple Black
    Oct 2020
    Arizona
    I rather retain Voom Voom mode. If it lowers mileage so be it!
