Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 117
  1. #76
    Active Member Rednaxs60's Avatar
    Mar 2021
    British Columbia
    Shocks have not arrived on this side of the border, expect the M2 shocks to be here Tuesday/Wednesday - holiday in the US. Out for a ride with Sonya this afternoon, good ride but looking forward to riding with the new shocks. Have been compiling a binder regarding Spyder suspension, lots of good threads on this forum to read. The Spyder needs an alignment as well.
    Looked at the tires. The tires are the original factory install from 2014. Still have good tread, no sidewall cracking and will be good for this riding season. Intend to have new tires on for next year's touring season - planning a trip to Newfoundland and back next summer - Spyder is going to get a good workout. Looked at some Canadian distributors.
    Tire.ca has Federal 595 EVO 165/55 R15 for $158.00 CDN each.
    Blackcircles.ca has Continental Procontact 155/60 R15 at $105.00 CDN each, and Kumho Solus KH16 at $85.00 CDN each. There is the Continental Wintercontact TS800 for $109.00 CDN
    Going to compare these tire costs to the OEM tires from the dealer. Looking at all options. Will use CounterAct beads for balancing.
    "When Writing the Story of Your Life, Don’t Let Anyone Else Hold the Pen"
    "Too many of us are not living our dreams because we are living our fears.” – Les Brown
    2014 Can-Am Spyder RT LE
    1985 Honda GL1200 Goldwing Limited Edition
    Ernest
  2. #77
    Mar 2021
    British Columbia
    Have been looking at the front suspension of my Spyder. There is no preload adjustment so not a lot of information available to digest. These shocks would fall into the category of replace and not worry about front end height. Will be looking for a hard point that I can use to setup the front suspension with the new M2 shocks.
    I noticed when I was inspecting the front shocks and the ride height that there is not a lot of travel available, approximately 1 1/2 inch to 2 inches with no one on the Spyder. Hopefully the new M2 shocks give have a longer travel.
    The rear shock is different in that you have to take into account the air controlled suspension (ACS) components. The new shock will have a 500 lb/in spring so will be doing a sag adjustment. Hopefully the sag will be able to be in the 25% range. From other threads on this forum, a stiffer spring to accommodate myself may be required, say an 800 lb/in spring, but this is for consideration down the road. Setting the rear sag will impact on the front sag measurement so it will be a back and forth issue.
    Looked into the fuel octane requirement for specific cylinder pressures and compression ratios. My '85 Honda Goldwing GL1200 Limited Edition fuel injected model, has a cylinder pressure of 165 PSI on all four cylinders. Honda specifies a cylinder pressure of up to 180 PSI. This is approximately a 12:1 cylinder compression ratio similar to the 1330 engine. Honda specifies 89 octane fuel for the 1200 engines, and includes the 1500 and 1800 engines as well. A higher octane number is required to prevent pre-ignition of the fuel in the engine cylinders. If the engine is a low compression engine say between 8:1 and 10:1 compression ratio, using a fuel with a higher octane rating is not advantageous because complete fuel combustion may not occur, unburnt fuel is probably being exhausted, and fuel economy can be less. I have used premium fuel in my 1200, but this was during a hot spell, riding two up, and in the mountains - could hear the engine ping from pre-ignition. Having mentioned the above, going to start weaning the Spyder off its rich diet of premium fuel. It's not a lot of money per tank full, but it is the principle of the issue.
    Cheers
    Ernest
  3. #78
    Mar 2021
    British Columbia
    More research into the alignment procedure for my Spyder. Have read the procedure in the OEM service manual. There are some procedural issues/items I would not be doing, but the majority of the alignment procedure can be done in the garage.
    First would be to buy a small magnetic laser level for the brake rotor. Found an inexpensive one on Amazon: https://www.amazon.ca/Johnson-Level-...593374&sr=8-10 Should do the trick. A 1" to 1 1/2" angle aluminum bar for the straight edge needed at the centre of the frame. Need to determine a rear distance point that is equivalent to the straight edge extension out the front. The manual shows the front shocks installed so that is not an issue. Securing the handle bars should not be an issue.
    Front trunk has to come off, may find where the two bolts that I have left over from the first time I removed the front trunk.
    This is timely in that I expect the new shocks this week.
    Ernest
  4. #79
    Mar 2021
    British Columbia
    Had a good day with the Spyder. Sonya and I went for a 400 Km round trip ride up island to a place called Goats on the Roof. A bit of a tourist trap, but it is widely known at home and abroad: https://oldcountrymarket.com/ Good marketing strategy.
    Good weather, clear skies, warm - but not too overbearing. Spyder operated well.
    Tried some 87 octane for the trip. Never noticed a difference in engine performance. Now to caveat the experience. Not going to get into a yea/nay contest regarding this issue because it is how I understand the issue. Have been involved with different fuels over the years, as Engineer of HMCS IROQUOIS had to deal with JP-4 for the helicopters, NATO F-76 - commonly called NAVAL Distillate, diesel/gas for small boats - everything is small comparatively, and the likes. Spent 9 months in the Adriatic Sea back in '93/'94 during the break up of the former Yugoslavia. Had fuel issues so requested a fuel test kit from Halifax. Had an engineer who never went to sea inform me that all I had to do was request the fuel to the required spec, and the fuel suppliers where I was would give me what I asked for. Good answer, but the suppliers could have been giving me furnace oil for all I knew.
    Back to the Spyder. Very aware of the recommendation to use a 91 or better octane rated fuel. The amount of energy in a gallon of 87 octane fuel is the same as a gallon of 91 octane fuel - won't quibble over a few points here and there. The difference is how the fuel burns in the engine cylinder. A low octane fuel should fully combust in a low compression engine, say 10:1 (approximately 145 PSI) compression. A higher octane fuel say 91, requires a higher compression, say 12:1 (approximately 174 PSI) compression or greater to fully combust. A 91 octane fuel requires the additional heat from the higher cylinder compression to fully combust. If you go to a 94 octane fuel, you require additional cylinder compression as well to fully combust the fuel.
    Aside from a manufacturer's recommendation to use a specific octane rated fuel, there is the operation of the engine to consider. In periods of extreme heat and stress on your engine you may encounter pre-ignition of a low octane fuel. This is called detonation knock/pre-ignition (could be called other names but this one will suffice). When this happened in older engines, the cure is to use a higher octane fuel that would not ignite as quickly and use this fuel until you were back into normal riding/driving conditions - then switch back to the recommended fuel. Had this happen with my '85 Honda Goldwing GL1200 riding through the northern California mountains in the summer, extremely hot and riding two-up. Heard the engine start to "ping", switched to 91 octane fuel, and carried on. Pre-ignition of fuel is not an engine's friend.
    There have been comments about using a higher octane rated fuel in an engine that is rated for a lower fuel rating. The issue here is that to fully combust a higher octane fuel requires a higher compression so that the appropriate amount of heat is in the engine cylinder to fully combust the fuel. Not having this may result in the fuel not burning fully, you will be putting unburnt gases out the exhaust - bad person, and fuel economy can suffer. Moral of this paragraph is that using a fuel with a lower octane rating won't be an issue, depends on your personal view, fuel should fully combust, but going up in fuel rating the fuel may not fully combust.
    Modern fuel injected engines have knock sensors that are calibrated to accept engine noises within a certain range, but if the engine sounds are out side this range, a couple of things could happen. The Spyder has a knock sensor. The engine management system can adjust the engine timing to compensate, or go to a "limp" home mode so that you are not totally stranded. If the engine management system goes into the "limp" home mode, should take your vehicle in for dealer servicing. Since this post is about motorcycles, my '85 Honda Goldwing GL1200 does not have a knock sensor, so the safeguard that new motorcycle engines have is not available to me.
    Did some additional research regarding the compression ratios of my Goldwing(s). For the GL1200, the OEM service manual mentions that a compression test should result in compression pressure of 155 to 215 PSI for an engine rated at 9:1 compression ratio. Honda recommends 87 octane fuel for this engine. Honda has continued this recommendation to this day in most of its vehicles regardless of compression ratio.
    BRP uses this engine in a variety of vehicles. Some of these other vehicles have higher horsepower and it can be expected to use a higher octane fuel. BRP may also be doing the "cut and paste", one size fits all. Better to protect the corporate butt, then to use the same engine with a different fuel specification. All too easy to make a mistake and recommend a lesser fuel octane rating for a higher power version of the same engine. To err on the side of caution and recommend the same fuel for the engine regardless of the application is good policy.
    For the next while will be using 87 octane fuel and monitor the engine performance during this process.
    Ernest
  5. #80
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    I just finished a 3600 miles trip with some days pushing 100 degrees. I used 87 octane and could not tell any difference. Spyder ran fine and got 34.4 mpg on the trip.
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
  6. #81
    Mar 2021
    British Columbia
    Quote Originally Posted by rjinaz86323 View Post
    Thanks for the info. Have been browsing the web to get more information on fuel octane ratings for detuned engines, not too definitive, but will keep looking. Did find a forum thread - should have bookmarked it, regarding the US fuel regulations in that apparently all vehicles are supposed to be able to use 87 octane fuel. This did not imply that a higher grade of fuel could not be recommended.
    The M2 shocks are finally on the way. Now that the various industries are starting up in full force, imagine that Marcus at M2 Shocks is busier than a bat's ass - don't know where I learned this one. Since the shocks will be here soon, paying attention to how the Spyder operates on the straight, sweeping curves, and hard corners so that I can give a good review/comparison between OEM and the M2 shocks.
    I have noticed that in a tight corner such as on a cloverleaf, the OEM shock is forced hard over and there is little if any rebound in the corner. The shock rebound once I exit the corner is either abrupt - exiting the corner and going in a straight line quickly, or the rebound is more gentle when I allow the Spyder to drift a bit going into the new lane. Hoping the new shock(s) will mitigate this feeling.
    More to follow.
    Ernest
  7. #82
    Mar 2021
    British Columbia
    Have been researching tire availability for my 2014 RT LE - post #76. Phoned the local Spyder dealer, just over an hour up island regarding price and install. Cost of Kenda tires is approximately $130.00 CDN plus tax. For the dealer to install it's shop time and rate at $120.00 CDN/HR - needs at least an hour I was told. Would have thought that the dealer would have a set rate to install tires they sell. Will be going to a few local tire shops to determine if I can get the tires I have found available in Canada and what the install cost would be.
    Looking at front tires (all in CDN):
    Kumho Solus KH16 - 155/60 R15 - ~$89.00 ea plus tax
    Continental Procontact - 155/60 R15 - ~$108.00 plus tax
    Federal 595 EVO - 165/55 R15 - ~$158.00 plus tax
    The 155/60 R15 are almost identical to the 165/60 R15. The tire width is slightly smaller by 0.4 inches, not much change in tire revolutions. The estimated speed change is in the positive, going from an increase of 0.2 MPH at a reading of 20MPH - so 20.2 MPH to 0.8 MPH change at a reading of 90 MPH - 90.8 MPH.
    Contacted Counteract Beads in Guelph, Ontario for the recommended bead weight on install. 2 ounces per front tire, and three ounces for rear. Probably put a 1/4 ounce more in each.
    Contacted a car tire dealer that is closer. This dealer has the Kumho Solar KH16 tire in stock because these are used on the smart cars. Found one forum thread regarding this tire and the person was pleased with the tires performance. They may be able to install, but would have to take in. $302.00 CDN installed - forgot to ask if taxes in. Mentioned I would use Counteract Beads and she was familiar with these as well, I would have to supply - have on hand. May do this sooner than later - the tires that are on my Spyder are original from 2014. Tires show no cracking on the sidewalls, but tire compounds harden over time regardless of what the tire looks like. The lady I was talking to mentioned that the rear tire may be a different issue. This company also provides a lot of two wheel motorcyclists with car tires for their motorcycles.
    Ernest
  8. #83
    Mar 2021
    British Columbia
    Short update. M2 shocks on the way - Marcus was up to his eyeballs in work, being delivered to Blaine WA on Tuesday, should have for the weekend. Going to put a set of Kumho Solus KH16 tires on the Spyder. This will be done on Wednesday. Reason for the Kumho tire (used on the Smart Cars) is availability, in stock - price is good as well, $302.00 CDN installed, balanced if I wanted, out the door, taxes in. Going to specify 20 lbs inflation. Will be using CounterAct beads to balance, 2 ounces per, going to use 2 1/4 ounces - similar to Dyna beads. Have a set of Centramatic balance rings as well. Will be able to road test the tires before shock install. Be good to see what the difference is before the new shocks are installed. Change out shocks by the Monday following receipt. Set up the Spyder suspension, then tackle the alignment.
    Have some additional reading to do regarding the rear shock. Had Marcus at M2 send a 700 lb/in rear spring as well. Have read a thread regarding rear shock upgrade and it was mentioned that an 800 lb/in spring wasn't overkill. If I do decide to change the rear spring before new rear shock install, will consider replacing OEM shock spring with the 500 lb/in spring coming with the M2 rear shock.
    Ernest
  9. #84
    Sep 2017
    Durham,Maine
    WOW! I just read threw this post, I need a decaf and a nap!! You are just the Eveready Bunny, god love you. You must have that thing ready for the Indy 500. When do you find time to ride it? Good job and if you need something to do and want to refurbish a 2012, I've got just the sled for you!!! Happy trails!!! WoW!!!
    2012 RTL , Pearl
  10. #85
    Mar 2021
    British Columbia
    Thanks. We use it for most of our outings when the weather is good as it is, and I use it instead of the car. My '85 Goldwing is feeling neglected. Only take it off the road when I have everything I need and understand what I am going to do. Makes the work go faster. Doing as much at the beginning of ownership, instead of at the back end closer to when I may sell so I can enjoy what is/has been done before someone else. Only 7000 Kms in 4 months, slowing down.
    Short update on the shock issue. Read over the threads/work on front/rear shocks done by spacetiger in 2013. Relevant information, detailed and well presented. Bottom line is that a stiffer spring rate is required front/rear to accommodate the overall riding profile. This work was done on a 2012 RT and I expect my 2014 RT LE to be heavier because of the engine and possibly other changes since then. Recommendation after reading through spacetiger's thread again, new springs front up to 500 lb/in, and rear 700/800 lb/in minimum. Have a 700 lb/in spring coming with my M2 Shocks, will install before new shock goes in. Will wait and ride the Spyder to determine if fron t spring rate at 250 lb/in needs to be upgraded.
    h0grider thread in 2019 on "RT Limited OEM Rear Shock - Making it adjustable" was a good read as well. Innovative way of upgrading the rear shock to improve ride quality and performance.
    Lots of info out there.
    Cheers
    Ernest
  11. #86
    Mar 2021
    British Columbia
    Maintenance update. Handlebar Lidlocs came in today. 5 minute install and done. Trialed, will work nicely.
    Front tires off. Called tire shop. The Kumho Solus KH16 are non-directional, good to know. Did ask about a 165/55 R15 tire, Federal 595 EVO, not avialable, but the Kenda Kanines are in the warehouse in Vancouver, BC. Pricing for the Kenda Kanine is $90.00 CDN more so going with the Kumho tires.
    The M2 shocks have arrived in Blaine WA, should have notice these are in Victoria tomorrow or Thursday. This will give me a day or two to trial the Kumho tires before changing out the front shocks. Like to do one change at a time, assess the change, do next.
    Ernest
  12. #87
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by Rednaxs60 View Post
    ..... The M2 shocks have arrived in Blaine WA, should have notice these are in Victoria tomorrow or Thursday.....
    I hope that you are correct on when should arrive in Victoria. Since Covid began, a shipment from the U.S. sat in Canadian Customs for 30 long days before it was released. It was a sheepskin for my RT.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
  13. #88
    Mar 2021
    British Columbia
    Quote Originally Posted by bigbadbrucie View Post
    I use a cross border broker that is a Mom and Pop shop with head office in Victoria at the Victoria airport. Comes into its warehouse in Blaine WA, trucked to Victoria location generally the next day. Email sent to pickup, take payment docs to broker, get paperwork from them, go to customs at the airport, pay whatever is deemed for the item, sometimes it's have a nice day, back to broker, pay for the transport - $18.00 for the first 5 lbs, pick up package. Works well. I do a comparison anytime I order from the US - almost always free shipping in the US. Sometimes better than other means, won't use UPS if I can help it - I find DHL from Europe better and faster.
    Ernest
  14. #89
    Sep 2015
    Thanks for that....I did not realize that the brokers were able to jelp during the border shutdown. That’s great. I use a small mom and pop mail drop right at the border, but they were shut down because of covid.
    Again, free shipping and I just hop across and pick up and then walk through customs.
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
  15. #90
    Mar 2021
    British Columbia
    The company is called Seawings Express. I don't go near the border. Only a 10 minute drive from the house to the airport where the company is located. Only downside is it is one way, from the US to Canada. Be nice if it were the other way round as well. Very nice people to deal with.
    Ernest
  16. #91
    Mar 2021
    British Columbia
    New front tires today - Kumho Solus KH16. Nice tread profile. Had the tire shop use standard lead weights. 1 1/2 ounce for one and 1 ounce for the other. Installed wheels without the Centramatic wheel balancers and did road test. Had a bit too much vibration for my liking. Came back to the garage, wheels off - Centramatic wheel balancers installed, wheels on and road test over the same route. Much better, but still not 100%. Will leave for a week and if not satisfied will go back to tire shop and have the CounterAct beads installed - 2 ounces per tire. Owner was good about this issue and stated that if I wasn't satisfied, bring back and the beads can be put in.
    Checked the tracking as well. Put the left wheel on the centre line and let go of the bars. Tracked in a straight line, but did eventually fall of the centre line. The Spyder did not dart to one side or the other. Begs the question - do I want to straighten the bars? Will chew on this for a bit. Shocks should be here tomorrow, do shocks then think about alignment.
    Have a mechanical noise coming from under the front seat, in the vicinity of the air compressor. Almost like it is continuously on. Can hear the system when it expels air. Will investigate, peruse the two forums for information. Possibility of an air leak. Have seen a couple of threads regarding this, but didn't pay a lot of attention to these. Will do more checking of install when I do rear shock.
    Ernest
  17. #92
    Sep 2017
    Durham,Maine
    Depending on what you are getting for a rear shock you may not need that rear air bag at all! It all depends on how he set the shock up, and what you have for a spring on it!
    2012 RTL , Pearl
  18. #93
    Mar 2021
    British Columbia
    Agree. The M2 rear shock will have the 500 lb/in spring installed. I asked for an 800 lb/in spring to be included in the package, but we settled on a 700 lb/in spring. My perusing/research of the threads indicates probably better going with the 700 lb/in spring from the get go. h0grider and spacetiger threads have convinced me of this. h0grider uses a 600 lb/in spring and finds it to be very good, and minimizes air spring use. spacetiger settled on an 800 lb/in spring - older bike, probably less weight but same principle. Understand the need to take into account the ride settings for the ACS. Front shocks have 250 lb/in springs installed, may need to tweak this as well. See how everything comes out in the wash so to speak.
    Did a course in shock and vibration in 1985 from our Navy's Naval Engineering Test Establishment. The fellow who facilitated this course, name eludes me - called him Dr X, equated everything to how the ship "bounces" around the ocean, and the possibility of explosive events. Don't remember the math, minutiae around this issue, but do know/remember the importance of it. A lot of the vibration isolation was not just to protect the equipment, but to minimize the noise signature.
    Back to the comment, going to monitor the system, and tweak as required. Keeps the retired mind active and engaged.
    Cheers
    Ernest
  19. #94
    Mar 2021
    British Columbia
    Picked up the M2 shocks this afternoon. Marcus called today to make sure I got them - good follow up. Have installed the front shocks, had to remove the front trunk, not enough room to get at the upper bolt on the one side.
    Have put some 7000 Kms on since I bought the Spyder 4 months ago. Time for an oil change, doing at the same time.
    Have the rear shock ready to go in. Installed the 700 lb/in spring, considerably more robust than the 500 lb/in spring. Have looked at the install, not a lot of room in there. Will be able to use a crows foot 15 mm wrench on one side of the top bolt, The left side is a straight in to the bolt. Getting it off may be the easy part. Have drained the air from the air shock, easy enough. The rebound adjustment is at the top and with the limited room won't be adjusting it too often. Adjusting the preload will be challenging enough. Going to take a page from h0grider, settled on 0.625" preload with a 600 lb/in spring, mine is a 700 lb/in spring - hopefully I will be close to what he came up with - be a good comparison.
    More to follow. This is one of the last few items I need to address. Remaining list: new rear tire - need a torque wrench that will go into the 160 ft-lb range - mine has a max of 150 ft-lbs, trailer hitch, trailer hitch wiring, should be just about it.
    Ernest
  20. #95
    Mar 2021
    British Columbia
    Finished up this short work period today and have done a road test. The story:
    Finished up the shock install, and oil/filter change.
    Left the engine to drain overnight. Took out the engine drain plug to check the o-rings and was not expecting more oil in the engine sump - wrong, still oil in the sump. Note to self and others - to get as much oil out of the engine need to remove the engine side drain plug. The lower o-ring on the drain plug was torn so needed new one. Replaced the crush/sealing washer, and both o-rings. Will be putting the used oil into containers tomorrow. Will be interesting to see how much oil came out. Used Lucas full synthetic 10W40.
    Took the rear shock off, lower bolt was easy, upper bolt required some finesse. Had a 15 mm crow foot wrench on the nut that is located in behind the air compressor. Had Sonya assist, and left the nut up against the shock mount for later install. Wouldn't want to take the nut out and try to put it back in later. Didn't hurt to leave it there for the duration.
    The rear M2 shock is longer than the OEM by about 1.125 inches. Makes a difference sometimes. I also installed the 700 lb/in spring. The 525 lb/in rear spring is 6" unloaded length, the 700 lb/in rear spring is 6 7/8 inch unloaded length.
    Free travel - Spyder in air no preload 9.5 inches. Percentages: 25% = 2.375"/30% = 2.85"/35% = 3.325 Right now I'm using approximately 2.25" or approximately 24% of rear suspension travel. I can theoretically use up to 3.325" when two up riding. Will have someone take a measurement of the two of us on the Spyder. Be interesting to see what it is.
    After rear shock install, did some measurements for centre of rear wheel axle to the left saddlebag. Full travel no preload 9.5 inches. Spyder on ground no rider no preload 8 inches. Spyder + rider + 24 lb no preload 7.25 inches. Used just over 25% of shock travel for ride height. Rear shock was set at 20 clicks for rebound damping, has about 40 clicks - lots of adjustment. Minimal preload used, almost none.
    Adjusted the front shocks for preload and rebound damping. These shocks have some 60 clicks for adjustment. Set on 31 clicks both sides and the shock compresses and returns to set height with no overshoot. Set the front height with preload adjuster(s). Have the spring compressed to 18.5 cm. Thinking of reducing this to 18.25 cm then road test - scraping is not your friend.
    Spyder back together and time for road test. Set the ACS at lowest/softest setting. Was aware of some people having ACS trouble codes after a shock or suspension tuning/upgrade. Was conscious of this for the entire test ride. No trouble codes.
    Noticed right off that the ride was a lot firmer. The rear of the Spyder did not settle when starting off necessitating the air compressor to compensate, or when shifting at a higher RPM. The front end did not dive as it did with the OEM shocks. The front end would dive even on a gradual sweeper, and it could be seen. With the new M2 front shocks, I had to watch closely to see if the front suspension was compressing, but was hard pressed to see the A-frames compressing. There was front suspension movement as I could feel the centrifugal force in a corner/turn, but it has now been minimized significantly. Thought I might need to upgrade the front shock springs to a stiffer spring rate, but maybe not.
    Took the same route that I did when I had the new tires installed. Lots of twisties, roundabouts, and turning at corners. Significant improvement in the ride and handling. The handlebars "feel" more centred. Did the same alignment test on the same section of the ride. 70 KPH, let hands off the bars and the Spyder tracked quite straight. Did fall off after a bit, but the road will do this, did not feel like it was a Spyder issue.
    Returned home and scraped the front, first time it has done this. Might have to increase the front preload to raise the front end a bit more.
    Mentioned I had set the ACS on the lowest setting. The air system had been purged of all air before rear shock removal/install. On return home, checked the air system pressure and there was none. I think the system is trying to work, but the new rear shock is longer and the spring sufficiently stiffer that there is no need for the air system to adjust to compensate for ride height. The 700 lb/in spring is more than sufficient to carry the weight of the Spyder and myself - didn't take the extra 24 lbs I used for shock travel heights. If this works out well two up, will be considering disabling the ACS system. Better to have the main shock do the work and be sized properly. Will check the amount of air in the air system after the first two up ride. I'm thinking it may be negligible.
    The rebound damping on the shocks was spot on, but being such, the ride can be too firm. Have adjusted the front shocks so that there is a small overshoot on rebound, but shock settles with one small overshoot. Softened up the rear as well. More trials to do.
    Picked the shocks up yesterday afternoon and started on the install. Marcus called to follow up. We had a short discussion and I mentioned I would get back to him. Called him a short while later to get a quick insight into the rebound damping settings. Marcus phoned again today asking about my progress. Mentioned I was working on the rear shock and would get back to him. He asked for pictures, have take a few - will post when I get a moment. Going to provide him with my thoughts on the M2 shock performance. I got the impression he has not done an M2 shock install on an RT LE.
    I had to take a round file to the front shock mounting bushings to have the OEM bolt fit - small inconvenience, but one that should be noted.
    Instructions that came with the shocks are quite good.
    Have pics and will post when I get them annotated and such.
    Cheers
    Ernest
  21. #96
    Dec 2013
    .....Mentioned I had set the ACS on the lowest setting. The air system had been purged of all air before rear shock removal/install. On return home, checked the air system pressure and there was none. I think the system is trying to work, but the new rear shock is longer and the spring sufficiently stiffer that there is no need for the air system to adjust to compensate for ride height. The 700 lb/in spring is more than sufficient to carry the weight of the Spyder and myself - didn't take the extra 24 lbs I used for shock travel heights. If this works out well two up, will be considering disabling the ACS system. Better to have the main shock do the work and be sized properly. Will check the amount of air in the air system after the first two up ride. I'm thinking it may be negligible.....
    The ACS is probably not trying to work yet... You might find that the ACS won't actually work at all &/or add/bleed any air until you put some air into the air bag via the schraeder valve - once the bag has been emptied/bled down to zero pressure, those of us with a manual switch still on the dash generally get a 'Manual' warning & the ACS won't work/we'll get no pressure change at all until there has been some air added manually; it usually only needs about 10 psi or so.
    That said, you really should keep something like 5-10 psi in the bag at all times anyway, even if the ACS & air bag never actually comes into play any more. Leaving the bag empty is highly likely to cause it to stretch & kink enough as the suspension articulates that it'll be destroyed over time; while running just enough air in there to keep it inflated means that the bag will retain its integrity instead of doing the stretching & kinking thing.
    But aside from that, it really sounds like you've got it close to sorted! Bewdy!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
  22. #97
    Sep 2017
    Durham,Maine
    That's what the guy's at Lamonster told me also with the Elka's, that if I used there shock in the rear to just leave 10-15 lbs in the bag to keep from pinching!
    2012 RTL , Pearl
  23. #98
    Mar 2021
    British Columbia
    Thanks for the comments. I had a thought that there should be some air in the ACS system, and I'm going to read the service manual, and put some air in the system. I would think there is a minimum air pressure maintained by the system.
    I will be checking the ride height with the wooden blocks as recommended in the service manual. Get some additional numbers.
    Have to look at the numbers I have and determine exactly what I have done.
    I was thinking of the difference in the ride and performance of the Spyder now. One issue I had with the OEM shocks was that when going into a corner and not hitting it just right, that when the weight transfer went to the outside of the corner, and stayed there until exiting the corner - the Spyder would tend to initially go straight instead of turn. This would necessitate my having to lean into the corner to counteract this and use more steering than I thought necessary - a bit of a safety concern. Not an isolated incident, but one that always irked me. This happened at varying times, speed was not always a factor - had this happen doing the speed limit, riding solo or two up.
    What I think was happening is that the front shocks would start to resist the Spyder weight transfer going into the corner/curve - as a shock should, then the turning motion/force would overcome the shock resistance and the weight of the Spyder and load would abruptly go to the outside of the turn - shock fully compressed and not rebounding. This abrupt change in the Spyder orientation would have the Spyder want to go in the direction of the weight change and that is straight ahead, not around the corner/curve as required, ergo weight counterbalance and more steering required quickly. Sounds good to me.
    This and info in my other post was key to my decision to pursue a shock upgrade. The BajaRon sway bar is a good upgrade. Installed new tires, working well, but not something I would put in the performance category, in the ride quality category, yes. The shocks and sway bar are definitely a ride quality and performance enhancer.
    I have done this upgrade at up front, and now will be able to enjoy the Spyder that much more for however long I own it. Better to do this now than later, just before I sell it.
    For what it's worth, and JMHO, if you're sitting on the fence regarding a shock upgrade, or have to ask if it's worth it - you're already half way there to a decision. Personally, go for it, you won't be disappointed.
    Ernest
  24. #99
    Sep 2017
    Durham,Maine
    2012 RTL , Pearl
  25. #100
    Mar 2021
    British Columbia
    Update on new shock install. Two up ride today, mostly city and rural streets with some highway riding. Mentioned to Sonya that her priority today was to pay attention to the ride quality and cornering. Good news, Sonya mentioned that the lean of the Spyder when taking curves/corners, and turning onto another road from a stop was significantly reduced. The overall ride quality was good as well. Got a bit choppy on one of the side roads, but she admitted that the road was not the best. Overall impression was that the new shocks did a much better job than the OEM shocks I took off.
    Have to adjust the front shocks for correct preload and ride height - scraped front end again. Ground clearance front and under engine is to be 110 mm or 4.3". I will be using a structure point for the front clearance, specifically where the OEM service manual recommends putting the jack stands when doing an alignment. Will check the front of the front trunk, but this is plastic and not as definitive as part of the chassis. Did some adjustments after arriving home - ride height significantly increased. Started Spyder and the , increased the front shock preload to 3 cm on each shock, new noise from front of Spyder, thinking it's the DPS unit and ride height too high. Reduced ride height and noise went away. No error codes indicated.
    Measured the ride height with Sonya and I on the Spyder. Using the same point of reference, the loaded sag was 6.5". This is in line with what I was hoping for. Unloaded non-preload rear travel extension was 9.5". This sag represents approximately 32% of travel. Need to do more research into what these numbers indicate, but thinking all is well. Maybe a small increase in rear preload.
    Refresh on the numbers:
    9.5" - Spyder rear off floor, no shock preload
    8.0" - Spyder on floor, no additional load(s), no shock preload
    7.25" - Spyder, rider, and 24Lb small load, no shock preload
    6.5" - Spyder, rider, pillion, no shock preload.
    Can also consider a rear shock spring rate of 600 lb/in. This would change the loading numbers, but would probably require the use of the ACS system to provide minimal air support for solo riding and slightly more for two up riding and towing a trailer. There is always a sweet spot regarding spring rates. May change the 700 lb/in rear spring for the originally installed 525 lb/in spring and determine the difference in ride quality and performance and what the sag numbers are. This will be a good down the road project.
    Put some 15 psi in the air shock before ride. Checked air pressure on return home - 0 psi. Will look at the system in the OEM service manual. Best case is all is well and system is working as it should considering the new shock install. If system is functioning properly, may have to consider turning the ACS system off and isolating it enough to maintain approximately 10 to 15 psi air pressure in the air shock to prevent damage to it. Will do some number crunching tomorrow with approximately 15 PSI in the air shock.
    Still considering a front shock spring change to 300/350 lb/in depending on final front shock preload. Will know more after tomorrow and final ride height adjustment - front/rear. Looks like the front preload will be approximately 2 cm.
    Front spring is 8" in length and 250 lb/in. Lots of room for a longer spring at a higher spring rate. Will be discussing with Marcus at M2 shocks. Have found an 8" - 300/350 lb/in 1.88 ID spring that would be acceptable. I'm of the opinion that M2 is using data derived from an F3 Spyder. These rides are similar, but centre of gravity being higher for the RT, and a slight weight difference coupled with this changes the RT dynamics. My primary objective with a greater spring rate is to minimize preload, the fact that a greater spring rate would be beneficial cornering, on curves and turning onto a road from a stop is all good. I will also be towing a trailer.
    Cheers
    Ernest
