Dummy acc plug on left side of Ignition key on an F3s
I noticed when I remove the acc (dummy) plug on the left side of ignition switch there is a wire attached.
It has 2 black 1 blue, and 1 orange going into a plastic looks like 4 outlet connector.
WHAT is that for? Is it for an accessory?
I want to install a volt meter in that area and maybe I could use part of that harness, or not!
I have called BRP, and no less than 4 dealers in my area and NOT 1 can tell me what that harness is for or connected to.
Thanks,
Rotax
Left side is Heated Grips.
Right side is Fog Lights
David C
2016 F3T
Battery tender cable
Rear IPS Pack Rack
Thanks David!
Can I utilize that connection to connect a volt meter
in that space?
Suggestions.
Rotax
David,
I don't need the heated grip option.
I would need to find the male connection for that accessory without
the heated grips?
Rotax
Rotax,
What you need is a 4 Position MX19 connector.
Sorry, I don't have a source for this part.
You can check http://www.cycleterminal.com/
I made a male from computer parts for my fog lights.
David C.
David C
2016 F3T
Rear IPS Pack Rack
Outstanding David!
Will investigate that connector however I will only need two
wired of the 4 for the volt meter.
Hate to impose on you, but do U know which 2 wired, +/- that will
allow me to hook up the volt meter?
Again, THANKS for all the info!
Rotax
Left Side Connector.
Sorry i have not worked on the Left Side Connector.
After looking at the wiring diagram (very confusing) I would not try to run a voltmeter from the Grip heater plug.
I believe the plug wiring runs to switching relays and other component in the fuse block. It may not show the true voltage.
I would wire directly to the battery or to one of the Customer Accessory terminals in either the back of the frunk or under left side panel.
David C
2016 F3T
Rear IPS Pack Rack
