Page 1 of 2 12 LastLast
Results 1 to 25 of 44
    Dec 2014
    S.E. Michigan
    Default thinking about cross country ride?
    I'd really like to take my Spyder on cross country ride. If I take a major highway, will there be repair shops if I get into trouble? I've got a 2016 in good shape, new tire on the rear and good tread on the front. Starts without arguing, fresh oil, newer battery. I have AAA and AMA as backup. (And charge cards if needed.)
    Whar do y'all think?
    ~Sandee~
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
    Northern Kalifornia
    Check your brake pad thickness front/back and it sounds like you're good to go. OEM brake pads don't last a heck of a long time. Stay safe have fun and wish I could go.
    Brake pads - I ride hard and the OEM pads did 30,000 rear ( but they were toast - so 25,000 mi. is safe ) ...... Front 42,000 mi. and could have gone another 5000 mi. without an issue ..... I would not rely on any REPAIR shops other than at a Can-Am dealership .... so map your route and find out where they are before you go ..... I don't take my Spyder to any dealers, but you may have to. ..... good luck and have a happy safe trip ..... Mike
    Dec 2013
    Sandeejs, I think you've got it well & truly covered, especially with the good advice above!
    If your Spyder is well maintained & otherwise running well; then simply toss & replace any OE Spec tires & check that any replacement auto tire you've fitted has suitable tread depth to last your anticipated trip (I'd suggest you start with at least 1/2 of their 'new depth' for a cross-country trip! ); similar on the brake pads, as BK911 mentions above; and try to work out where you'll be whenever you're likely to hit your next scheduled service, particularly if you need to get one or more done while you're away! . You might even want to do a pre-trip service a little bit early & get that oil tested so that if you need to stretch your next or any subsequent oil change interval juuussst a little bit to make it home, you can confidently do so knowing how well your oil is likely to be lasting.
    My 2013 RT Ltd still eats up the miles (& kms! ) and I haven't yet & despite many earlier similar trips, I still don't hesitate to just pack up, gas up, and head off on the next 10,000km trip either solo or with me'n the Child Bride aboard - but I do always pay head to the above!
    Go On - DO IT!! You know you want to!
    Ps: sure, you might wanta stick to the major highways for your very first cross country trip, but don't let that restrict you for all your future trips!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    If you are doing a long journey and want to keep family etc updated on your whereabouts there is a free Spotwalla service that may be of interest. Its often used by Iron Butt riders (which is why I know about it) but can be used for anything. Spotwalla will display your location on a map every 15 minutes (or how often you choose), or you can choose to tag where you currently are. Theres also an SOS option as well - fortunately I've never needed it:-).
    You can connect to it using a dedicated device (like SPOT or Garmin) but there are also app's for both Apple and Android - I use SWConnect on the Apple phone.
    Here is an article about it written by one of the local riders, it was written for the TT2000 event but it got lots of good info on general usage:
    https://www.wiltshire.net/2021/01/23...00-event-2021/
    Nov 2020
    Lincoln, Nebraska
    Go where you wanna go. I broke down in the middle of nowhere on my Harley all on the Great River Road. I called Harley owners group and they said it would be at least $700 for a tow. I then called AAA and they got the exact location through my phone and a wrecker was there within 20 minutes. To get to a Harley shop they had to haul me all the way back to Memphis which they did at no charge. They were very understanding about motorcycles and trikes. And although it cost me a day of my trip the experience was exceptional. So get off the major highways and enjoy the fresh air.
    Jul 2014
    Mint Hill, NC
    If you have AAA you should contact them about adding RV coverage if you don't already have it. There is a waiting period of about a week as I recall but it has a much longer towing, I really mean rollback lift vehicle, mileage limit should you have a problem on the far side of beyond. You can always cancel the RV coverage after the trip. You can also have AAA create a TripTik to route you the way you want to go.
    IMO, if you're going to make the trip I recommend planning it off interstate highways as much as possible; they're duller than dirt and no fun unless your primary objective is to eat up mileage as fast as possible. There is much more of our beautiful country to see and interesting people to meet off the interstate highway system. Jump on the opportunity and have a blast!! Good luck!!!
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Active Member Scotts8826's Avatar
    Jun 2014
    Kansas
    How far do you plan to travel and what distance do you expect to cover each day? Don't over think the trip. Long distance riding is my favorite time on the Spyder.
    Active Member almosthere's Avatar
    Jan 2016
    Paw Paw, Michigan
    Last year my wife and I went north over the Big Mac then west on US2 all the way to Mount Olympic National Park, Then south down Highway 101 / US 1 to the Golden Gate Bridge. Through Sequoia National Park then west to Hot Springs, AR. There you will find Spyderpops's shop where the best group of people, who will treat you like family and your bike like their own. There they can get your ride purring like new again before you head back out on the road to come home to MI or continue on your adventure.
    Active Member Rocketman 2012's Avatar
    Oct 2015
    Carthage, Missouri 64836
    I have a related question so this isn't a high jack: How fast is safe for the Spyder, eating long distances on the Interstates, since the average speed I see is between 75 and 80 miles per hour? My new ride is a 2021 RT SE6 and I'm thinking about touring to Southern Calif in early Summer. I've done this many times on my past Motorcycles but I'm concerned about long distances on the RT.
    To the OP, I suggest this: Never, ever start a long touring Vacation unless your Vehicle is in tip top shape! (A half worn tire for instance will wear out magically before your eyes in no time when you least want it to)
    Sam
    2021 Spyder RT ES6 PETROL metallic. Carthage, Missouri 64836
    Jul 2014
    Mint Hill, NC
    Quote Originally Posted by Rocketman 2012 View Post
    ...How fast is safe for the Spyder, eating long distances on the Interstates, since the average speed I see is between 75 and 80 miles per hour?
    A properly aligned Spyder with tire pressure equalized front tires is capable of of being safely ridden at speeds that far exceed the skill of the nominal rider. In 2017 I comfortably rode for hours on end through OK and NM at 80-85 into a vicious headwind on my way to UT. My only concern at that speed was watching the gas gauge because at those speeds and into the headwind I got only a bit over 28 mpg. Unless you're a professional racer the Spyder has much more capability than you do.
    Cognac 2014 RT-S
    Sep 2013
    Boynton Beach, FL
    1. Take the phone # of at least one knowledgeable Spyder owner or Service Mgr. If you do have a problem, it helps to have another person to lend advice or moral support.
    2. If you have to go to a dealer, stress the fact that you are on an extended road trip and must be taken care of today or first thing in the morning. Even if they have to take parts off another Spyder. Be very polite, but very firm.
    3. Definitely Go and Enjoy.
    Roger
    2014 ST-L
    Mar 2015
    forrest above Reno, Nv
    Got hooked up on a ryde out to Middlegate Nv. last fall. ( Should be called the middle of Nowhere Nv.) Between Fallon and Austin Nv. Hwy 50 is known as the loneliest road in the country . It is basically un patrolled. The fast sport bikes in the group were cruising a 90+ ----- and so were the Spyders ( all 4 of us ) No problems at all. We did loose some of the V-twins though.
    Lew L
    2014 RTS , Circuit Yellow
    Sep 2020
    Middletown, NJ
    Most of the above replies are breakdown related so that's covered.
    My suggestion is to keep your eye on the weather reports and radar maps. If you're not locked into a specific route, you can re-route around trouble spots and make the trip more of an adventure. We take long trips a couple times/yr and sometimes play "Radar Tag" to avoid rain, hail, or snow. We end up finding new gems we would have missed otherwise.
    Just do it!
    2020 RT base , Chalk White
    Quote Originally Posted by sandeejs View Post
    ~Sandee~
    Repair shops are usually few and far between. The good old days, where you could pull into any gas station and get pretty much anything fixed are long gone. The is a very technical piece of equipment. Most of the things are controlled by computer. Road repairs are for the learned Spyder mechanic or for the brave. It is better in the lower 48 than what I experienced in Alaska for almost twenty years.
    There were two Spyder dealers at first, then one, then none. I put on 150,000 assorted miles on five Spyders while I was there. Never had a breakdown on the road. At least, in the lower 48, there is at least one dealer in every state. Independent mechanics or gas stations, are not likely to want to work on them. Over the last five years, I think the Spyder is more dependable than the earlier models. I will drive mostly anyplace without the fear of breaking down. I keep mine maintained according to schedule and get anything I am not sure about looked at in a timely manner.
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    Here is a thread that may be helpful, https://www.spyderlovers.com/forums/...-to-Coast-trip
    I’m in the planning phase of a 3 - 4 week trip to CA next Spring.
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    Oct 2020
    KS
    When I google or BRP search for Can Am Spyder dealers I get fewer locations than if I just search for Can Am dealers. I know a lot of dealers are primarily 4 wheelers but are they qualified on the Spyders or required to be?
    I also plan a 2,000 mile trip this summer KS to AZ and want to map out dealers beforehand in case of issues. Just wondering?
    Quote Originally Posted by milryder View Post
    Non Spyder, CanAm dealers are usually not qualified to work on Spyders, nor are they likely to volunteer. Dealers that go through the actual process for "official" Spyder mechanics spend a lot of time and money for that. Even the dealer where I came from fudged the last couple years, and I was getting to the point of move or sell the Spyders.
    Oct 2020
    KS
    In that case southern KS through southern CO to Flagstaff will be w/o Spyder repair contacts. My guess is a 4 wheeler dealer would be better than a non BRP dealer if one had problems.
    One might get lucky, and it does not hurt to ask if a situation does come up.
    Oct 2020
    KS
    They would be my first choice but with new machine hopefully no issues. Hope to get 3,000 mi check before that trip the end of June. Will be stock other than updated front pulley. Dealer wants $260 for Rollo align and said one of their customers had it done and no adjustment was necessary. So far my RT seems to track well.
    Sep 2020
    Middletown, NJ
    Wow! That's more than twice what I paid. Try a different dealer if possible.
    Jul 2015
    Dorr, michigan
    We head out on roughly a 5-thousand-mile trip for two weeks every summer. We run nothing but back roads and prefer to be in the middle of nowhere, the views are nicer!
    We have never mapped our travel via Spyder Dealers, and if I had to, I wouldn’t own one!
    somewhere between 45 and 50 thousand miles on the 2015 SE6 RT limited, most towing an aspen camping trailer, now over 5 thousand on the 2020 RT Limited.
    I have never had to see a dealer or get a repair on the road. I have blown a fuse, had trailer hitch come loose, the latch to hold down the top of the camper broke, and a few other minor things go wrong on the trips. Nothing has ever has gone wrong pertaining to the spyders dependability.
    2020 RT Limited , Petrol Blue
    May 2017
    Mesa, Arid-Zone-A
    A few years ago I was on my Spyder and stopped by an out-of-the-way dealership. They specialized in 4WD off road vehicles including Can Am. I had a conversation with the service manager about their experience/capabilities changing Spyder belts and rear tires. His response was "Well, this is the first time I have seen one up close." Enough said..... Jim
    Semper Fi
    Sep 2012
    Northern Virginia
    [B]
