Results 1 to 7 of 7
    Central Oklahoma
    Default Will this Lawn Tractor Lift work for a Spyder?
    Will this work to life the front end of an RT-S?
    https://www.tractorsupply.com/tsc/pr...r-lift-1222682
    2020 RT Limited , Petrol Metallic Dark
    Quote Originally Posted by sduskin View Post
    350 lbs. of lift strength ... ... I wouldn't use that on a Spyder or a Ryker .... you have many choices of lifts in that price range ( and even less money ) .... check out Sears , Great Northern, Harbor Freight ...... good luck ... mike
    Nov 2016
    Upstate NY
    I agree. That lift is not strong enough. Its also not wide enough.
    Northern Kalifornia
    Default No, No
    Nov 2015
    Myerstown, Pennsylvania
    Lifting the front end of an RTS involves lifting most of the mass of the spyder. I used a pair of folding ramps for the back of a pickup that were rated for 1500#. Just put them on and drive the spyder up until you have the height you need. EZPZ
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Northern Kalifornia
    That's exactly how I do it. Then I jack up the rear and set a third ramp under the rear tire. Now it's level and secure and I have plenty of room to change the oil. Safety first always!
    Oct 2020
    Arizona
    This is how I slide out the old and the new sway bar in, rest of work was done on blocks.
