Results 1 to 16 of 16
Thread: The Whine!
    Active Member Airborne's Avatar
    May 2019
    Tasmania, Ausralia
    Default The Whine!
    Hi all,
    Last year i bought a new2020 RT LTD which had the annoyingly high whining noise near the front of the machine that I've read about on this site. Thing is i sold that bike for various reasons [nothing to do with the bike, i loved it, just not the whine]
    I am now looking at getting a 2021, does anyone know if the problem was defiantly solved by BRP AND DO THE 21'S HAVE THE SAME ISSUE?????
    Thanks
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    My 21 RTL does not have any noticeable whine. Then again I play my music so loud, I probably wouldn't here it.
    GLIDE-ON>>>>>>>>>>>>>>
    "Blue Belle" 2021 RTL Chrome in Petrol Blue
    2021 RTL Chrome , Petrol Blue
    Mar 2013
    Quote Originally Posted by Airborne View Post
    Hi all,
    Thanks
    BRP changed the front drive sprocket in September of 2020. If you get a 2021 made after that you should have the new sprocket that is designed to eliminate the noise. If unsure have the dealer check to make sure the sprocket is white on the one you are getting.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Nov 2012
    North Las Vegas, NV
    I just rode a 2021 RT at a Demo Day event a couple weeks ago. It did have a whine like described above. If I had one I'm sure I would get used to it. It may just take some miles for the belt to wear in.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Hi all,
    Thanks
    Being able to EXACTLY locate various sounds is quite difficult ..... badly aligned drive belt could have been the cause or the tension of that belt ..... sometimes there is no magic bullet ...... Cheers .... Mike
    Feb 2019
    Portland, Oregon
    I had the whine but it went away when I took the front Kendas off and replaced them with Federal Formoza tires. A vibration went away too!
    Active Member Rocketman 2012's Avatar
    Oct 2015
    Carthage, Missouri 64836
    My new 2021 RT SE6 has no Whine but if it did I'd have some Cheese with it as a bonus!
    Sam
    2021 Spyder RT ES6 PETROL metallic. Carthage, Missouri 64836
    May 2019
    Tasmania, Ausralia
    Thanks for the input guy's.
    I saw the Smak's video on you tube where he says it is an issue with air flow through or near the front sprocket and although he initially though it just characteristics of the bike i also read that BRP were now replacing the front sprocket but nothing definite. Anyone else have this issue or heard about the fix, just to confirm.
    I'll send over some nice Aussie cheese to go with your whine.
    May 2019
    Tasmania, Ausralia
    Quote Originally Posted by PW2013STL View Post
    Thanks Mate,
    I suspect your answer is the correct one but are you definite on that, its only the second time I've heard it after searching the internet. Paying $42000+ for a whine like that puts me off.
    It wasn't Tyres or anything else, i had a 18 F3 LTD before it with no issues.
    Dec 2013
    Thanks Mate,
    Quite a few posts/threads here confirming this - the later 2021 models got the 'upgrade white sprocket' to eliminate this noise!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    May 2019
    Tasmania, Ausralia
    Thanks for that Peter, a fountain of knowledge, as usual.
    Nov 2020
    Lincoln, Nebraska
    I to have the same whine on my 2016 RT. I believe it comes from the front tires as they are stock. It only occurs between about 35 and 45 miles an hour. But, who drives that slow?
    Oct 2020
    KS
    Dealer replacing my early '21 front sprocket under warranty.
    Quote Originally Posted by Rocketman 2012 View Post
    Sam
    You beat me to it. When I first read the title, I was also going to make some kind of a comment about wine.
    Aug 2018
    Piperton, TN
    I have a 2021 late and between 48 - 52, I get the whirling sound like a tornado siren. Every time I hear it I have to remind myself not to seek shelter.
    Aug 2020
    Michigan
    I have a 2020 RTL that I bought in Oct 2020. I noticed the whine at 50-54 mph. I did some research on this site and found out about the front sprocket issue. I brought my bike back into the dealer to have armrests and a hitch put on and at that time I asked about the sprocket issue and explained my findings. The dealer looked into it and advised me that BRP was aware of the issue and they were coming out with a different front sprocket. He put in an order for it and it came in around February and they replaced it under warranty. I have ridden it only 2-3 times due to weather here in Michigan but the whine is gone.
