1077 brake light bulb equivalent
I forgot which bulb I replaced brake light bulb with before as 1077 is not readily available on 2015 RS.
Was it 1157?
Thank you in advance.
6 states down 42 states to go
The 1077 is the same double contact bayonet base, staggered pins, other than the low element draws slightly less current than the 1157.
1077 low element is 0.48 amp
1157 low element is 0.59 amp
The 1077 is typical for European applications.
The 1157 high element for stop is same amps (2.1)
The 1157 low element is 38 lumens, compared to 25 for the 1077.
If turn signals not involved, have you considered 1157 LED?
23 Moto Guzzi V7-850 SE 23 Yamaha XT250 18 Yamaha Bolt R-Spec 22 Triumph Street Twin 20 CanAM Ryker 900 14 Honda CB1100 18 Yamaha XT250 16 Moto Guzzi V7 II 17 Yamaha TW200 12 Triumph Bonneville 02 Sportster 1200 Sport 03 Sportster 883 76 Honda CB750F 75 Honda CB360 70 Yamaha CT1 72 Yamaha CT2 72 Yamaha AT2/CT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda CB160 62 Honda CA110
2020 900 , NGK 4218 iridium CR8EIX Matte black
Thank you and I wanted to get spyderpops all in one, marker/turn/brake led but he says I can’t get it without strobe brake lights. I’ve been behind vehicles with strobe brake lights and found it to be distracting and very very annoying and don’t want it on my spyder.
1157 is installed and I’m good.
