Results 1 to 8 of 8
    Feb 2017
    Riverside ,Ca
    Default 2017 Spyder F3 Parking Brake will not release?!
    My parking brake will not release. I have disconnected the battery and reconnected but no luck. At least it's in the garage and not on the ride I took today.......can anyone address this mishap?
    Bossier LoUiSiAna
    Many options of threads on the matter
    https://www.spyderlovers.com/forums/...archid=2000640
    Oct 2015
    Lynden, WA
    The only way, I know of, to release the parking brake is to take the brake cable or the actuator lever off the fixturing point near the axle.
    Look for a video on YouTube. I carry 2 12mm combo wrenches just for this issue.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    PA
    Put a rock behind and in front of the rear tire before you loosen that 12mm nut! EXPERIENCE TALKING! Loosen the nut, count how many times you spin it. Take it home ignore the dumb beeping. Once you get home put a rock in front and behind rear wheel, open the brake side panel, get an air hose blow out the wheel, wipe the lever with a thin soft rag and see if it engages. If so tighten nut same count and your good till next time. It will happen again.
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    Happen to my new 2019 f3s too, disconnected the cable reinstalled and never had a problem with it again
    richie spyder
    Sep 2008
    TX
    I absolutely love this forum and the ability it affords one to find solutions to problems. My 2018 F3-T had this issue when I picked it up with 15 miles on it. The mech disassembled the actuator and reassembled and it "worked". 1000 miles later, same issue. Gave a Brake Switch error thru the BUDS, but switch and wires checked out. Adjusted the PB cable, solved for now. Seems like too much torque for the motor to release.
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
    Oct 2011
    Kalamazoo, Mi
    Quote Originally Posted by pauly1 View Post
    Pauly1, I think that is the key, the correct adjustment of slack on the parking brake cable IMO
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
    Feb 2013
    Edinburg, TX
    My 2015 had this problem at about 77,000 miles. It turned out to be a failure of the electronic module that controls the motor for the brake, and the motor that lowers/raises the windshield. Replaced under warranty, including the $50 tow bill. (But I had to pay the $20 cab ride home, 12 miles, then drive my car back the next day, to meet and direct the tow driver.) I knew nothing about pulling cables to release the brake, but the dealer tech did, to drive it of the tow truck. It was slid onto the steel truckbed rear-wheel first... no biggie.
    I had to wait several days for the new module to ship to the dealer.
    NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
    Retained the old mirrors with TricLed Signals
    General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
    Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
    Riken Raptor HR.........rear tire (at 114,200 miles)
    Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
    Gear Brake Decelerometer Module
    OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
    BajaRon Anti-sway Bar
    Kumho ECSTA AST rear tire (at 14,200 miles)
    TricLed Turn Signals in Mirrors
    2015 Limited , Intense Red Pearl
