My main worry with that is with the way it can easily breakaway if it catches anything (mainly potholes) on the road at speed is the possibility of directly driving over it at a speed that it would lift the body up enough to cause a loss of steering as it passes underneath not to mention the amount of damage it could cause.
2020 F3 SE6
I'm guessing it added approx. 6" overall length to the Spyder. I have since removed/sold it locally, as my F3S will be up for sale come spring. Other than an occasional scraping of the underside (designed to be a bump skid after all), I had no issues with it.
Reason: sense ;-)
2022 RT Sea To Sky
Retired U.S. Coast Guard 76-97
Shad bags
Lamonsters 2.0 usb dual power plate
F3 ultimate boards
LED arc lights
Lidlox helmet extender
Lamonsters top cuff with Ram ball and phone holder.
Lamonster billet sway bar end links
BRP driver backrest
LED Volt meter
BIW Cat Delete pipe
Route 129 windscreen
Looks super industrial - cool, but I have my doubts it will serve any real purpose other than looks. Unless you are driving through brush, off-road or your roads are littered with tall debris you can't avoid this has no purpose IMO.
BUT If I had the money to burn, I'd get it. I bought a similar looking guard for my riding mower. lol
2023 Spyder F3-S, Manta Green
2023 Ryker 600 ACE, Black on Black (The wife's toy )
2020 Kawasaki Z900, Candy Plasma Blue
Ordered & on the way! Will install soon as it gets a little warmer. No heated garage here. 2019 F3 came with Spyderpops bumpskid installed so have to remove that first. Front grill guard looks easy, no idea about remove/uninstall of bumpskid. Slingmod has them reduced by $60. plus 20% off with coupon code SEPERF.
That helps w/ the cost, also free shipping.
I ordered the version for my 2022 RT STS. Will install it the same time I install my BR Ultra sway bar.
2022 RT Sea To Sky
