Results 1 to 12 of 12
    Jan 2019
    North Carolina
    Default How much electricity is needed to stay charged?
    Hi folks, the building I will keep my 2013 RTL in doesn't have electricity yet
    I'm thinking about adding a solar panel to maintain the battery.
    And rough idea how much it uses just sitting there?
    Or maybe asked differently, any idea how much solar energy it would take to maintain the battery?
    Sep 2020
    Middletown, NJ
    Unless you have a parasitic device, it shouldn't need much solar power to maintain charge. Alternatively, you could remove the battery and put it on trickle charger in garage or somewhere with power if solar option falls thru.
    2020 RT base , Chalk White
    May 2017
    Mesa, Arid-Zone-A
    I have seen portable solar battery maintainers at Cabelas and Bass Pro Shop. They're available in different capacities and not very expensive. A little research on their web sites should provide you with the information you want. Good luck..... Jim
    Semper Fi
    Very Active Member Cobwebs's Avatar
    Sep 2018
    Australia
    I use one of these on all my toys. Works great even in low light conditions.
    https://www.amazon.com/SOLPERK-Panel...8162862&sr=8-3
    2017 F3S Daytona , Circuit Yellow Metalic
    Quote Originally Posted by Jackhartjr View Post
    IMHO taking your battery out is easier and lots less expense than what you thinking about doing. Then you put it on a small battery for an hour or two once a month. .... All the RT spyders have parasitic loss even in 100 % stock configuration ..... good luck .... Mike
    Sep 2016
    Chillicothe, Oh.
    Quote Originally Posted by Cobwebs View Post
    I have two of these that I use during the winter months. I ride year round as I don't own a four wheeled vehicle and my wife isn't always too keen on me taking her car. It would be a major pain in the butt to remove and install the battery in my Spyder or Guzzi repeatedly over the winter so I gave these a shot. They work well, but they WILL NOT charge a low battery, they are strictly a maintainer.
    2015 RT , Black
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Most devices which remain energized with the key off draw about 1 milliamp (0.001), each.
    A no load AGM self-discharge is about 2% per month…at cold temperatures.
    This is based upon a clean battery case. Crud on the case will allow current flow, post to post and greatly accelerate / augment discharge.
    If connected to a Sportster, (through 2006, with carb) this is load with the key off:
    Voltage regulator 1 milliamp (0.001 amp)
    Speedometer 1 milliamp (0.001 amp)
    Tachometer (if equipped) 1 milliamp (0.001 amp)
    TSM (non-security models) 1 milliamp (0.001 amp)
    TSSM (disarmed) 3 milliamp (0.003 amp)
    TSSM (armed) 3 milliamp (0.003 amp)
    TSSM (storage mode) 1 milliamp (0.001 amp)
    HFSM 1 milliamp (0.001 amp)
    Security siren 20 milliamp (0.020 amp): Siren will draw for 2-24 hours from time motorcycle battery is connected and 0.05 milliamperes (0.00005 amp) once siren battery is charged.
    I posted a Yuasa link on a Sportster forum, but the link is no longer valid.
    The sample battery in that link for discharge rate is an AGM and is 50% discharged in 60 days with a drain equal to the load of a voltage regulator, speedo, tach, and TSSM. With only a regulator, speedo (no tach) and TSM, the load is only ~ 3 milliamps and 50% discharge would be about 120-150 days. For 2014 up Sportsters, with CANBus, there would be additions for BCM, etc.
    Without a spec from the Can-AM factory service manual, we could use a moderately equipped auto, such as a Kia Soul spec of 50 milliamps, as the max to be expected (1/2 that more likely).
    0.050 amp x 12 volts = 0.6 watt maximum parasitic consumption (0.3 watt more likely)
    State of Charge (AGM battery)
    12.8+ 100%
    12.6 75%
    12.3 50%
    12.0 25%
    11.8 Zero
    Bottom line:
    A. Best to not go over 30 days without a charge, 60 days maximum
    B. The Amazon link by Cobwebs would do the job. A larger one could be detrimental, due to the possibility of an overcharge
    C. An unregulated solar panel should be checked for over voltage...perhaps connect a couple days a week and check voltage.
    I have AGMs, well past their warranty period, serving well in travel trailers at my ranch.
    They are used for LED lighting, water pump, circulation fans (summer) and cell phone recharge, typically 3 days out of 30.
    When I arrive and check the voltage, it can be in the low to mid 15 volt range...which is over typical voltage regulator limits of 13.8 to 14.8, even though the 5 watt panels are regulated.
    Before I switched to AGM from lead acid, distilled water had to be added at least twice a year. In 2004 I gave a 2001 Jeep to a daughter with a new battery. I put the old lead-acid battery in one of the trailers and used it for 10 years. In almost 20 years, I have only replaced one solar panel...but not the solar panel's fault that cattle like to chew on things; including wiring, screen tents, Nylon window screens, etc.
    May be more than you wanted to read, but some of the info may be helpful.
    23 Moto Guzzi V7-850 SE 23 Yamaha XT250 18 Yamaha Bolt R-Spec 22 Triumph Street Twin 20 CanAM Ryker 900 14 Honda CB1100 18 Yamaha XT250 16 Moto Guzzi V7 II 17 Yamaha TW200 12 Triumph Bonneville 02 Sportster 1200 Sport 03 Sportster 883 76 Honda CB750F 75 Honda CB360 70 Yamaha CT1 72 Yamaha CT2 72 Yamaha AT2/CT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda CB160 62 Honda CA110
    2020 900 , NGK 4218 iridium CR8EIX Matte black
    Bossier LoUiSiAna
    Quote Originally Posted by RayBJ View Post
    Except avoid trickle charger find a maintainer There is fair amount difference & less likely to kill/overcharge battery. Solar charging is good too however less sun available northern hemisphere this time of year, may not get best results
    https://www.spyderlovers.com/forums/...26#post1554426
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Jan 2019
    North Carolina
    Thanks for the excellent advice!
    I THOUGHT I had read that there was a lot of parasitic draw, apparently not as much as I thought.
    Much thanks!
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jan 2019
    Kentucky
    We use a 5W Battery Tender Solar Charger to maintain the deep cycle battery used to run a 12000# winch on a car hauler trailer. Does an excellent job and the panel isn't enormous.
    May 2020
    New Mexico
    A 5 watt is what I use on automotive batteries.
    Think they were $79, each.
    I started out with a 2 watt (appropriate for M/C battery)
    When cattle killed it, switched to 5 watt and mounted it higher
