Results 1 to 11 of 11
    Jul 2017
    Woodbine, Iowa
    Default Tire monitoring System
    Is there any one on here using a tire monitor system on their Spyder? I have used Doran for years on my motorcycles. The model that I have they have stopped making the sensors for. Does anyone know of a good brand to buy?
    2021 RT Limited
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    Jan 2020
    New York
    FOBO 2 works great. Integrates with BRP connect so you can see it on the Bike screen as well with your phone connected.
    https://my-fobo.com/product-family/F...KE_2_for_Trike
    2020 RT Limited , ASPHALT GREY METALLIC - DARK EDITION
    Aug 2020
    Georgia
    Quote Originally Posted by AdmiralS View Post
    Integrates with BRP connect so you can see it on the Bike screen..
    I didn't realize it would also pair with the bike - that is a great feature for those. Does it also tell you the tp before you ride the bike, either via your phone or the dash? That was one feature that I wished that my previous motorcycles had.
    Active Member Spydermike's Avatar
    Mar 2018
    Maricopa, AZ
    I have FOBO as well and have been pretty pleased with them
    2016 RTL "Boris"
    Foam Grips
    Utopia Backrest
    BRP Passenger armrests
    Bajaron sway bar
    LED Bumpskid w/remote
    Belt guard
    BRT rear lighting w/strobe
    High mount BRT w/strobe
    Dual a-arm LEDs w/turn signals
    Multicolor underground Halo lighting
    LED headlights and foglights
    FOBO TPMS
    Techgripper phone holder
    Lidlox
    Dual USB with voltmeter
    Dakota Digital Compass/Clock/Altimeter/Temperature Gauge
    Vredestein Quatrac 5 175/55R15 - Fronts
    General Altimax RT43 215/60R15 - Rear
    Feb 2020
    N. Wilkesboro, NC
    Quote Originally Posted by WilcoJunoHotel View Post
    It pairs with 2018+ RTs and F3T/Ls. BuRP Connect is trash but allegedly, FOBO 2 now works in it. If you use BuRP Connect, you can't use your phone for anything else. I have the FOBO 2 and it works very well but I don't use BuRP Connect. FOBO 2 has a stand alone phone app. That's what I use. You can see the tire pressures and temps any time. The bike doesn't have to be running. Just checked my tire pressures from my office and my bike hasn't been running since Sunday.
    Active Member SgtRay's Avatar
    May 2019
    El Paso TX
    I have the FOBO But mine don't seem to go down far enough to hit the valve stem to read the pressure. So currently they don't work at all. Anybody have any suggestions that don't involve switching out the whole valve stem?
    "Friend to those who have no friends. Enemy to those who need no enemies. Headache to those who have no aspirin."~ The Phantom Texter
    2019 F3 s , Neutrino Aurora Accessory Fuse Block Blue
    Oct 2011
    Jacksonville,Ar
    Do not use the locks. Also on some year F3 the stems are to short
    15 rt , yes Black
    Feb 2020
    N. Wilkesboro, NC
    They don't fit on Shamrock wheels although I'm not sure what the Shamrock wheels are or what models they came on.
    May 2019
    El Paso TX
    Quote Originally Posted by samewok View Post
    Just my luck!
    May 2019
    El Paso TX
    I tried putting a piece of a toothpick in and it worked! But it was too long and wouldn't let the valve seat. So I switched to a piece of plastic zip tie. I seems to be working. I know when I check it when I get home wed night.
    Wow the things I do to make things work!
    May 2019
    El Paso TX
    Quote Originally Posted by SgtRay View Post
    Nope didn't work. air leaked out... Well I did get a cool tire inflator out of it! Lol
