Results 1 to 23 of 23
    GOS member (Girls On Spyders) cohoff's Avatar
    nebraska
    Default Battery Tender for 2020 RT
    I used this battery tender on my 2014 RTS and used the cigarette lighter adapter to plug it in in my rear trunk. The plug in in the trunk on my 2020 RT is USB. Where do I plug in the battery tender on my 2020 RT?
    http://visitedstatesmap.com/image/AZCACOIDILINIAKSKYMDMIMNMOMTNENVNMNCOHORPASDTNUTVA  WAWVWIWYmed.jpg
    Sep 2020
    Lakeland, FL
    Same question...
    2021 S2S , Green
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    Connect the pigtail shown in the photo directly to the battery, that's what I had to do with my 2018.
    2018 RT LTD , Black
    I agree, pigtail directly to battery. FWIW, my BT Jr is plugged into a double receptacle in the garage ceiling and the power cord hangs down into the frunk when it's plugged into the pigtail.
    Sep 2020
    Platte City, MO
    ^^^^^^^^That's how Peggy's Spyder is set up. Works well.
    nebraska
    Quote Originally Posted by ottawa-rider View Post
    Which part is the pigtail?
    Sep 2020
    Platte City, MO
    The pigtail is the section of wire with either the clamps, or ring connectors to hook to the battery. It has a coupling
    to connect it to the tender. The tender is plugged into an outlet, so the pigtail can stay attached to the battery and
    can be disconnected from the tender. Good ones have an inline fuse.
    In the photo, the far right item and the far left item are both pigtails.
    nebraska
    Thank you very much for explaining it so clearly for me
    Feb 2019
    Portland, Oregon
    It looks to me you should invite a friend over, one who knows automotive electrics to connect the pigtail. The electrics in Spyders is very fussy and grievous harm can be done to it if a mistake is made.
    For the cost of a beer or two, you'll save your bike.
    INDIANA, USA
    Default Directions
    I have the same 'Battery Tender Jr' and received very good directions in the package. Good Luck with your Mission. .......
    ENJOY YOUR LIFE WITH A SPYDER
    nebraska
    I took your advice. Thank you.
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by cohoff View Post
    I'm glad I could help. Too bad you don't live near me, I love a beer right now.
    If you want to attach the permanent pigtail to the battery, the one at the lower left in the picture is the one you will use. Note the marked red and black eyelet terminals, they are connected to the positive and negative terminals, respectively, of the battery and there is an SAE plug on the other end of the pigtail. Simply, remove the bolt on the negative terminal of the battery first. Move the negative (ground) wire and wrap some tape around it so there can be no metal to metal contact with the Spyder. Then remove the the bolt on the positive battery terminal and attach the positive pigtail eyelet to the terminal with the bolt. Some folks also recommend adding a star washer between the bolt head and the two terminal leads. Next, remove the tape from the negative Spyder ground cable and attach the negative pigtail terminal as you did on the positive side. Lastly, plug the battery tender into a 110V receptacle and plug the SAE connector on the power cord to the pigtail; it will only fit one way. An indicator light on the battery tender will come on, probably red. After a few minutes the red light will begin flashing green and finally will show steady green. That's all there is to it. Always remember to unplug the pigtail BEFORE you start the Spyder.
    Nov 2020
    Lincoln, Nebraska
    Perfect.
    Nov 2019
    PA
    My 2020 RTL came with a pre-installed battery tender connector located near the left front shock. I plug my Battery Tender Jr. directly to it, no problem. Not sure if this is just the Limited model, or also on the base RT. Sorry if this has already been posted here.
    Jul 2010
    Las Vegas, NV
    Next time, ride over. I’ll do it. Joe
    Joe Meyer
    Sep 2012
    Quote Originally Posted by japgen View Post
    If the Spyder came with a pre-installed connection, it was from the dealer not BRP, some are known to do that.
    2018 RT LTD , Black
    Yes, some dealerships, including Honda, Can-Am, Seadoo of Winston-Salem threw mine in complementary, pigtail attached.
    Nov 2019
    PA
    That's interesting. I learned about it on this forum after taking delivery of the bike. Dealer made no mention of it. You would think they would point that out if only to gain some customer good will.
    Aug 2018
    north wis
    On my 18 and again on the 20 I asked the dealer to run the tender connector under the seat.Easy access for tender and doubles to connect heated gear with an adapter.
    Apr 2020
    North Myrtle Beach
    I have 5 or 6 small chargers. I need to connect 1 to my RTs. I'd been considering building a magnetic plug for one of my cars. Connect the charger wires to the magnets (one North and One South) then mount the magnets under the car (it's fiberglass). The magnets make the connection, if you forget to unplug the charger No Problem. It just pops apart. I could do the same under the Frunk and possible kill 2 birds with 1 stone. (My RT will not Trigger the Red Light leaving my house.
    The dealer/salesperson you interacted with at the dealer probably has no idea that it's even there in the first place - let alone who installed it; where it's been installed; what it's actually useful for; why it's there at all; or how it even makes any difference!!
    But since you DO actually have a connection like that, it suggests there's at least ONE customer service oriented & conscientious Supervisor &/or tech in the Service Department of whatever dealer took your Spyder out of its shipping crate & assembled it?! Consider yourself lucky!
    Jun 2011
    Alamogordo, NM
    Make sure you can get to the fuse to replace it if it Blows. I can run a Gerbings Jacket liner and Gerbings Heated Gloves on mine.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
