Results 1 to 15 of 15
    SpyderLovers Sponsor
    Nov 2012
    Twinsburg, Ohio
    Default Question from Don Frank at F4 Customs about steering
    Hey folks as some of you know Kim, my wife, rides a 2016 Can-Am RT. She has the Elkin shocks and adjustable handle bars.
    She has been telling me that her steering is getting hard to turn. I rode it and unless your moving you can't turn the handlebars. My F3 Limited as soon as I start the bike and try to turn the handle bars I can quite easily and I remember her RT was that way at one time.
    What do you suggest? Have any of you had this issue?
    Don
    Hard steering on my 2014 RT-S when not moving down the road. No answer as to why???
    Active Member LifeLongRider's Avatar
    Aug 2018
    Florida
    DPS? Dynamic Power Steering sensor? Is it throwing any codes?
    2019 F3 Limited
    2019 F3 Limited , Oxford Blue
    Sep 2020
    Platte City, MO
    Just a data point, Peggy's 2013 STS-SM5 is hard to turn at a standstill, but is easy to turn when moving. Almost impossible
    to turn if the motor is off.
    The power steering is dependent on many things, one of which is battery power. If your battery voltage is low, the assist
    will be less. That's about the only thing I can think of that can be easily checked.
    Does it still have the original battery? If so, it might be time to change it. The DPS draws a huge amount of power, much more than the alternator supplies. If it's getting old and weak it just may not have the oomph needed to power the DPS adequately. Poor connections can act the same. Check the battery cable terminals. A good cleaning may solve the problem.
    Nov 2012
    Twinsburg, Ohio
    Default steering
    Quote Originally Posted by LifeLongRider View Post
    No codes and I changed the battery just in case there was not the right amount of current
    Nov 2012
    Twinsburg, Ohio
    May have to bite the bullet and change the sensor
    Very Active Member fireplug98's Avatar
    Sep 2011
    Arden Hills, MN
    Quote Originally Posted by F4 Customs View Post
    Or buy her a new bike !!!
    Tommy J.
    F3L SE5 Black -- F4 windshield w/wings, Reggie LED headlights, driving lights & Cyclops LED, Ultimate seat, Fox shocks, BajaRon swaybar, Lamont highway centerline pegs & 3rd peg, Lamont belt tensioner, K&N air filter, Baker air wings & cup holder, CanAm hitch.
    2019 F3L , Black
    Nov 2012
    Twinsburg, Ohio
    Quote Originally Posted by fireplug98 View Post
    Tommy J.
    No she likes this one
    Kim's Spyder doesn't have a low or flat tire or two up front, does it??
    Anything much lower than about 10psi in either or both of the front tires will make your 'not moving' steering pretty hard, even with the better 'stopped & low speed DPS assist' that's available on the more recent Spyders. I've found that dropping the tire pressure in my (not Kenda) front tires down to just 12 psi up front on my 2013 RT doesn't measurably increase the required turning effort; but the moment I drop just one front tire below about 10psi, the necessary turning effort goes off the scale PDQ!! (altho admittedly, it is a pretty small scale that I use to measure that turning effort. )
    Worth a look, maybe??
    That means changing the entire DPS unit. The torque sensor that controls how much assist is provided is an integral part of the DPS.
    Sep 2009
    La Valle, WI
    My 15 RTS turned hard sitting still. Had to start moving to get ps. The F3's all steer easy at idle. It wasn't till late 2017 they put the new dps in the RT's. Unless it turns hard while moving. Probably normal. Make sure battery terminals are tight. Even slightly loose. The dps wont work right.
    2018 F3 Limited , Oxford Blue
    Apr 2020
    Edgerton,WI
    Don
    Lift the front end off the ground to remove weight off the front wheels.....check for binding in steering components....ball joints,tie rods,steering shaft.
    2019 F3L , Covid Blue
    Active Member papanorm's Avatar
    Aug 2016
    central texas
    I raised my front tire pressures to 15-16 and it made a noticeable difference in steering improvement. Also I don’t feel the bike wandering when hitting bumps while cruising.
    2016 F3L , Big Bike Parts Black
    Clinton, MS
    Quote Originally Posted by papanorm View Post
    Got to ask, what pressure did you raise it from?
