Results 1 to 9 of 9
    Oct 2020
    Ontario Canada
    Default Rear brake squeeks
    Dealer installed new rear pads on 2012 RT Limited
    Now when coming to stop only just before stop there is a squeal sound. More often first few stops
    Dealer so far not able to fix
    Any ideas?
    Brake squeal is not uncommon. Especially on the pre-2013 models. There are a number of things that can be done to mitigate the noise. The 1st thing I would try would be to do some hard stops to heat the pads up and cure the resin. Slow as fast as you can from 60 mph to 20 mph in quick succession at least 3 times. Then ride a few miles without applying the brakes to let the brake system cool naturally. This may cure your problem. If not, there are some other things which can be done. However, the most effective methods require removal of the brake pads.
    Good luck!
    Oct 2020
    Ontario Canada
    Thanks I’ll try that and let you know if it fixes the issue
    Oct 2020
    SC
    Good luck!
    I have had the same problem only my squeal is when I back up my 2012RT. It happens as I am rolling back (engine off) I step on the brake and it stops...had a mechanic here in Greenville SC tell me to spray some silicone on the brake sprocket ?? Any thoughts?
    Oct 2020
    SC
    Mar 2015
    forrest above Reno, Nv
    Brake sprocket?????????????/
    I wouldn't have silicone spray anywhere near my brakes.............. I even wash my dirty, greasy hands before putting in the brake pads.
    Lew L
    2014 RTS , Circuit Yellow
    Sep 2020
    Platte City, MO
    What's a "brake sprocket"? And yeah, any silicone spray needs to be far from braking surfaces.
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Quote Originally Posted by Lew L View Post
    Lew L
    Agreed. Bad advise, even if you could figure out what they were talking about!
    Oct 2020
    Ontario Canada
    Thanks for the tip.
    Has helped to cure the problem except for first couple of stops. After that no sounds.
