Page 1 of 3 123 LastLast
Results 1 to 25 of 63
    Very Active Member mastertek2000's Avatar
    Mar 2012
    E Freetown MA
    Default 2014 RT SE6 with no spark - any ideas?
    i have 2014 Rt wont start no spark any idea 10.000 miles on it
    Sep 2012
    Stetson, Maine
    Im sure you checked your kill switch.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Sep 2014
    USA
    Wont start? Does it turn over? How do you know you have no spark? Do you have gas?
    This may help try to solve your issue.
    Quote Originally Posted by mastertek2000 View Post
    After you check the KILL switch .... try jumping it with a car/trk battery .... I would do this WITHOUT the vehicle running .... then you need to check the State of Battery voltage .... good luck .... Mike
    Mar 2015
    forrest above Reno, Nv
    A little more info would certainly be helpful. Does the motor spin but not start??? What happens when you press the starter switch??? In gear- foot on brake??? Anything on the dash? Could be a DESS failure????
    Good Luck.
    2014 RTS , Circuit Yellow
    Mar 2012
    E Freetown MA
    Quote Originally Posted by Lew L View Post
    Good Luck.
    it cranks when you turn the key on you can hear fuel pump no DESS failure and no codes i pulled hose off air box shot some fuel in it and nothing so i would say no spark
    Sep 2014
    USA
    You still may have not got any fuel into the intake at the hose area. Maybe closer to the air filter but would have to remove the air filter first , you may get better fuel to squirt into the throttle body.
    Or try starting fluid.
    Mar 2012
    E Freetown MA
    i did that removed hose next to throttle body and not even a sputter
    Durham,Maine
    What have you done to the bike leading up to the moment that it didn't start?? Did you wash it? Was you under her skirt playing around with some wires, or digging around to install a farkel? Did it sit in the rain with out a cover on it? There's a lot of things that could cause this and we have to have the answers to this to pin point the issue!
    2012 RTL , Pearl
    Active Member Stache's Avatar
    Apr 2020
    Flatrock, NL, CA
    I don’t think you’ve confirmed no spark yet. Have you pulled a plug and held it to ground while cranking?
    MWO (Ret'd) SJ Barnes
    ‘20 RTL Stone Grey
    named Britannia in honour of EE Doc Smith’s
    Grey Lensman’s ship.
    Farkles:
    Bestem Carplay
    canamsypderaccessories hitch and wiring harness,
    showchrome trunk rack,
    12v AND dual USB direct to battery in the frunk,
    dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
    frunk lid organizer,
    trunk organizer,
    showchrome rider backrest,
    ryder and passenger cup holders,
    ram mount for the iPad mini I use for GPS
    quadlock phone mount
    Nautilus horn
    Data blocker on the glove box USB
    Big Bike Parts highway pegs
    Spyderzone dash pouch
    Convex mirrors
    ‘20 Ryker 900 (my wife’s ryde)
    Farkles
    Slingmods fwd/rev ‘suicide shifter’
    frunk organizer
    dual horn
    Max mount
    Rear seat with tall back rest (not mounted)
    Ryder backrest (not mounted)
    Side bag
    Top bag
    top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
    2020 RT Limited , Stone Gray
    Mar 2012
    E Freetown MA
    Been build new home in TN have had no time just kept in on battery tender and started it up every month had to replace battery that’s about it and new fuel is was sputtering but now nothing
    Jul 2011
    Mitchell, Ontario, Canada
    Sounds like it could be flooded.
    Twist the the throttle to full open and hold it there. That will turn off the fuel injectors. Crank the engine for 10 seconds max. Allow the starter to cool for a bit. Then do it again. After that try a normal start.
    Durham,Maine
    Now did you drain the tank or just put new gas over the bad??
    2012 RTL , Pearl
    Durham,Maine
    I would start by draining as much gas out as you can, and start out fresh! Then put some good gas in and put a good shot of seafoam in with it! Then try to start again, it's going to take a bit to get that bad gas out of the lines. And you have to take care you don't run the battery down to far!
    2012 RTL , Pearl
    Durham,Maine
    If it's sputtering you got spark it's just got crap in the fuel system!! I am a firm believer in seafoam, it works, some people here on this site don't, but it has worked for me!! Good luck, you'll get it!!
    2012 RTL , Pearl
    When a bike is on battery tender for a long rest, it is best to NOT start the vehicle once a month. The engine usually does not get fully warmed up unless you ride it each time you start it.
    This may be the cause of the problem. The advice about fuel and flooding is probably right on.
    Mar 2012
    E Freetown MA
    Took it for ride ran it down them filled it up
    Mar 2012
    E Freetown MA
    I did that
    Durham,Maine
    So you got it!!! Great!!!!!
    2012 RTL , Pearl
    Mar 2012
    E Freetown MA
    It start about a week ago but now nothing
    Durham,Maine
    OH, crap!!!
    2012 RTL , Pearl
    Durham,Maine
    Is you your battery up to full charge?
    2012 RTL , Pearl
    Durham,Maine
    Still think you got a water problem! Bad fuel can give you fits, and a weak battery with this machine will do the same! Your fuel filter could be full of crap Good luck I'll leave you alone!!!!
    2012 RTL , Pearl
    Sep 2014
    USA
    Wondering too about low battery voltage?
    Sep 2014
    USA
    Engine Cranking Conditions SM6 Model The following conditions must be met to allow engine cranking: – Ignition switch ON – Emergency engine stop switch to RUN – Mode button pressed in once (safety message acknowledgement) – Transmission in neutral (or in gear with clutch lever depressed) – Brake pedal depressed – D.E.S.S. recognizes the key – Start button pressed in. SE6 Model The following conditions must be met to allow engine cranking: – Ignition switch ON – Emergency engine stop switch to RUN – Mode button pressed in once (safety message acknowledgement) – Transmission in neutral – Brake pedal depressed – D.E.S.S. recognizes the key – Start button pressed in. NOTE: If the transmission was not in neutral when the engine was shut off, the HCM (hydraulic control module) will automatically shift the transmission to neutral at the next engine start to allow engine starting (if there is sufficient oil pressure). The parking brake state will not affect engine cranking. TROUBLESHOOTING TROUBLESHOOTING TIPS It is good practice to check for fault codes using B.U.D.S.as a first troubleshooting step. Refer to COMMUNICATION TOOLS AND B.U.D.S. subsection. Refer to POWER DISTRIBUTION AND GROUNDS for fuses and relays information. Always refer to the WIRING DIAGRAMwhen troubleshooting an electrical circuit. Install a battery charger on jump start posts in front storage compartment for any tests that involve a prolonged "key ON" period. If battery voltage gets too low, test results can be altered. NOTICE Never force a multimeter probe into an electrical terminal. STARTING SYSTEM TROUBLESHOOTING If the gauge or lights do not come on when ignition switch is ON, refer to TROUBLESHOOTING in IGNITION SYSTEMsubsection. If gauge and lights come ON with the ignition switch ON and starter does not engage, start your testing sequence by carrying out STARTER OPERATION TESTin this subsection.
