Results 1 to 3 of 3
    May 2015
    Arizona
    Default RT fender issue - broken mount block
    On my 2014 RT front fender there are 2 mount blocks attached to under side of fender. One of these mount blocks has broken off. Any one else have this issue and how did you fix it?
    Last edited by Peter Aawen; 08-25-2020 at 06:39 PM. Reason: This is a 'How do I?' not a 'How to:' diy explanation....
    Jul 2014
    Mint Hill, NC
    Haven't had the problem but is I had, first thought would be epoxy.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    RT-S PE#0060 Gordy's Avatar
    neepawa manitoba ca
    both of mine broke on my 2010 rts they are a hollow tube so i fitted a rod on the inside and welded both of them ,havent had any more trouble
