Results 1 to 21 of 21
    Jun 2020
    Aurora,In
    Default Starting my Spyder
    2017 RT Limited any way around the starting sequence needed to start from factory?
    Bossier LoUiSiAna
    Guessing you mean skipping the mode button some have disabled the dess. I think removes that sequence from the start up, however :lecturef_smilie does remove one of security features allowing easier theft
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Jun 2020
    Aurora,In
    Been riding 60 years without it guess I’ll learn to live with it. Thanks
    Active Member Spyderjuice's Avatar
    Aug 2008
    High Point, North Carolina
    Disabling the DESS does not eliminate the start up procedure, only eliminates the chipped key reading. To eliminate the start up I think you have to do the ECU update.
    Spyderjuice
    Happy owner of 2014 White RTS - SE6
    Sep 2016
    Chillicothe, Oh.
    My DESS has been disabled and I still have to do the ritual.
    2015 RT , Black
    Active Member trong's Avatar
    May 2020
    West Valley City, Utah
    Pressing another button to start my RTL doesn't bother me. What I do not like is waiting for the electronics system to get ready. Why does it take that long? For the glow plugs to get warm up?
    ‘21 Honda Rebel 1100 DTC Burgundy
    ‘13 Spyder RT-L Pearl White
    Mar 2013
    Marion, Arkansas
    No the long wait is the computer booting up. Glow plugs are in diesel engines, not gas engines.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Aug 2019
    southwest oHIo
    Have you tried pressing the Mode button BEFORE the procedure is complete?
    On our '17 RT-S, we turn the key ON, press the MODE button, press the START button in rather quick sequence. Once you are comfortable that there is enough oil pressure or if you want it to warm up for a few seconds, you can put it in gear, release the brake and drive off.
    If you do these all in quick sequence, you can be moving in about the same time that the computer will be telling you that you can continue with the start sequence.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Quote Originally Posted by jkoons View Post
    I decided very early on #1- insert key .....#2- turn key on ...#3 put on helmet ....#4- hit start button ....#5- drive spyder = No delay ..... Mike
    Jun 2020
    Aurora,In
    Sounds like a plan.
    Idaho
    I turn the key on when I approach the bike. No harm in letting it sit there for even 5 minutes while putting on gear.
    2014 Copper RTS
    Feb 2012
    Spring City,Utah
    My routine exactly. Turn on Spyder ,put on gear,, climb on Spyder, instant start.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    May 2020
    Quote Originally Posted by Ex-Rocket View Post
    Sorry I was wrong about glow plugs.
    I have done some researching and what I have found is very interesting. According to some technical service manuals that were circulated inside BRP only, applicable only to Spyders sold in other countries outside of Canada, when you turn on the ignition key, the computer of course will have to initialize and then use Google to translate from Canadian French to local user language. For example, my 2013 RTL takes that long to complete the booting up procedure because it takes that long to translate from Canadian French to American English.
    Also for those countries that do not use Latin alphabets for their written language it will take up to 4 minutes for the Spyder to complete the computer boot up sequence. That is why there are not many Spyders sold in China or Japan or India and such.
    I just deal with the starting procedure for now until I can find a way to embed English in my Spyder as default language.
    Cheers.
    Very Active Member bluewoo's Avatar
    Sep 2018
    greensburg,pa
    You can get the ECU re flashed and they can remove that feature. My 18 I just turn key on,hit mode start it an go.
    2021 RT LTD Petrol Blue DARK delivered 9/22/20
    New Engine @ 500 miles 4/8/21 - 5/21 due to oil leak in block
    https://www.spyderlovers.com/forums/...400-miles-HELP
    2018 RT-L , Blue
    Dec 2013
    Quote Originally Posted by trong View Post
    Cheers.
    Maybe you could just set your dash language to Canadian French instead?? Altho I do think that at least the older/pre-2017 Canadian Spyders still have that 'wait for the message then press mode & start' delay built in?!
    Still, even tho I've had my Spyder's ECU Upgrade done, I'm one of those who practices turning the key on, finishes getting my helmet & gloves etc all buttoned up, climbs aboard, presses mode, & then starts the engine before ryding off... altho admittedly, sometimes I might actually get to start the engine immediately BEFORE I climb aboard! Regardless, having that Mode thing or not has really made ABSOLUTELY NO DIFFERENCE in the overall scheme of things as to how long it takes me to walk outta the house with my gear in hand & what time elapses before I actually hit the road
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    I tried it on my '14 - I don't have to wait for the screen to finish booting to start up. Turn key, press mode, press start and it fires right up.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Aug 2016
    ne Pa
    Turn on key press mode press start. Works on all the 1300cc as far as I know.
    Jun 2020
    Aurora,In
    Hey that work. Thanks
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by bluewoo View Post
    I hope you didn’t pay extra for that “feature”, bluewoo, because “turn key, hit mode, hit start” is standard on the 2015 and later models
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2020
    Aurora,In
    You know the old timers always said if you don’t learn something new everyday you ain’t paying attention.
    Sep 2018
    greensburg,pa
    Pete
    No, I never had it flashed. Other owners have had the ecu re flashed and it's also an option to remove the "press mode" button on start up.
    Open this and read it where it states Quick start.....https://bc5ea35f-0a76-4e03-8a52-544a...cf24549946.pdf
    2018 RT-L , Blue
