Results 1 to 9 of 9
    Sep 2019
    Christiana TN
    Default HELP! Stripped out tranmission plug
    Of course what seems like the simplest tasks to do has turned into a bit of a nightmare. I got the T45 oil drain plug out without much issue, however the 6mm allen/hex transmission plug has now been stripped. I have tried a few things like lock wrenches to try and grab the smallish area of the bolt, but no luck.
    Really need suggestions please!
    Thank you,
    john
    2015 F3S , Black/Chrome/Red
    Jul 2018
    Northern New York
    if you can find this tool locally it will probably work...go to amazon.com and type in vampliers in the search to get to the tool....i have 2 pairs of them different sizes and used them for stripped bolts..they do work!! Hopefully u can get them locally since you need them in a hurry...If your having trouble finding the page on amazon.com i can take a pic of my 2 tools to send you...good luck!
    Jul 2018
    Northern New York
    Ive also used this tool to remove stripped allen head bolts from the side case of my Ultra...
    Northern Kalifornia
    Pick a torx head bit one size larger than the 6mm allen head bit, cram it all the way into the allen plug and then remember, right tight, left loose. Then replace those dam things with quality aftermarket hex head plugs. Lots of luck.
    You can glue a tool into the stripped out hole using JB Weld. You need to let it sit a day. But this has worked for me.
    Florida Swamp
    I tapped some out with a small chisel against the edge of the plug angled in the unscrew direction. Don't need to bump it too hard. The slight impact when you tap the chisel will get it started turning. Once it backs out about half a turn you can back it on out with pliers. Sometimes you have to remove the plastic cover so you can get the chisel on the plug. You have to jack it up or run it up on ramps to have enough room to work under there.
    Same trick usually works removing stripped bolt heads or Phillips heads. For small screws use a very small center punch to get the screw turning.
    2019 F3-S , Black & Silver
    Sep 2019
    Christiana TN
    Thanks ALL! Yes, a torx hammered in a bit did the trick!
    john
    Quote Originally Posted by MidTNSpyderGuy View Post
    john
    Glad you got it out ..... what might have helped you was the " Hammered it in a bit " .... these plugs have a tendency to " varnish lock " .... and respond well to hitting them fairly hard before trying to get them out .... I also set my rachet to loosen BEFORE I try to use it .... it is easy to forget that when using it " upside down " to forget it's now " rightly " to loosen ...... Mike
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by Gwolf View Post
    On my first RT, even the Svc Tech couldn't get it loose, but he used the chisel method and told me about it. Later, on a newer RT, had same prob and the chisel worked great. Didn't take much of a tap to get it loose.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
