Results 1 to 25 of 38
    Jan 2020
    New York
    Default RTL 2020 Mirror Wedgies
    Hi All,
    The mirror wobble has gotten progressively worse on our 20 RT Limited as we have put more miles on it. Based on other posts it seems that wedgies were in the works but could not find if they are available.
    Anyone have any more info?
    2020 RT Limited , ASPHALT GREY METALLIC - DARK EDITION
    Mar 2013
    Maumelle, AR
    I talked with Joe Meyer (Squared Away) at the Deadwood Rally and he said they're still in the works. He's been pretty busy lately, but hopes it won't be too much longer.
    2020 RT Limited , Chalk
    Feb 2020
    N. Wilkesboro, NC
    2020 RT mirrors are the same as the F3T/L mirrors. You have (2) options. First, you can buy the wedgies. It's my understanding that there's someone on this forum who developed them and may still sell them. I know Slingmods also sells them so the forum member may have sold out to Slingmods. The 2nd option is through LaMonster. He has a video out that shows how he fixed the issue by drilling a hole, tapping same and installing a bolt to tighten things down. I don't know if Lamont is selling his special drill bit or not.
    Nov 2018
    Waynesboro, PA
    Here you go look at this as a DIY project https://www.lamonstergarage.com/cam-...3-and-2020-rt/
    My Spyder
    2012 RTL , Brown
    Jan 2020
    New York
    Quote Originally Posted by CopperSpyder View Post
    Thanks. Sounds like a super simple solution. Will give it a whirl this weekend
    Apr 2020
    Westfield, IN
    I'm a little confuse with BRP concerning the vibrating mirror problem. I had a 2012 RT with no mirror vibrations. I recently purchased a 2020 RTL with the left mirror vibrating. BPP doesn't think its an issue, therefore doesn't have a fix? What is the difference between the left mirror and the right mirror? My right mirror doesn't vibrate. I re-tighten the 3 bolts in the left mirror and seen to help a little. I'm almost due for the 3K oil change and plan to ask the dealer about this issue.
    Active Member Frostbyte's Avatar
    Nov 2019
    Florida
    The 1/4 - 20 combo drill/tap used in the Lamonster video is made by Kline Tools, and is available at Graybar Electrical Supply and other Kline suppliers. I have the full Electrician's set ganging from 6-32 through 1/4 - 20. Electricians like myself have been using specialty tools like these and Triple Taps for ages.
    Knowledge is the accumulation and remembering data.
    Wisdom is the effective application of it.
    [img]https://www.spyderlovers.com/forums/maps/map.png?
    2019 RT Limited , 2" Pedal Extender W/Oversize Pedal Phoenix Orange
    May 2016
    Vancouver Island, BC, Canada
    Quote Originally Posted by AdmiralS View Post
    Hi All,
    Apparently, BRP now markets kits that convert the loose mirrors from clip-on to bolt-on. My dealer has ordered several sets; no word yet on deliveries.
    2023 900 Sport , Nitro Blue
    Danbury Connecticut
    Quote Originally Posted by Frostbyte View Post
    Another vote for Lamonsters' fix. It worked for me. I already had a drill set to drill a 1/4" hole. I threaded the hole with a 1/4-20 tap I bought at Home Depot for about $6.00 and a couple of 1/4-20 screws. I couldn't find stainless steel, so I used brass screws.
    Zip Zam Zowie and SWOOSH..... All Fixed.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Danbury Connecticut
    Quote Originally Posted by ryu1867 View Post
    Any info on this kit ?
    IBA #47122
    Jan 2020
    New York
    Added the two machine screws today and it was night and day difference. Took 10 minutes start to finish. Took longer to run to the hardware store and back....
    Jul 2010
    Las Vegas, NV
    As soon as anyone has a part number, please PM me! I have gap issues with Wedgies on the 2020. Simple is better! Thanks! Joe
    Joe Meyer
    Sep 2018
    greensburg,pa
    2018 RT-L , Blue
    Jan 2020
    New York
    I ordered the parts earlier today. 62$ seems excessive, but i have seen that the screw fix eats into the bracket on the machine.
    708400550 x 4 - Brass Anchors
    207551044 x 4 - M5 Screws
    232561200 x 4 - Nylon Lock Nuts
    Active Member RTL1330's Avatar
    Dec 2014
    Campbell River, BC, Canada
    Just had my 2020 RTL mirrors fixed at dealer no charge. They ordered the new mirror repair kits and installed today. Took 1/2 hour for both and now they bolt on with 2 bolts at base of mirrors under back covers. Mirrors are solid now no vibration. I have no part number info etc. As dealer ordered, installed and no paper work. Now I can see who is behind me.
    NOTE - these are installed by dealer tech at NO COST as a warranty fix.
    2020 RTL - Petrol Blue Metalic / Black, dark model.
    Colour match rear tail cover, Garmin GPS.
    Heated Ultra Comfort driver seat & backrest.
    LED headlamps, LED Front corner lamps and lower front LED lamp.
    Baja Ron sway bar.
    Ride Til You Rot!
    Jul 2020
    Port Hope, Ontario, Canada
    I have a new 2020 RTL. Same issue, but BRP does have a fix. It won’t be a recall since it’s not considered a safety issue. My dealer has just ordered the parts for me. I gave him the part numbers as used by Shawn Smoak in Vancouver WA. You’ll need 4 of each as follows:
    708400550 - anchorage, mirror,
    207551044 - flange hex screw.
    232561200 - nut, stop, elastic.
    Cost should be about $65.
    My parts guy said they are listed at BRP so it shouldn’t be an issue to get hold of them..
    Active Member rick_w's Avatar
    May 2013
    NE Ohio, Madison
    Quote Originally Posted by DesHaggerty View Post
    They are giving you a deal, list is about $75. It probably is the best way to fix it but I really can't imagine why they just don't fix all of them like this.
    About 9 minutes into the video he shows the parts, very easy fix with some expensive nice parts.
    https://www.youtube.com/watch?v=xGRw...ature=youtu.be
    Rick
    Spyder Lovers Vendor
    Value-Accessories
    Dec 2014
    You shouldn't be paying any dealer anything for this fix on a 2020 RT as it's a BRP fix to a production fault. If you get charged your getting hosed. 3 of us had ours done this week at NO CHARGE by BRP dealer here in BC, Canada.
    Baja Ron sway bar.
    Ride Til You Rot!
    Danbury Connecticut
    I found a problem with Lamonsters fix.
    After a time, the mirrors start to shake again.
    The metal screws, threaded into plastic holes started to back out, loosen the mirrors thus allowing them to shake again, albeit far less than the original problem.
    I didn't think anything like Locktite would work, so I wrapped the screws with teflon tape, typically used to seal plumbing joints.
    I'll see if this holds up.
    IBA #47122
    Clinton, MS
    Maybe just don't run the tap all the way thru so that the last threads taper, forming a lock nut.
    Jul 2010
    Las Vegas, NV
    I’ll try my dealer, and see if they will fix it. They never did the F3T.
    Joe Meyer
    Durham,Maine
    Loctite or a dab of finger nail polish I would think may help
    2012 RTL , Pearl
    Aug 2012
    Central Coast, CA
    Quote Originally Posted by cptjam View Post
    Let us know what happens.
    2020 RTL SE6
    May 2016
    The kits can now be ordered from BRP dealers and are free of charge. Service dept. will install, takes 10-15mins. Bolts replace lower clips.
    Just had mirrors on my 2020 RTL upgraded - now rock solid!
    Durham,Maine
    Wow, every now and then BRP will own up to a screw up!!!! Good for you guy's!
    2012 RTL , Pearl
