Results 1 to 9 of 9
    Sep 2018
    VA
    Default Lower cable from helmet headset to Spyder
    I am looking for the short lower right angle cable extension from Spyder to helmet headset in the attached picture. If anyone knows where to find one or just what the part number is would be great information.
    I have been able to find it as a component to an entire helmet headset but not as a separate part
    Jan 2010
    usa
    What type of headset?? If you are using J&M
    https://jmcorp.com/JM-P-Series-Compo...ord_p_135.html
    When the going gets tough...Downshift..
    Idaho
    Quote Originally Posted by ScootRP View Post
    Is this a Can Am headset? Did you buy it new or did it come with a used Spyder? Depending on old the headset is it might be time to buy a new set. J & M has a good one.
    Show us a pic of the end of the cable so we can maybe identify it from the pin configuration.
    2014 Copper RTS
    Idaho
    I just did some more looking. It's a BRP headset - https://can-am.brp.com/on-road/us/en...set-wired.html. The instructions for its use will have the part number for the separate pieces, if they can be purchased separately. The BRP instruction web site does not have the instructions available so your best bet is to go see the parts guy at your dealership. If the instructions are available he should be able to find them and then order the lower cord for you. If that route dead ends then you'll need to replace the entire headset.
    2014 Copper RTS
    Sep 2018
    VA
    It is a 2015 RTS. The short 7-pincable is that old. The J&M headsets that plug into are less than a year old.
    Idaho
    So your headset is a J & M headset, right? Then you should be able to get the lower cord from them. If they don't sell it separately then you can buy both the upper and lower cord to plug into the block on your helmet. The downside may be that the straight connector they offer may run into interference with the handle bar. If that is the case, and you're handy, relocate the DIN connector toward the side of the bike somewhere. That will have the added benefit of getting the cord away from the glove box lid.
    2014 Copper RTS
    Idaho
    OK, after looking around some more and thinking about it what you have is a J & M headset with a straight DIN connector that you plug into the short lower cord. The short lower cord is essentially just an adapter so you don't have to plug the straight connector into the bike headset connector, right? So in that case your J & M cord will plug into the bike connector but interferes with the handlebar. Do I have it figured out correctly? If that is the case I suggest you relocate the connector on the bike from the switch cluster to the left side tupperware, something like what I have done.
    2014 Copper RTS
    Feb 2012
    Spring City,Utah
    It looks like a 5 pin din plug, so a computer store should be able to get you something that will work.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    I have one you can have however it is off my 2010 and not sure if it is 100% as shown in photo below. PM me your address if interested.
