PhotoShop Master
BACK UP BRAKE SQUEAK SOLVED .....
this morning backing out of garage i heard that bad brake squeak that we have learned to grow and love
I took a shot that pads were not seperating so i installed two small springs between brake pads on the caliper slide bolts .... so far no squeak and brakes are still functioning perfect ...i'll let you all know how it works out over time .
THOSE WHO LIVE BY THE SWORD DIE BY THE SWORD... BUT...THOSE WHO MASTER THE SWORD SURVIVE BY THE SWORD....
Rev. J. Proctor
reverendproctor.com
HAPPY SPYDER OWNER
Can I get a second moton for "genius"
2008 SM5, F1 EvoIII slide, Hindle, Race Air Flow System, O2 Delete, Fuel Pressure Modfier, Powerbus System, BRP 6 Spoke, 12V power supply x2, 1" Handel Bar Riser, CompuStar Alarm System w/pager, Mono Seat Cover, Brake Caliper Trim, Trunk Liner, Outdoor Cover, Carbon Fiber SM5 Handelbar Inserts, Carbon Fiber Tank Knee Pads, TBR Juice Box.
What brilliance of mind.can the spring get in a position to keep the brake from working?If not you need a patent lawyer.
You should sell your Brake Anti-Squeak kit on e-bay for $19.99 !!!
Number One: 2008 Yellow GS SM5. I love my Spyder.
Number Two: 2012 RT-S Limited (the poop colored RT) I still have Number One, but Some Girl made me buy Number Two...
SpyderLovers Founder
A good conversation it was over coffee. I will try it next.
2008 GS SE5 in 2008
Traded at 43,000 miles for a left over
2010 RT SM5 in 2011
Traded at 57,000 for a left over
2014 RTS SE6 in 2015, which has 35,000 miles
Oct 19th, 2017, totaled 2014 RT while killing a Javaline
Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
Never had any breakdown stranded issues.
PhotoShop Master
Put some miles on spyder today so far working like a charm been coasting backwards with engine off and I get no squeak and I see no way that the spring will interfere with the brakes at all did a lot of stop and go driving today so far works great I got an asortment pack of springs at home depot for like 6.00 and found two that fit perfect around caliper bolt and they were not too strong to keep pads from working hope my little fix helps all
Rev. J. Proctor
reverendproctor.com
HAPPY SPYDER OWNER
In no way is the CHAD just a FAD
Send the picture to BRP
Happy Owner
Chances are the referenced post is positive in nature, may result in a solution, alteration, modification, or highlights an extraordinary event or ride, that's worth posting.
pauly1 - SpyderDeb's 'wrench'
2018 F3-T & 2015 F3-S Road Warrior Foundation Tribute customs
IBA #48220 SS1000 BB1500
2015 F3-S , OEM na Basic Black with Custom Wrap
Brake squeek fix
Was it only your back brake that squealed? Or did you do the spring install on all wheels?
Motorbike Professor
Have you ridden with this in heavy rain yet? I am curious as to how it might affect the initial stopping in wet weather. One of the advantages of disk brakes is that they ride on the rotor, so are not easily contaminated or rendered less effective by moisture and crud (i.e., they wipe themselves clean constantly). This may still be close enough to do the job, but it does create a question in my mind. I still may try it for myself. Far less effort than completely removing the brake pads to apply Disk Brake Quiet.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Here is what I do not understand.....Dealer says the squeal is because of high metal content in the pads that is need to stop the spyder due to its weight. A Goldwing weighs in at over 800 pounds and their brakes do not make a sound.....
PhotoShop Master
thanks for input scotty ...yes i have driven in rain and stopping power is great still the spring is very light tension and pads are still touching rotor
Rev. J. Proctor
reverendproctor.com
HAPPY SPYDER OWNER
Motorbike Professor
Thanks. After I recover enough from next week's surgery to crawl around on the floor again. I may try this. Heck, if it is boring and cold this weekend, I may even get to it sooner.
-Scotty
PhotoShop Master
Rev. J. Proctor
reverendproctor.com
HAPPY SPYDER OWNER
How will we recognize it's a without the squeal ? we hope to do this too. Loved your runon commentary; sounds like something I would do.
Motorbike Professor
I am humbled by your trying something i came up with .....
all knowing master of cycles...
I did it this afternoon, oh wise one. No more school bus sound pushing it out of the garage or in reverse! It was a bit of a shock to have it push so easily, and to roll backward on a slight incline when stopped. I used a couple of 1/2"x1/2"x0.041" springs, stretched slightly since I couldn't find any just a bit longer. I had some thinner gauge springs the right diameter, but they were too long, and were too close to binding if the pads wore out for my comfort. I suppose I could have cut them down, but I preferred the finished ends on the whole springs.
On the minus side, the brake pedal is a little farther down than before, at full engagement. Makes it feel a tiny bit soft, since it is just the back. One additional pump and it is rock solid. Stops just fine, but I think my spring is a little bit strong, and is pushing the piston back a wee bit. 0.020-0.030" wire would have been better, but doesn't appear to be available. A 5/8"x9/16"x0.035" spring is available on the Web, and that might be just the ticket. That one is also available in stainless. I will revisit this fix after my surgery, when I have some slightly softer springs. Meanwhile, it takes the cake! Have yet to test wet weather performance.
I also applied CRC Disk Brake Quiet gel to the rear, cleaned the brake parts and pads, and lubed the appropiate places sparingly with CRC Disk Brake Caliper Grease. Still a tiny bit of typical squeak, possibly from the fronts. No worse than my BMW, not a squeal, just a tiny squeak if the brakes are applied lightly. So quiet I can actually hear the ventilation holes as they approach the pads now. Thanks for giving me the incentive.
-Scotty
Mod Maniac
ata = allergic to asphalt
My mods: https://www.spyderlovers.com/forums/...ead.php?t=5753
There are two kinds of people: (1) those who can read, reason and apply the experiences of others; and (2) those who just have to pee on the electric fence. ataDude, 2009
My Spyder:
Motorbike Professor
Originally Posted by ataDude
Guess I could have phrased that one a little better.
I will buy some new springs while I am recovering from my knee surgery, and install them when I can get down that low once again.
How's that? Then again, having the doc install new springs in me could be helpful...
-Scotty
Mod Maniac
Whew, Scotty, I was concerned. Those springectomies are really tough... I had heard it's best to have those while you're still <<ummm>> a spring chicken.
Good luck on the surgery!
My Spyder:
this will be next BRP recall....
Happy Owner
wd40 is magic
this is genius. But I havent had any problems ever since I sprayed WD40. works great no complaints..
Rear Brake Spring
Every time I parked my in my garage, the next day I would push out before starting and the rear brake would just howl like crazy, I would mess around with the rear brake by hand and some times it appeared to seperate the pads just enough to stop the howling, but would go right back to howling. I went to Home depot and purchased a $3.50 pack of springs, found two that were about the right size, would have to squeeze just alittle to get them in, but went in fine, not to stiff, and not to weak. After the install, like the other fellow showed in his pic, it worked instanley, and been riding for a week with lots of miles and no more rear brake noise, riding or pushing. another in expensive mod (like the truck spring and push button trunk light) that someone came up with that really works, and was nice enough to share it with all of us. Mod dose not effect the rear braking power in any way. My front brakes squeal from time to time. might try that mod on them too??........anyway thanks.
