Which direction to undo front sprocket bolt?
I even bought the shop manual and it does not say. I have tried the normal counter-clockwise direction and it does not want to budge. Before I try a little harder, I want to be sure that this isn't a left-hand threaded bolt? So counter-clockwise or clockwise to get this darn thing loose?
Also, I have 18,000 miles on mine, there's no hint at all of red rust. Maybe I should just leave well enough alone? I did get the Loctite Moly and was going to lube it up, but maybe I don't need to at this point?
Thanks!
Without knowing what spyder you have, you are correct, leave it alone.
It's a right hand thread and I would examine it, clean the splines and cover the them real good with the Moly Paste. Torque to 110 ft/lbs. I did not like the looks of the lube BRP used - it appeared to be just a white lithium grease. Maybe that's the cause of the failures?
My 14 has a lil dust but 41000 miles ....so if it's the same sprocket from 08' --whaaaats the difference now?
Sorry, it's a 2017 Spyder RT. I have 18,000 miles on it. There's not a trace of red dust to be found anywhere.
On the one hand I feel like taking it off and cleaning it and putting in new moly paste, but on the other hand, if there's no red dust whatsoever maybe it's best to just not F with it at this point.
Yep, keep it clean and keep an eye on it. Much luck to you with that issue.
Thanks!
Keep checking on it every few thousand miles, but, if it does not exhibit the red rust signs don't touch it. Why cause problems where there are none. At this point I believe that minor sighting of rust staining does not mean that you are facing imminent failure of the splines.
Is your '17 RT included in the front sprocket recall? If so, hang on till dealers get replacements.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
SpyderLovers Sponsor
Thanks!
Lefty loosie righty tighty
Yeah but I don't know if it's broke unless I pull it off and inspect it . Seeing as how I had no trace of red dust at all, I have not fooled wth it yet.
