Results 1 to 25 of 26
    Jul 2019
    AL
    Default battery needed - what's the best replacement
    guess i need a new battery,any suggestions on the best battery, Thanks
    Nov 2013
    Oro Valley Arizona
    OEM
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    OEM seems a good choice to me also.
    Sep 2014
    USA
    On my 6th year on my OEM battery
    Active Member RideOn's Avatar
    Sep 2018
    Bakersfield, CA
    I've had good luck with Yuasa in both Spyder and Harleys. I'm pretty sure the OEM is a Yuasa with Can-Am branding.
    The correct battery for most Spyders is the YTX24HL. Avoid any that have a -BS suffix, as that means you have to add the acid and charge. Otherwise, it is fully filled and charged at the factory. There is a battery finder on Yuasa's website: https://www.yuasabatteries.com/
    Generally these batteries are cheaper on Amazon, but not always.
    “There comes a time in the affairs of men... when we must seize the bull by the tail and face the situation.” - W.C. Fields
    2019 Spyder RT Limited - Asphalt Gray/Chrome
    1991 H-D Sturgis FXDB -- #684 of 1600 Limited Edition
    Gone but not forgotten:
    2014 Spyder ST SE5
    Steel Black Metallic
    2019 RT Limited , Asphalt Gray/Chrome
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Some will debate that adding sulfuric acid ensures a fresh battery, versus a factory filled battery.
    However, some factory filled AGM batteries are vacuum filled, which allows more absorbtion.
    Dekka took over H-D OEM from Yuasa, about 15 years ago.
    The difference between a Dekka battery and a Dekka manufactured H-D battery, is that H-D specified vacuum filled.
    However, I think most recent H-D batteries are no longer Dekka, as Sportster riders have reported a shorter battery life, the last couple years.
    Having Yuasa batteries in many (most) M/C, they have a good reputation, however, with good life reports from OEM Can-Am batteries, if price is close to same, I would go with OEM.
    May 2014
    Benson, NY
    Still on the original battery in my 2013.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Boerne, TX
    I will soon replace my 2017 battery on Mr. White. I change out my batteries every three years. Many do not agree but I don't want to get caught with a dead battery in far west Texas.....no cell service in some areas I ride....JMHO
    I also agree with Mr. White above. I came from Alaska. Same reasoning for why. Some things are hard to change.
    Sep 2015
    Chilliwack, BC. Canada
    I, personally, see nothing wrong with your reasoning. It may be a bit of over kill, but peace of mind is much more important.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Aug 2019
    Stoughton, WI
    Thing with batteries is that they can fail without any notice. I tend to replace my battery every (4) years. I'm perfectly content with Yausa AGM batteries.
    2022 RT Sea To Sky
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by SportsterDoc View Post
    The confusion with which is better factory filled or bottle filled on Spyderlovers is that the battery in earlier models of Spyders were on their side. The factory supplied battery was bottle filled. That looked like the best choice. Because it did not matter how long it took until the spyder was sold and prepped. The battery would be just like new. If the dealer did not take the time to properly prep the battery. Charge for 12 hrs upright with the caps off. Not all the air bubbles would come out of the glass mat and they would leak laying on their side in the Spyder. The damage that would create for BRP was big. Even though it was a dealer prep issue. So BRP went to a factory filled battery. Even though the battery starts to age once it is filled. Because of that on Spyderlovers it became the common believe that factory filled batteries were better. Not true. But that's the way it is.
    Jul 2011
    Quote Originally Posted by 3ntune View Post
    So I assume you had the battery load tested and it failed. If not. Then I agree you are just guessing that's your problem.
    This sounds like an excellent way to have a great battery .... but what if the NEW battery is defective !!! - it happens ..... then your Old battery that may have been very good is gone ..... just a thought ..... Mike
    Active Member ChicagoSpyder's Avatar
    Chicago
    Every 4 years is where I'm at to, and AGM for the win.
    It's the odds Mike, it's the odds
    2018 F3 Limited , Black/Chrome
    Aug 2019
    Stoughton, WI
    Fortunately, I never had that happen. That said, I buy my batteries locally as my old employer gives me great pricing. Returning not an issue. Now, out on a trip, that would be a PIA..
    2022 RT Sea To Sky
    Jul 2011
    I don't have a problem with changing out batteries at certain time intervals. If it give you peace of mind and in hotter climates it may be a good idea. But to think that a new battery for certain will be better than the old battery. Well that is probably likely true but you don't really know unless you do some testing and don't guess. I have had several new batteries fail in a short period of time. On the other hand I have had batteries last 8 years or more.
    The problem I have is folks changing out the battery for a new one when they don't really know it's the problem. It comes up on this board all the time. Almost any electrical problem question comes up. Someone will recommend putting in a new battery. So some folks do. So often the problem is not fixed. So money is spent on a new battery without fixing anything. So the new battery is run dead a bunch of times until the real problem is found and fixed. By then several years of life has been taken out of the new battery and maybe it should be changed again. If you think the battery is bad. Charge it. If it takes a charge. Load test it. If it fails replace it. If it passes. Something else is wrong and fix that. When that problem is fixed. Test the battery again. It could have been damaged trying to fix the other problem.
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    mine too. and still tests great.
    [joyce & irvin toms]
    Active Member thereverend's Avatar
    West Monroe, LA
    I use the one's that LaMonster sells above at the Spyder Store. The yellow one has 4 posts instead of 2.
    Sep 2014
    USA
    Quote Originally Posted by irvin48 View Post
    Mine tested good too. Got me one of them battery analyzer's. Battery Still showed good. So left in the Spyder.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by RideOn View Post
    There is a battery finder on Yuasa's website: https://www.yuasabatteries.com/ Generally these batteries are cheaper on Amazon, but not always.
    I just tried the Yuasa website search by vehicle tool. They don't list Can-Am. Am I missing something?
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    I searched by battery and found it under BRP snowmobiles...
    Anyway, ordered from Amazon - it was the best price at $93 + free shipping.
    2014 RTL Platinum
    Durham,Maine
    Quote Originally Posted by thereverend View Post
    X2, Motobat!
    2012 RTL , Pearl
    Active Member RULINGCHAOS's Avatar
    Oct 2022
    Sikeston, Missouri
    I noticed this listing on Amazon.
    https://www.amazon.com/Chrome-Batter...0-4513d670b6bc
    Says the battery is sealed and no acid is needed. It has the -BS on it. Is this still the case?
    2017 Spyder RTL
    Mods
    Baja Ron Swaybar
    Mesh Intake covers
    LED Skidplate
    LED Headlights and Foglights
    TricLED Dual Color LED A-Arm Running Light Strips with Blinker
    12V Cell Phone / GPS Docking Station with Dual USB Charge Ports
    Quick detatch backrest
    Show Chrome RT Trunk Rack
    Show Chrome Short Spiral Radio Antenna
    Custom Airbrushed paint with ghost flames
    Mar 2017
    Salisbury,NC
    Quote Originally Posted by RULINGCHAOS View Post
    you get what you pay for..................i wouldn't buy that cheap a battery. couldn't find CCA on info. i prefer BS tho, so i can fill myself and charge
