Results 1 to 11 of 11
    Aug 2016
    Calverton N.Y.
    Default Best wire connectors for LED lights?
    Looking for the best connector for LED lights.
    Thanks
    SoFlo
    The oem waterproof type are available and not expensive from Value Accessories. These work well and give an oem appearance while being waterproof.
    http://store.valueaccessories.net/Sp...onnectors.aspx
    Jun 2010
    Las Vegas
    Posi-taps
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    SoFlo
    Quote Originally Posted by SpyderAnn01 View Post
    Posi-taps
    While I like Posi-Taps for certain stuff, typically here in the tropics with humidity and rain, water gets into the Posi-Tap causing corrosion. Overtime the corrosion messes with the electrical circuit and often corrosion wicks up the wires length. They are quick and easy though.
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Like Anne said, Posi-Taps. To combat the humidity, I put a dab of silicon sealer on the ends where the wire goes into the Posi-Tap.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    SoFlo
    Quote Originally Posted by Grandpot View Post
    Downside of most silicone sealants is they contain acid that adds to the issues. Maybe consider non acid silicone sealant or silicone dielectric compound. Regardless, glad to read it works for you without issues.
    Aug 2016
    Calverton N.Y.
    Thank you. This is very helpful. Safe riding
    Jul 2010
    Las Vegas, NV
    They make waterproof positaps!
    Joe Meyer
    Sep 2017
    Durham,Maine
    and dielectric grease!!
    2012 RTL , Pearl
    Aug 2019
    southwest oHIo
    Quote Originally Posted by Rawspyder View Post
    Thanks
    All good points above, but I have to ask: are these decorative LEDs or high-power LEDs, like driving lights?
    The need for weather protection still exists, but I might use different connectors, based on light type and location.
    Sep 2014
    USA
    Delphi connectors work well and weather packs.
