Results 1 to 12 of 12
    Apr 2020
    Pennsylvania
    Default Rear Trunk Gas Shock
    My 2011 Spyder Rt Limited rear trunk gas shock won't stay up...best fix? and Go...
    Jul 2014
    Mint Hill, NC
    Read this thread and you can decide whether you want to replace the gas shock or add a second one to what you have. https://www.spyderlovers.com/forums/...as-shock/page2
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Active Member Bob L's Avatar
    Oct 2014
    Massachusetts
    Bob L.
    Worcester County Massachusetts
    www.rk-mass2.org
    Sep 2013
    Houston
    Why would you spend $35 for a stick to jury rig it when you can get a replacement strut and do the job right for $44?
    Just fix it right.
    Source for strut:
    https://www.amazon.com/gp/product/B01MDPI3O9
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Sep 2012
    Stetson, Maine
    I agree with jcthorne. I have that strut and it is much better than stock. It is a direct replacement.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Active Member rmag's Avatar
    Jun 2015
    miamisburg, ohio
    I have a first aid kit tucked up into the trunk lid which stresses the oem shock. I found a tent pole repiar kit ( roughly 12 dollars). Fiberglass rod cut to length with rubber ends propped in place to add support.... works great!
    2014 RT Limted, platinum, with matching 622 trailer.
    Ultimate tall boy seat w/adjustable back rest, Corbin armrests, Spyderpops bumpskid & missing belt guard, BRP side air vents, Lamonster lidlox, cargo nets, Stebel air horn, Wrap my spyder accents......and more
    Feb 2017
    Just fix it right.
    Source for strut:
    Why? It might be a case of to each his (or her) own. I disagree that the products Pierre sells are "jury rigged" to begin with, and can attest the product works reliably no matter what we put in the net on the inside of the lid or how much is strapped to the luggage rack on the lid. And, it will never lose its gas charge over time and sag or refuse to keep the lid open.
    I did replace the pneumatic struts for the saddle on both our Spyders and we're pleased that the saddle pops open when asked to even if we have gear strapped to the passenger portion. That is certainly an improvement.
    Apr 2020
    Pennsylvania
    I love the idea of the gas shock for $44....but installation? gulp.. not sure i am up for taking the bike apart to do so... tough install?
    Active Member juscuz's Avatar
    Dec 2015
    Virginia (US)
    Open Trunk, look at top inner rectangular panel where you will see three (if I remember correctly on the total) torx screws. Remove and push seat back forward. See, look, there's the bottom part of the strut, plain and simple. Take a small to medium sized flat tip screwdriver and gently insert and twist metal clip, strut will slip right off. Same procedure for top of strut mount. Nice to have a second pair of hands to hold trunk lid but can be done alone. Hope this helps, been a while.
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    There's mounts on both sides so you can put in two gas struts. That'll hold it up even with the luggage rack on.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Very Active Member Purple Guy's Avatar
    May 2013
    Edmonton Alberta, Canada
    Quote Originally Posted by Wahrsuul View Post
    This is what I did, carry a 10 lb rollbag when traveling and have had no issues with the lid staying open!
    2014 RT-Ltd , Cognac
    Sep 2013
    Houston
    Easy install.
