ipod/iphone
I have a 2011 Spyder Rt Limited & I am trying to use the cable coverter for the ipod. I bought an adapter that fits my iphone 8 so that when plugged in I can use the audio controls on the bike to go forward/backward on a playlist etc. When I plugged it in, I am in Aux mode and can only change the volume up and down. Suggestions?
Most 3rd party adapters do NOT work.
Did you buy a 3rd party or the certified Apple Adapter?
AJ
2014 RT-S
Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
a 3rd party
Which cable do you have for the input in the trunk, the one with a power box in the cable or the one that is a cable only? I believe the 2011 has to use the cable with the power box in it. Sometime in 2012 BRP changed the radio and the adapter cable so unless your radio has been changed out you need the earlier cable. I don't know if the wrong cable will block the controls or not. But your 3rd party adapter could very well be the problem.
2014 Copper RTS
We had 2 2011's (now down to 1) and they need the can am Din to Apple adapter that has the box on it... and then you need the Apple branded 30 pin to lightening adapter. Worked great like that with both of ours. On occasion it will still say Aux for a couple of minutes but eventually will kick over and say iPod. Not sure if it was something with the bike or the charge level on the iPod.
Can Am Part number is 219400187 if you need the one with the box on it. They are getting really hard to find.
Thanks...I do have the adapter with the box on it.. it must be the 3rd party adapter
The box one is ok and has a different name on it even though it is a BRP sold part... can't remember at the moment... the 3rd party part that causes issues for some is the apple 30pin to lightening... no reported issues with the Apple branded one. Some haven't had any issues with the aftermarket ones either, but some have.
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
