Results 1 to 6 of 6
    Jun 2020
    New Haven, CT
    Default How do I connect my phone to my 2014 Can am Spyder ST Limited?
    How do I connect my phone to the audio system and if I wanted to listen to radio, how do I search station by station as it only go the the set stations
    Sep 2012
    Stetson, Maine
    I cannot help with connecting the phone. To scan radio channels, hold down on either the right channel selector or left. Radio should start to scan. Good luck. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Jul 2014
    Mint Hill, NC
    Does your ST have the optional audio package? If so, begin at pg 29 of your operator's guide. My RT radio works as safecracker described.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Bossier LoUiSiAna
    May need add Bluetooth to ST stereo for phone. If is iPhone then u can use provided 30pin cable with adapter (proper apple adapter , others fail often)& will have ipod controls available. Or use headphone jack & only get to adjust volume
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Very Active Member Trbayth's Avatar
    Jun 2014
    Schenevus NY
    Looks like you got your ST used.
    There's a round, 5 pin connector in the frunk. New, the bike came with two cables: one that connects that 5 pin plug to an old-style 30 pin iPhone connector and one that connects that 5 pin plug to a standard mini-audio plug (for Android phones and other, non-Apple, MP3 players.) You can get those cables on Amazon.
    There are other options such as attaching a bluetooth adapter to the iPhone connector, or a Sena adapter (I believe Motorcycle Dave can hook you up with that.) But only if you have the iPhone connector, connected to an Apple device, will you be able to flip through music tracks via the left control pod.
    Other options are to use a Sena headset connected via bluetooth to your phone. The advantage there is you'll be able to make and receive phone calls while riding as well.
    Finally, if you didn't get a owner's manual with your ST, you can download it here: http://www.operatorsguides.brp.com/I...0-7fd63229ee0b
    Welcome to spyderlovers.com!
    Trb-- (Roger)
    2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    2022 White Pearl F3T
    Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
    Spyder States Visited
    Jun 2020
    New Haven, CT
    Thank you.
