Results 1 to 17 of 17
    Oct 2014
    Ohio
    Default Zumo XT will not connect with Garmin Basecamp
    Zumo XT will not connect with Garmin Basecamp on an Apple Imac computer...with Catalina OS...
    Has anyone had this problem ?? Its there a fix ????
    Mar 2012
    Beaverton, Oregon
    I use basecamp with my 590 an a iMac but do not have an XT! Would love one though but will wait for all the bugs to be worked out
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Quote Originally Posted by biker01red View Post
    Have you tried calling Garmin Support, 800.800.1020? I can count on fewer than five fingers a problem they couldn't solve in five years of working my Zumo 590 and BaseCamp.
    Greenville Tx
    Same problem here. Called them once and it still does not work. They just sent me some links they said were helpful. On my windows laptop it is just the opposite. I can connect to Basecamp but Garmin express will not recognize it. I did delete basecamp once and reinstalled it and It connected once after a long wait but It crashed and I never got it back.
    2017 F3 Limited
    Quote Originally Posted by AY4B View Post
    ...On my windows laptop it is just the opposite. I can connect to Basecamp but Garmin express will not recognize it...
    Have you deleted Garmin Express and reinstalled it? I've found that with both Windows 7 and Windows 10 Garmin Express is slow to recognize the connection, not really slow but not like flash drive quick.
    Greenville Tx
    Ill try that. I normally make all my routes on my windows laptop. I got the IMac to to make it easier but with Catalina, It has been a pain to do anything.
    2017 F3 Limited
    My son, a BMW Adventure rider, struggled with BaseCamp on an Apple desktop for a couple of years until he got so p o'ed he finally bought a small Windows laptop to use the program.
    Oct 2014
    Ohio
    I called Garmin Support, was on the phone 40 minutes with a Tech, he could not resolve the problem. Said he would set up a “Case” and an advanced Tech would contact me. Next day I got an email from another Tech stating the XT will not work on an Apple computer with Catalina OS !! Nothing ever stated in their ads or website about that. I am stuck with an XT I can’t use.. If I cannot find a cure for the problem,I will post the XT to sell !!! I have been a Garmin user for many years, never had an issue before.
    Oct 2014
    Ohio
    My issue is the same, the XT connects to Basecamp for about six seconds, then Basecamp shuts down. Did this several times with the Garmin Tech on the phone...problem not resolved
    Oct 2014
    Ohio
    Quote Originally Posted by bmwlarry View Post
    Do you have the Catalina OS on your IMac ?? If so, since the 590 works, I assume the 595LM would also work ?? If so, I might invest in one of them.. I can’t return the XT because I had already installed the mount and cradle on my bike..never used !!
    Active Member george123's Avatar
    May 2017
    San Antonio, Rogers Ranch
    I'm having the same problem. On my IMAC ( Catalina) I can connect Garmin Express to my XT and do the map updates, but it will not connect to Basecamp. On my 2012 MacBook Air ( Catalina) it will connect with both Express and Basecamp.
    When I do connect with Express on my IMAC, even though it works, Finder still shows no connection to the IMAC. I've about given up though on figuring out Basecamp. I can build a route quicker directly on the XT. The XT is great, much better, faster and brighter than my 660 was.
    2022 Spyder RT Limited Sea to Sky Mystery Blue
    Very Active Member tofriendscreek's Avatar
    North Central Arkansas
    Might it be suggested to stop using Basecamp and try a different routing program that works with Garmin, including the XT?
    2022 Plasma Red, F3 Limited, Special Series
    May 2017
    That was my point( indirectly I guess). I giving up on Basecamp and doing it on the XT.
    Quote Originally Posted by george123 View Post
    There are a number of routing programs available. There are also a number of threads on this forum about them. I have used myrouteapp for years and it’s great.
    Oct 2014
    Loudon, TN
    I use Mac OS Catalina (on a MacBook Air)and Basecamp with my Zumo 595LM regularly, never a problem connecting or transferring routes.
    2014 RTS SM6 , Cognac
    Greenville Tx
    Quote Originally Posted by Dgdecker View Post
    I also use my 590 LM on the iMac and it connects without issues. It even shows the mountains and hills where on my laptop it won't.
    On my windows laptop the only issue is the XT will not connect to Garmin express. I did the updates on it threw the iMac.
    2017 F3 Limited
    Oct 2014
    Ohio
    My experience is exactly the same. I will try building a route on the XT. I have not tried that.
