Results 1 to 11 of 11
    Dec 2016
    Nj
    Default When Mileage is very low--on a 2 year old F3
    Hello folks--
    only 2200 miles on my 2017 F3t (started riding exactly two years ago this month)--(hate cold weather and travel out of state alot)--anyway, the oil is only thing i check often and i will again but it looks very clean) and a year ago i believe my dealer gave a very quick look see when it was at the service dept for some cosmetic mods...question is since going on two years plus now--the work that would be performed at the 3k mile service (hopefully i hit the 3k by the winter this year) is there anything , other than the oil, that i should have the service department double check--just given that 24 months has passed notwithstanding the ridiculously low mileage--
    thank you in advance for your input
    Sep 2009
    La Valle, WI
    You need to change your oil once a year no matter how low the miles you put on. The oil breaks down over time. If you can't do it yourself the bike should be checked over annually.
    2018 F3 Limited , Oxford Blue
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Repeated condensation accumulation likely an issue
    2020 900 , NGK 4218 iridium CR8EIX Matte black
    Right on about the oil. For 1330 engines...of which the F3 is...oil should be changed at 3500 miles for the first change, OR, once a year whichever comes first. THEN, every 9500 miles or once a year, whichever comes first.
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    Pete!!!
    I'm gonna hafta ride out your way with Janis one day soon and help you put some miles on that ryde!
    In the meantime, ryde safely
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    2016 ST-S , Steel Black Metallic
    Bossier LoUiSiAna
    Quote Originally Posted by JP58 View Post
    the service mileage are just minimal estimates, you want it to operate minimally? also try keeping good log of what was checked when. Might end up double checking few items np till you put something back wrong consider Birthday inspection kinda like the Dr does physicals
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Jul 2016
    australia
    Brake fluid due every two years regardless of kms.
    Dec 2016
    Nj
    hey rich--yes that sounds awesome--hope you two are well
    Active Member Joerolwing's Avatar
    May 2016
    Nashville, TN
    Is degradation of oil an issue with fully synthetic oil also, or is condensation enough of an issue by itself?
    Jul 2017
    FL
    My understanding is it's not the oil itself that breaks down over time, but it's the additive packages (corrosion inhibitors and things like that) that become less effective once exposed to the elements. So a sealed container will last "forever" but once opened and put into an engine it should be changed yearly.
    Aug 2007
    Greeneville, TN
    All good boiler plate information. But I have to say that my Spyder sat for over 3 years. The oil had about 3.500 miles on it when I parked it. When I got it going again, I put about 500 miles on it and then had the oil tested. Came back with flying colors! All parameters way above the safety margins. And I live in a relatively high humidity area (east Tennessee). I use Amsoil, which is well known for longevity and ability to prevent any rust or corrosion.
    I am not recommending this to anyone. Just recounting the experience. The results surprised me too!
