Results 1 to 14 of 14
    Active Member thunor's Avatar
    May 2015
    Lyons, NY
    Default Overheating problem on 2014 RTS
    End of last year and start of this season I have been having overheat problems when idling. Fan kicks on but it appears to not be cooling it off enough as the Overheat light will come on. Zero signs of
    any leakage anywhere. I am scheduling my springtime oil change and will probably get them to look at and fix it. This is only a problem when idling still or cruising at 5 mph or so. RTS is about to break
    39,000 miles. Was a 2014 leftover bought in the summer of 2015 so I have put a lot of travel into it. Hoping to get a lot more out of it still. Looking in the book it shows that the filler/level indicator is
    supposed to be behind a panel in my frunk but where it shows a rivet connector to open to get to it I have a fuse panel cover(right and left). Below those it has torx screws to open the next lower panel so
    it is not the indicated rivet. What am I missing(no jokes please, lol). Not ready to trade up yet as I want to buy new when I go south in another year or so.
    Thanks for any directions to look at with this.
    1984-87 Kawasaki GPZ750(1983)
    2011 Kawasaki Vulcan 800(2005)
    2012 Victory V92SC(2009)
    2013 Harley Davidson Road King(1999)
    2015 Can Am Spyder RT-S SM6(2014)
    2014 RTS , White
    Check to see if you have a good seal on the radiator cap. We had overheating on on 2011 and that turned out to be the solution. Just tighten the cap.
    Jul 2014
    Mint Hill, NC
    Shine a flashlight into your grills and you will be able to see if you have an accumulation of bugs on the radiators. If you've been riding in big bug country that could be the problem.
    If you open your frunk and remove the right side black plastic panel with a laptop embossed on it and held in place with one push pin you will see the coolant tank. You can also see the lower portion of the tank by looking upward from behind the right wheel shock absorber. If you then shine a flashlight on the coolant tank from below you can see the coolant level in the tank.
    Did you have the coolant changed at 28,000 miles? The service schedule says 28K or five years, whichever comes first.
    If you find excessive bugs in the radiators, after you get them cleaned out go to Spyderpops and order a set of KOTT (Keep Out The Trash) Grilles. They are the best method to keep radiators clean and they add a touch of class to the look of your Spyder.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    May 2015
    Lyons, NY
    I will check out both when I get home from work. Thanks. Been out of warranty for a bit now but if due
    a coolant change then probably a good time to do it.
    2014 RTS , White
    Sep 2016
    Chillicothe, Oh.
    I believe the RT has two cooling fans. Are both fans operating?
    2015 RT , Black
    Mar 2019
    NEBRASKA
    Following
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Dec 2013
    Quote Originally Posted by thunor View Post
    Only if you do the drain, flush, refill bit yourself, DO NOT try to open the drain tap!! They've been known to seize & when twisted in an attempt to open, snap right outta the tank!
    Undo the bottom rad hose instead!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Sep 2012
    Stetson, Maine
    I have found the easiest way to unscrew and add fluid is to remove the tupperware around the headlights. This gives you more room. You do have to remove mirrors and wind deflectors and upper side panels. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Jun 2010
    Las Vegas
    Jay has a good suggestion, on my 14 RTS I had overheating issues twice and neither happened at home in Las Vegas. Once was in Alaska and the other in Quebec both times I had ridden on wet, dirt roads. I was at BRP Homecoming when it happened and they replaced my radiators as it was like concrete had formed in the fins.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Nov 2013
    Oro Valley Arizona
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    SoFlo
    No coolant drain on these models as in previous years. You must remove the radiator hose. Radiator has the boss molded in for a drain, but they never final machined or installed them.
    Mar 2013
    I agree with Jay and Ann.
    Had this issue with my 2015 F3. Found my radiators 80% plugged. I had to remove them in order to clean them. Took 5 hours just to get them unplugged from all the dirt and bugs packed in the cooling fins.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Nov 2012
    Pueblo Colorado
    One of the bigger issues if you put a lot of highway miles on in "Buggy" country. Even the look of the new 2020 RT shiny radiators facing right into the breeze makes me anticipate the plugging problems down the road.
    Grilles help somewhat, but still a problem on our bikes at 50,000 miles plus....
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    May 2015
    Lyons, NY
    I only had enough time last night to check the level(eyeball) in the overflow tank and saw nothing but didn't get to throw a flashlight under it.
    I can only assume that both fans are going as it is very loud when they kick in. As long as I am driving about 20 mph or higher my temp is sitting
    around the 3 bar level...even with extended ride.
    Having most of mileage be in the Upstate NY region...bug build up is a very likely possibility...they might as well be birds. I will check that out as
    well.
    2014 RTS , White
