Results 1 to 7 of 7
Thread: RT Windscreen
    Active Member Garf's Avatar
    Oct 2017
    Ortonville, Michigan
    Default RT Windscreen
    I've always thought it would be nice to be able to raise and lower the power windscreen
    on my 2017 RTL without having to start the engine. ie: for cleaning purposes.
    Does anyone know of a way around this?
    Thanks in advance.
    Gary
    2017 RTL Asphalt Gray Metalic
    1987 BMW K75s
    Mar 2013
    Maumelle, AR
    I don't.
    2020 RT Limited , Chalk
    Active Member MeudtPG's Avatar
    Aug 2018
    Monroe, WI
    Wish we could update 2018 RTL windshield to the new 2020 RTL automatic memory windshield. Anyone know what this would take to add in the software?
    Ride Safe!
    "BLUE STAR – She shines so brightly"
    2018 SPYDER RT LTD SE6 BLUE/CHROME
    2018 RTL , Large Brake Pedal (cut 1/3 off). Oxford Blue/Chrome
    Jul 2014
    Mint Hill, NC
    When you finish a ride, before you turn off the engine raise the windshield. Then it's done, so anytime you want to drag out the cleaning gear the bike's ready for you.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Feb 2020
    N. Wilkesboro, NC
    Quote Originally Posted by MeudtPG View Post
    Ride Safe!
    I'm guessing that's part of firmware update 30.7 that's ONLY for the 2020s.
    Danbury Connecticut
    Ride Safe!
    I have the 2020 RTL. I have that feature. It's OK, but it's not a big deal, at least for me.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Idaho
    Quote Originally Posted by Garf View Post
    Thanks in advance.
    I would say your chances of doing that are somewhere between zero and none unless you're an expert at hacking computers. The windshield motor is controlled by the windshield and parking brake module. The commands to raise and lower are digital commands from the left handlebar switch module sent via the CanBus. Part of the signaling system is a signal from the ECM that the motor has started and reached 900 rpm. You would have to change the the computer program in the WPM and ECM, and maybe other modules, to change the restriction of having to wait for the engine to reach 900 rpm.
    2014 Copper RTS
