Results 1 to 24 of 24
Thread: Super Visor
    Aug 2019
    WI
    Default Super Visor
    I have been riding for over 50 years. I would not ride without a Super Visor on my helmet.
    I have no connection with this company.
    12tree
    Jul 2018
    Fountain Hills,AZ
    I like it!! Do you have a link?
    Feb 2020
    N. Wilkesboro, NC
    Feb 2020
    N. Wilkesboro, NC
    Quote Originally Posted by 12tree View Post
    I told a former boss that I was tired of having a Super Visor riding my *** all the time. He told me if I continued w/that attitude I would have no connection with that company.
    Dec 2019
    Land of Lincoln
    My Super Visor rides behind, and yes we do go and do what she says.
    SWMBO She Who Must Be Obeyed
    Nov 2018
    Claremore, Ok.
    I just ordered one.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Sep 2019
    WI
    Since I seldom ride with my faceshield down i just put a two inch wide band of black tape across the bottom and use that as a visor.
    Feb 2019
    Portland, Oregon
    I place a strip of black electrical tape across the top of the drop down visor. Works great and the price is right! If I want the shade of the drop down visor, but a greater view, I raise it a wee bit until the tape is above my field of view.
    May 2017
    Mesa, Arid-Zone-A
    That is exactly what I do. Two strips of electrical tape nicely trimmed. It looks like it belongs and is very effective..... Jim
    Semper Fi
    Dec 2015
    Oakley Utah
    I have been riding for over 50 years. I would not ride without a Super Visor on my helmet. I have no connection with this company. 12tree
    Not for modular helmets, unfortunately.
    2014 RTL Platinum
    Active Member Grayfox's Avatar
    Nov 2012
    Advance n. c.
    Have had one for several years
    Mar 2015
    forrest above Reno, Nv
    Have done the tape trick for years with both full face and modular helmets.But the air scoop that redirects more air to the helmet vents is good, Right Pete???
    2014 RTS , Circuit Yellow
    Sep 2009
    La Valle, WI
    Website has no video. How and where does it attach. Helmet or shield?
    2018 F3 Limited , Oxford Blue
    Active Member ozarkryder's Avatar
    Nov 2018
    Anderson Missouri
    Had one of these on 2 former helmets. They work well on helmets on which they fit, unfortunately they don't work with our present lids, I've gone with the black tape strip. I got mine from Aerostich Rider Warehouse - they are apparently not in stock now, but there are still a lot of reviews and use tips. https://www.aerostich.com/supervisor.html
    2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
    Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
    2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
    Oct 2015
    Lynden, WA
    Bought a visor today. It attaches to the shield and works with modulars.
    I have used tape and am not satisfied with the tape results.
    The air flow of this visor sounds like plus to me.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Jun 2013
    So Ca
    Purchased one to try.....!
    Aug 2019
    WI
    It mounts to the face shield. I have had mine on a HJC IS Max modular. Before gluing in place, tape it on and ride toward a setting sun. Adjust as needed as the sun gets lower.
    When satisfied, glue it in place. I had to use the provided clips for my HJC IS Max. I have used a product called Shoe Goo as the adhesive and it worked well.
    12tree
    Oct 2015
    Lynden, WA
    My new Super Visor got a real, straight into the rising sun, test this morning.
    It worked great.
    GMax54 modular helmet.
    Super Visor is attached to the shield with the mid level mounting clips.
    David C
    2016 F3T
    Rear IPS Pack Rack
    Aug 2019
    WI
    One more comment and then I will let it rest. Putting black tape on your face shield is not anything like using a Super Visor. I've done that too. It is not even close. When you put tape on your face shield the sun is still shining and glaring on your shield. A Super visor puts your face shield in the shade. The next time that you are riding into a low sun, put your hand up so that you shade your face shield. You will see the difference. Be safe. Have fun. 12tree
    May 2019
    New Mexico
    A visor might be just the trick for that last 40 minutes before sunset. For me though, in bright sunlight, nothing beats a tinted and mirrored face shield. Out here in the arid plains - it's a necessity.
    Sep 2017
    Durham,Maine
    I am going to look into this for my snowmobile helmet! Thanks!!!
    2012 RTL , Pearl
    Riding with a visor is a must for me. We have helmets (Nolan and Bell) with the inside drop down sunshades, but they don't quite cut it for us.
    The latest Nolans have an adjustable visor that drops down a little more than the Bell which is permanantly affixed.
    I do like the one you posted about...but so far, am happy with what we currently have.
    Active Member INfox's Avatar
    Jun 2017
    TX
    My little two cents:
    electrical tape
    I tried that, looked perfect, but it “shrinked” and pulled off on sides. After that it looked really bad.
    modular helmets
    We had the Visor on our old modular helmets, got Shoei Neotec 2 two years ago and new Visor’s again, can’t ride without them once we got used to them, especially in the Spring and Fall.
    The Visor attaches to the shields, not the helmets.
    2017 RT Limited Asphalt Grey with Lamonster RT Spyder Cuff; Lamonster FBB Highway Bracket; Kuryakyn 7597 ISO Trident Pegs; RoadSport Big Mudder Extreme, Magic mirrors, Airhawk R, plastidipped Frunk, Ram Mount Universal X-Grip IV Large, FZ-1 fuze block, Dual USB charger, BajaRon Sway Bar, Black Powder Coated RT Dash Mount Bracket
    Nov 2018
    Claremore, Ok.
    Quote Originally Posted by Revalden View Post
    I just ordered one.
    I bought one but it won't fit any of my helmets.
    Tag-Along trailer
    Garmin 396 LM GPS
    New Banshee AGM
