Results 1 to 17 of 17
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    Default OMG another tire thread sorry
    Hi I've got a 2014 RT LTD and I have the stage 2 flash. What tire does anyone recommend for the rear that will get better traction due to the increase in power with the flash. It's getting close. I already have 2 new front tires to put on. Thanks, Mike
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Sep 2014
    USA
    I am out on this one , as you probably know where this will go and which tires will be mentioned.. Good Luck!
    Quote Originally Posted by wmh9680 View Post
    The Q-5 probably has the best traction , but I wouldn't discount the Altimax RT43 ..... it would be close ..... Mike
    Member 101stVet's Avatar
    Dec 2018
    Blairsville, GA
    +1....Q5's
    Aug 2019
    Stoughton, WI
    Bought this one and really like it. Speedo pretty much dead nutz on..
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2022 RT Sea To Sky
    Active Member DougE's Avatar
    Dec 2019
    Cambridge, Ohio
    I went with the Yokohama Advan Fleva 205/55R15. Traction is a lot better than the stock Kenda.
    2013 RTS
    M2 Shocks
    Yokohama Advan Fleva 205/55/15
    Vredestein Quatrac 5 175/55/15
    Viair 97
    2013 RTS , Quantum Blue
    Nov 2015
    Tinley Park, Il
    WHO MAKES/SELLS THE q5 AND IS 205/55R15 THE CORRECT SIZE, THANKS MIKE SORRY 4 THE CAPS I'M NOT YELLIN JUST FORGOT AND TOO LAZY TO TIPE AGAIN
    The Q-5 is the Quatrac 5, and is made by Vredestein, ... the sizes available are 205/60-15 and 205/65-15 ..... both will work for any Spyder ..... folks here have bought from these three sellers ...Tire rack , Simple tire, and Vulcan tire .Mike .
    Nov 2015
    Tinley Park, Il
    Thanks Everyone
    Aug 2012
    Central Coast, CA
    That is my favorite so far too.
    2020 RTL SE6
    Mar 2008
    Hesston, PA
    This will be my next tire also, it will replace my Michelin Hydroedge...
    SoFlo
    You might consider searching for a performance tire vs a touring tire, since you are wanting more grip.
    Aug 2012
    Central Coast, CA
    Even though it's rated as a touring tire made with a relatively long lasting compound I found it to handle and grip quite well, much better than the on paper status would indicate.
    2020 RTL SE6
    Houston
    If its dry traction you are looking for, you will be better off with the Yokohama Advan than either of the station wagon tires mentioned above from Vredestien or General.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Nov 2015
    Tinley Park, Il
    I might even think about dismounting and mounting it myself if I'm too bored
    I don't know that you can find any car tire that won't break loose if you really goose it! There just isn't enough vehicle weight on them to make them stick tight. I've used the Michelin Hydroedge, the General RT43, and now the Cooper C5 Ultra Touring. They all have broken loose on damp pavement and dry pavement.
    Member Possumchaser's Avatar
    Mar 2020
    Alma WV
    Hi Mike, could you tell me more about the stage 2 flash? Does it wipe out stock programming, nanny, etc.? I'm looking to get my 2012 rt roadster reprogrammed but don't know where to send it. Thanks, Corey
