Results 1 to 8 of 8
Thread: Turn Signals
    Apr 2019
    Mi.
    Default Turn Signals
    I have a 2019 F3t and I'm not sure about how to work the turn signals. They work just fine in either direction and go off after a turn. But if they get switched in either direction by accident and I want to switch them off I'm doing something wrong. As I read the owners manual all you need to do is push the switch in. When I do that it either goes in the other direction or nothing at all.
    I realize this isn't a real big deal but it's just aggravating.
    May 2019
    Port St. Lucie, Florida
    Yeah, I had the same problem. It has taken me quite a while, but I have finally developed the right touch. It does cancel them, but it isn't as easy as my Gold Wing was. When you push, it just has to go straight down, and not too hard. Keep trying.
    -Carsong
    2018 F3t
    2018 F3T , Position 5/ full size Matt Black
    Quote Originally Posted by carsong View Post
    .... the switch seems to have very fine line between on and off ..... the slightest variation from " doing it perfect " will get the wrong desired result .... Mike
    Yes, a common problem. There is a fine line where the self cancel works/don't work. A straight push is required. Any deviation one way or the other will mess you up.
    Dec 2014
    NY
    A quick "double push" seems to work best for me.
    Mar 2017
    Quote Originally Posted by johnny pop View Post
    Feb 2020
    CT and ME
    Being a newbie, first ride I found that cancelling the turn signal was a pain. Then I found out that you have to push IN the switch, not try to push it side-to-side to cancel. It's pretty firm too.
    2020 F3S-SS , Titanium/Black
    Jun 2011
    Kerrville, Texas, USA
    Thanks for that tip -- I'm going to have to try it next time on the road, because after 2+ years, I still have to check to make sure I'm not broadcasting "I'm an idiot, I'm an idiot..." after a lane change.
    Regards,
    Bret
    2017 RT-S Orbital Blue
    BajaRon Anti-Sway Bar
    SpyderPops LED Bumpskid, Spyclops II LED, Full View Turn Signals & Belt Guard
    Sena 20S Bluetooth Headsets
    Brake Free Helmet Light
    FOBO Bike for Trike
    Rugged Geek RG1000 Safety Plus Jump Starter/Air Compressor
    Lamonster RAM mount/Techmount TechGripper
    Drink2Go Cup Holders
    UltraGard Half Cover
    2017 RT-S , Orbital Blue
