Page 1 of 2 12 LastLast
Results 1 to 25 of 48
Thread: Tire balancing
    Dec 2012
    fargo, north dakota
    Default Tire balancing
    Is it necessary to spin balance the front wheels of the syder and can any tire shop do it??
    SoFlo
    I believe opinions and comments are going to vary a bit.
    Some will insist on Road Force balancing. Others Dynamic balancing. Others will say install tire goo and others insist on balancing marbles. Some may even suggest static balancing without spinning.
    Our fronts I dynamically balanced with weights on both lips of the wheel flanges. No vertical imbalance or precession wobble.
    Sep 2014
    USA
    Unless the tire shop has a small hub for there machine they may not. I bring my own hub adapter for the tire place to balance my tires.
    Nov 2018
    N.E. Ohio
    I use Dynobeeds (sp), tiny white ceramic beads. No marring the rims, no glue to clean up, no liquid mess, and even took the 40mph no hand shimmy out of my Goldwing F6B. cueman
    Nov 2016
    Upstate NY
    I also use balance beads. Ride is smooth as glass
    2021 Sea to Sky RT , Highland green
    Active Member DougE's Avatar
    Dec 2019
    Cambridge, Ohio
    My local tire shops machine worked on the fronts, but not the rear.
    2013 RTS
    M2 Shocks
    Yokohama Advan Fleva 205/55/15
    Vredestein Quatrac 5 175/55/15
    Viair 97
    2013 RTS , Quantum Blue
    Active Member upsdoctor's Avatar
    Mar 2010
    Derry, NH
    trikemutha, where did you pick up the hub adaptor? I would like to pick one up. Not sure what one even looks like
    Bob H - Derry, NH
    2020 Spyder RT Limited - Petrol Metallic Blue
    2010 RT622 Trailer and BRP Hitch
    BRP Vented Touring Windshield, BRP Backrest
    Garmin 590 with BRP Mount
    Fobo TPMS for Spyder and Trailer
    Lidlox, Blue Sea Fuse Box for power distribution
    Ram Ball Mounts for Radar Detector, Cup Holder and Phone Holder
    Sena 20S / SL2 Headsets, Foam Grip Covers, Belt Tensioner
    BAJA Ron Sway Bar and Shock Adjusters, Heli Bars
    SoFlo
    Quote Originally Posted by upsdoctor View Post
    Truthfully, if you have a quality tire shop you plan to use, bring both wheels over. If they can fit them on the machine correctly, have them balanced. If the machine is not able to fit the wheel, get the brand and model, plus spindle size. Ask the shop if you bring the correct adapter will they then balance the wheels for you. The shop itself may wish to purchase the adapter themselves.
    My Snap On balancer fits the fronts easily, but not the rear. Even able to dynamic balance the RT622 trailer wheels.
    Oct 2016
    Sebring, FL
    I had great success with "Ride-On" in my GW tires, but have been reluctant to us it in my RT tires.
    Aug 2019
    Stoughton, WI
    I put the auto formula in my F3-S car tires. Working wonderful..
    2022 RT Sea To Sky
    Active Member nightcruiser's Avatar
    Feb 2019
    Indiana
    I changed all my tires recently and added RIDE-ON. plugs holes and balances tires. Doing great so far.
    Mar 2010
    Derry, NH
    Has anyone used RIDE-ON with FOBO TPMS sensors installed? The factory recommends that the sensors are hermetically sealed.
    Bob H - Derry, NH
    Apr 2020
    North Myrtle Beach
    Quote Originally Posted by cueman View Post
    I bought a bunch of Balance Beads several years ago. I "Tried" removing the Schrader Valve and pouring them in (like the Seller said) and realized, "THIS AIN'T HAPPENING".
    I guess the Easy Correct way is breaking the tire loose from the rim and pouring them in? How much did you put in your tires?
    Quote Originally Posted by FastOldGuy View Post
    I think the BEADS come in different sizes, so possibly the ones you have are too large for the valve hole...... good luck ..... Mike
    Oct 2016
    Sebring, FL
    I never was a fan of beads, used Ride On with previous trike, worked well.
    Nov 2018
    N.E. Ohio
    . The easiest is when you are replacing a tire. On my GW it is suggested to use 1oz. Front tire and 2oz. in rear tire. When the tire changer has the new tire pushed down on rim take a cigarette paper with the beads wrapped in it and drop in the tire before the top tire bead is seated then air up as usual. The super thin paper will break open and disperse the beads. Easy Peasy! cueman. PS, on the oz. per tire I was relying on my memory, may or may not be correct. Read the instructions as per tire size as to how many oz.of beads needed.
    Last edited by cueman; 04-28-2020 at 08:54 PM. Reason: Not positive on oz. per tire.
    Sep 2014
    USA
    2 oz front 3 oz rear now that was with counteract beads.
    Nov 2018
    N.E. Ohio
    Basic rule of thumb, with in reason, is if you need to add more, do it. I’ve had to add more in my Ural tires. YMMV cueman
    Dec 2018
    Blairsville, GA
    2oz front, 3oz rear
    Just had Q5's front tires installed. Used 2oz of 2mm ceramic beads bought off eBay from seller that sells by the ounce....with 10oz minumin @ 1.29 per oz.
    eBay item: 263127057584
    Much cheaper than Dynabeads and they work fine.
    In fact, talked with new Spyder rider on how to improve handling and tracking. Told him, IMO 2 improvements need to be done....laser alignment and sway bar.
    Now I would include new Verdestein tires front and rear. Unbelievable difference in ride and handling
    Note: IF you prefer brand Dynabeads and purchase from eBay....pls be careful on pricing. Many offered at unbelievable high prices.....buyer beware.
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Only one way to go Centramatic wheel balancers
    SoFlo
    Quote Originally Posted by RudyB View Post
    Absolutely not true, there are other proven ways to obtain balance of a tire.
    Oct 2016
    Sebring, FL
    Mutha, did you do the bead application with the tires on the machine? That rear looks like a real bear to get it done on the Spyder, hard enough just getting air in there.
    Sep 2014
    USA
    The wheel balances didnt work for me and had them balanced several times. Finally found someone who knew how to use a road force balance machine.
    Sep 2014
    USA
    Yeah had the tire off and just before I put it back on the wheel I dumped the beads in first. They are a PIA to put them in thru the stem, even with the wheel off the Spyder to get them in the stem.
    I prefer a long stem fill nozzle makes it easier for me. Also have a London sten digital pressure gauge.
    Oct 2016
    Sebring, FL
    So, are you using the beads in addition to the 'road force' balance?
