Results 1 to 20 of 20
Thread: Tire kits
    Active Member Lehrman's Avatar
    Feb 2020
    Violet, Louisiana
    Default Tire kits
    Any advice on what to carry for long trips in regards to tire repair? Considering tire slime, mushroom plug kit, mini compressor etc. Should all of these be taken? If not what is your recommendation? Also, which specific brands are the best in their respective categories?
    Sep 2016
    Chillicothe, Oh.
    I put together my own kit for my bikes. I bought a package that included the good old fashioned string plugs and the tools to install them. I have a small SLIME mini compressor. These have served me well the couple of times I have used them. Some like the mushroom plugs, but I had a bad experience when I picked up a large screw and the mushroom plugs were worthless. That's when I switched to the string plugs and never looked back.
    2015 RT , Black
    Florida Swamp
    Plug kit and COČ cylinders.
    2019 F3-S , Black & Silver
    Mar 2015
    forrest above Reno, Nv
    Thumbs up Extra CO2
    Quote Originally Posted by Gwolf View Post
    +1 with extra cylinders. Takes up almost no room in the in the frunk.
    Lew L
    2014 RTS , Circuit Yellow
    Northern Kalifornia
    I have the exact same kit and components on my spyder. After having used both plugs and strings over the years on car tires, I tossed the plugs and went with all strings. Truthfully it's a 50/50 shot with plugs or strings. Strings are easier to replace if one or two don't work the first time. Just add more. I've never had to (knock-on-wood) plug a bike tire. All my experience has been with trailer tires in the backcountry.
    Active Member MrMagicFingers's Avatar
    Apr 2020
    Dartmouth, Nova Scotia, Canada
    I have the "Slime" air compressor that I carry with me on the Goldwing. It's small in size but appears to be a good compressor in what few times I have used it. I do not used the slime. The bikes rims are aluminum and the slime will corrode aluminum easily over time. Plus when you do go to replace the tire you have an awful mess on your hands. I have gotten a chemical burn on my hands before using that slime.
    Instead, I use the traditional rope plugs. I have plugged 2 motorcycle tires in the past without issue with rope plugs and they have remained in the tire under normal use for the duration of the life of the tire. The flat footed Spyder tires should be no issue I would think.
    Tim
    Current - 2010 Spyder RTS
    1) Experience is something you don't get until after you need it.
    2) A closed mouth gathers no foot.
    3) IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU HAVE TIME TO DO IT OVER??
    ___
    Horsepower is an illusory mathematical equation; Torque is REAL, and is the source of all good things in the world.
    The problem is not the problem. The problem is your attitude about the problem. Do you understand?
    Please check out my pics!!
    Member glorybiz's Avatar
    May 2018
    Ellicott City, Maryland
    I used the co2 but found they run out very quickly so I got a small compressor instead along with the plug kit
    2016 RT Limited , stock yes red
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    How many CO2 cylinders are needed to inflate a rear tire on a Spyder?
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Florida Swamp
    Go to a place that sells the COČ for pellet rifles. They have all different sizes. The big ones will do it.
    May 2018
    millsboro,delaware
    Ive got plugs,strings,mini compressor.I bought most of it from the for sale section on here and it takes up very little space.BTW I had heard some of these pumps overheat and fail quick so I tried it on a deflated truck tire and it worked well and didn't get hot so I think Im ok.
    : 2017 RTL ORBITAL BLUE
    Jun 2010
    Las Vegas
    We carry a compressor from www.aerostitch.com. Works great, and it is small and priced around $50, it has never let us down and it has been used a ton.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Aug 2019
    Stoughton, WI
    Here's my $8 emergency tire repair kit. Mini compressor (Walmart) $5 + ebay tire repair kit ($3). Peace of mind.
    2022 RT Sea To Sky
    Florida Swamp
    The compressors are fine, but the F3-S has very limited storage, which is the reason I carry the COČ. If I had more room or if I was carrying a large bag on the pillion, I would probably carry a compressor too.
    Feb 2020
    N. Wilkesboro, NC
    troop---Is that BACON I see (left side)??? It IS bacon, isn't it? Bacon is great to eat during any roadside repair stop. (Or any other time, of course.) Tell me it's bacon. #baconrocks #ineeddeadpig #ivebeencoopeduptoolong
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by MONK View Post
    Come on man Tire plugs, but yeah, I see the resemblance
    2022 RT Sea To Sky
    Aug 2019
    Stoughton, WI
    I always travel solo. When I travel, I have my frunk, Shad luggage and a bolt on/lockable storage box on the passenger pillion. It measures 23" L x 12" D x 13" H. It holds my traveling tools/rain suit/snacks. Crap load of storage for one
    2022 RT Sea To Sky
    Active Member shakin_jake's Avatar
    Nov 2011
    north central Fla.
    For those of you putting together your first tire repair kit, one item I haven't seen mentioned yet in this thread but I consider it essential to have and use, and doesn't take up much space-& for those concerned about keeping your kit light and small...like the peeps that cut their toothbrush in half to save space in their trail kit bag, make sure you take along a single edge razor blade. It's used to cut your tire plug flush with your tire thread. If you leave excess plug exposed especially the string plugs & they're my choice as well, that part of the string plug above the tire tread can catch the road with each tire rotation and the plug can work itself out of the tire, so carry and cut off the string above the tire tread flush using your SE (single edge) razor blade
    One more thing...if you've never repaired a flat tubeless tire using the string/rope type repairs, get a car tire mounted on a rim full of air and practice on that. A junk yard will sell you one inexpensively. The tire doesn't have to have a lot of tread left, you just want something that will hold air then use a hand drill driver with a small bit to put a hole in the tire and plug away!
    It would be very prudent for you to wear a pair of safety glasses when puncturing the tire. Have fun with this as you learn this essential DIY repair!
    Not that anyone asked but the last time I plugged a tire on the road was at a WeSToc rally in southern BC (Kimberly). Actually, the tire was plugged (on a fellow SToc'ers Honda ST1100 in the neighboring province to the east. You Kamloopers know where I'm talking about. It was in that town by the park there, before Lake Louise. At the time, no one had an air source in their kit (from memory) but we did this repair beside a gas station so they had an air compressor
    2020 Rally , Black
    May 2016
    For those that use a small compressor, you need to be careful that you don't burn up the wiring from wherever you draw your power. There is a mention by someone about carrying extra fuses. That's fine as long as the wiring is big enough to handle the amp draw for a prolonged time period, especially if the original fuse was replaced by a larger one to prevent it from blowing. But, if the wiring is too small for the amp draw and say a 5 amp fuse is replaced by a 10 amp fuse, well, that can be a recipe for disaster. A fuse protects the wire. It doesn't care diddly about what you are running on it. So, if BRP put a 5 amp fuse on a circuit, there's a very high probability that the wire is only heavy enough to handle 5 amps. So, if you put a 10 amp fuse in place of a 5 amp fuse that was originally there because you blow the fuse when you run your air compressor, just know that instead of the fuse blowing, the likely outcome will be a melted wire. Along with that comes a possibility of a fire. And definitely the need to replace the burnt wire(s) and the expense that will entail. So the best thing to do would be to run a separate wire with an inline fuse dedicated to your compressor that is the correct gauge to handle the amp draw of your compressor.
    2013 RT-S SE 5
    Feb 2020
    Violet, Louisiana
    Thanks for all the advice. I have a lot to consider.
    Dec 2008
    Jacumba, CA
    Best way to fix a flat is with a round head Phillips screw (3/4 inch), Phillips screw driver, an air pump and a can of Fix-a-Flat. Pull out the piercing object, screw the screw in the hole, use one can of Fix-a-Flat, air up tire and continue your journey. I did that on a new tire years ago on my motorcycle. The fix held up until tire was worn and ready to change.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
