Results 1 to 10 of 10
Thread: gas cap
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    Default gas cap
    Good evening. A while back I purchased a gas cap with the little door in it so you don't have to remove it to fuel up and the first time I used it the nozzle got caught in the hole and I had a hard time getting it to come out so I went back to the oem cap. Well this week I put it on my Chevy Trax and the next day my check engine light came on, I guess because the system works on a vacuum and it sensed something was wrong. When I removed it and put the oem cap back on the check engine light went off. Anyone else have this happen on their Spyder or car? Thanks, Mike
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Mar 2017
    Salisbury,NC
    2 bad outcomes = don't use it
    Default Gas cap
    Nope ..... Mike
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Gas caps are not generic. Use the correct one in the correct place.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Nov 2015
    Tinley Park, Il
    Got the idea here and used the on suggested
    Danbury Connecticut
    I know on my Ford, the fill connection had that design built in. There was no gas cap, the gas nozzle just goes right into a hole fitted with that type of valve.
    The upshot is, there isn't anything inherently wrong with that design.
    You most likely got a faulty cap.
    Just my opinion. I could be wrong.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Sep 2016
    Chillicothe, Oh.
    If for some reason the cap doesn't seal on the newer cars and trucks then you will get the check engine light. Pretty much an airtight system, another perk of the tightening emissions regulations. I was in the garage one afternoon and my truck that hadn't been driven for two days starts humming to me. Turns out it does a fuel system pressure self test on it's own from time to time. It was interesting to say the least. The little door on your new cap apparently doesn't satisfy the sealing requirement of the Chevy.
    2015 RT , Black
    Mar 2019
    NEBRASKA
    Gas caps can be finicky
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Nov 2015
    Tinley Park, Il
    maybe when the gas nozzle was stuck in it and I had to force it out it may have damaged the cap
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    My Corolla does that humming routine & it had me puzzled for while.
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
