Page 1 of 2 12 LastLast
Results 1 to 25 of 32
    Oct 2015
    Northern Michigan
    Default Rear Tire Question
    Wanted to get the Altimax RT43 to replace the Kendra rear tire on my RTS-SM6. But can't find it in the exact same size as original. I notice here on the forum some have deviated a bit in tire size from the original. Would altering size not cause computer, ABS etc. type problems? Thanks for any input!
    Stick
    P.S. Finally giving up on the Kendra tires. Two rears at 7500 miles each is quite enough!
    Jun 2010
    Las Vegas
    I run the 215/60R15 and have for years. No trouble with ABS or anything else.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Oct 2015
    Northern Michigan
    Thanks, Ann!
    Jan 2015
    southern WI
    Yup. 215/60/15 works great and gets your speedometer within 1/2 mph of actual. I had that tyre on my 2010 RT, and now on the 2016 RT. You'll love it!
    2021 RT Limited
    2016 RTS , Pearl White
    Active Member LifeLongRider's Avatar
    Aug 2018
    Florida
    Quote Originally Posted by Stick View Post
    I read this many times but don't really understand why. I'm just ready to turn 7200 miles on my Kenda rear and seriously, you can't see any wear on it. Still looks almost new. Admittedly I drive easy, ride solo, never two-up and keep 30psi cold in it, but still, how can you wear out a rear tire, even a Kenda, in 7500 miles? Beats me
    PS: don't slay the messenger . . . I'm telling you the truth . . . . I can post pics if necessary
    2019 F3 Limited
    2019 F3 Limited , Oxford Blue
    Oct 2015
    Northern Michigan
    Hi Rider - don't know what to tell ya. I too ride solo, easy riding senior, run about 28 lbs., and twice now I've gotten only 7500 miles per rear tire. A dealer told me that is exactly the mileage the manufacturer predicts for the Kendra. You're having better luck, to be sure, but I'm moving on. With Ann and Mazo's response above, I'm gonna give the Altimax a try. Thanks.
    Jan 2015
    southern WI
    Quote Originally Posted by LifeLongRider View Post
    You obviously got VERY lucky and got one of the rare good Kenda tires. Most people get about 8500 and have to replace. I got just under 8000 with both the Kendas I had and replaced with Generals....Ride on em til ya can't no more...LOL
    2021 RT Limited
    Apr 2019
    PA
    My Kendra was shot at 7200 on the dot. I rode very easy too. I replaced mine with 215/60R15 Altimax. Awesome tire!
    Aug 2018
    Florida
    Pics of my odo and rear tire - pic is a little deceiving, tire shows almost no wear. Also, I did a laser alignment just after delivery (yes, it was out of alignment from the factory). I keep the two fronts at 19psi cold and they also show almost no wear. Maybe the newer Kendas are lasting longer . . mine is a 2019.
    2019 F3 Limited
    Idaho
    Kenda, and BRP probably, have gone back and forth on the rubber compound used in them. Early tires got good mileage, then for several years the compound was softer and that's when the 7000+ mileage started showing up. I'm not sure when they changed back to a harder compound but the newer tires are generally getting mileage such as you have. We're waiting for some users to post their experiences with the new after market Kenda Kanine. It's possible that the same rubber is being used in both the OEM tires and the Kanines.
    2014 Copper RTS
    Idaho
    Yep, deviation is the case. Almost no one makes a car tire in the OEM Spyder size. Our choice has been the OEM Kenda or similar crappy tire in the OEM size, or a good car tire in a non-OEM size. Nanny can readily tolerate some variation in tire size, at least for sure within the range that will physically fit a Spyder. The larger diameter brings the speedometer reading closer to actual speed. If you really want to learn all about this, and get bleary eyed doing it, search car tires here on the forum. There are hundreds, if not thousands, of posting about all things car tire!
    2014 Copper RTS
    " some varition " ???? .... in reality there is no tire made that will fit an OEM spyder that will cause a Nanny issue - period ..... Mike
    SpyderLovers Sponsor merlot's Avatar
    May 2015
    Tasmania
    hi lifelong
    difficult to see in your pic but its looking pretty close to the wear bars
    the tyre wears the middle 2inches,and the outside looks meaty,fooling you into thinking it isnt worn
    tyre middle wears due to centrifugal ballooning,not inflation pressure(personal experience having tried various pressures)so its difficult to control
    you find out its worn,tho,when it rains and you aquaplane
    to be safe,best to have tyre inspected by tyre service centre
    stay safe
    russ
    this tyre has 5000kms or 3100miles
    you can just make out the increased wear towards the middle
    i will be refitting this tyre as it has another 3000 or so kms left in it
    pres ride
    2014 RT-S
    bike is WIP
    bike has endured elect spike (was jump started incorrectly)
    still a WIP but bike is now running and registered....swapped out 5 modules mostly sourced from Canadian wrecker
    Oct 2015
    Northern Michigan
    Thanks for the info, guys and gals. Much appreciated. Very helpful!
    Stick
    Dec 2013
    Quote Originally Posted by merlot View Post
    hi lifelong
    stay safe
    russ
    Altho when you look at Merlot's pic (above) be aware that the 'bar' you can see in the foreground is NOT a tread wear bar - the actual tread wear bars in that pic are just visible up near the top of the tire, showing that there is still a little wear left in that tire.... that said, I don't think there's as much as 3000 km or so left in it, especially not for our (approaching) winter, or Russ's winter down in the far South of Australia in the wild & wet areas of Tasmania where he habitually resides (& rydes!)
    So check those (proper) tread wear bars LifeLong, you might not have as much tire left as you think!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Sep 2016
    Chillicothe, Oh.
    No harm to the messenger. Where you ride and how you ride make a huge difference in tire wear. I got 6000 out of the original Kenda and I was surprised I got that many miles. Here in my riding territory the roads are crooked and I ride hard. Lots of G-forces, tire spin, and giggles. That is how you get less than 7500 miles from a Kenda. I went through my first Altimax in 20,000.
    2015 RT , Black
    Idaho
    W e l l l l l l l l l !! I did say "at least for sure within the range that will physically fit a Spyder."
    2014 Copper RTS
    Sep 2019
    Prague, Oklahoma
    Roads have a lot to do with it also. When I was in California and still riding Harley's I could only get about 7,000 miles on the stock Dunlop 402 and usually went to a different brand. Once I ,oved to Oklahoma and had to have new tires I was new to the area and the only place I could find was a Harley dealer and he put 402's on it and I got over 15,000 miles on them. The way I rode didn't change so all I could think was different was the roads. That being said I got a 2019 Spyder RT Limited in October and I have over 7,700 miles on it now with the original tire and it is still going strong, just waiting to go to the Dark Side.
    2019 RT Limited , Pearl White
    Vermont
    Quote Originally Posted by Mazo EMS2 View Post
    I got 5,824 miles on the OEM rear tire. It was a Kenda.
    Since then I went with the General.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Vermont
    When I bought my 2014 RTS-SE6 the end of July( which was brand new) I put on 5,824 miles on the Kenda rear tire. It was not safe to drive at the time, Mike(Blueknight911) even said it was not safe to drive. Also, he recommended to me the General Altimax RT 43 tire for the rear tire.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Central Oklahoma
    Kumho Ecsta AST KU25 All-Season Tire - 225/50R15 91H is what I have on my '14 RT-S SM6
    https://www.amazon.com/gp/product/B004QL6DWS
    2020 RT Limited , Petrol Metallic Dark
    May 2016
    Sun City West, AZ
    Who put the General on? The dealership here will not put anything on but what they sell
    Danbury Connecticut
    No one is questioning your veracity.
    Nevertheless, your experience is most unique.
    Almost all of us have gotten around 7K miles off the stock Kenda tires.
    Kenda has recently come out with new Kanine tires as a response to complaints about the longevity of their tires.
    There's not a lot of experience with these yet.
    I'm just speculating, perhaps you have a Kanine ??
    IBA #47122
    2020 RT Limited Asphalt Grey
    Apr 2019
    Clinton, MS
    My 2019 RT now has 7,000 + miles and the rear kenda looks great. I think what we have here is the rubber content has been hardened over what it was in the past. I'm almost disappointed because I am looking forward to going to the dark side with different tires.
    Jan 2015
    southern WI
    Quote Originally Posted by ISPYD View Post
    I just had the local tire guy install mine. I took the wheel off and took it to him, as most do.
    2021 RT Limited
