Results 1 to 11 of 11
Thread: Tire age
    Active Member Garf's Avatar
    Oct 2017
    Ortonville, Michigan
    Default Tire age
    Just received a Vredstein Quatrac 5 from Vulcan tire with a manufacture date code of 4216
    Should I be concerned with the age of this "new" tire?
    Also are there any mounting suggestions for this tire. It has a blue stripe around one edge of the tread.
    This is for the rear of my RTL 205/60R15
    Thanks to all. Hope you are well
    Gary
    2017 RTL Asphalt Gray Metalic
    1987 BMW K75s
    Aug 2019
    southwest oHIo
    That tire is already 3 1/2 years old. I would certainly contact them to see if they have a fresher one to offer.
    May 2017
    Mesa, Arid-Zone-A
    Generally, any tire 7 or more years old should be replaced. Your tire is halfway there. If you do any riding at all you will ware the tire out before is sees it's 7th birthday. I wouldn't worry about it..... Jim
    Semper Fi
    The blue stripe MAY have conveyed some info to someone/thing at some stage of the tire's life, but only while it was being made/in the factory!
    As far as you and anyone else is concerned now - well, actually, ever since that tire left the factory, probably all that it is there for now is making the tire look pretty!
    Same with any dots that aren't red or yellow - they're not useful or important once the tire is no longer in the factory, so you can just ignore them!
    Quote Originally Posted by Garf View Post
    go the Vredestein tire Co. website .... they will explain why there is ONE BLUE LINE ...... For a single rear wheel application it doesn't matter which side it is on, the Q-5 is " NON-directional " ...... Mike
    Quote Originally Posted by canamjhb View Post
    I'm pretty sure the 7 year thing is what the tire can still be legally sold untill ..... personally I wouldn't be concerned about a 3 1/2 year old tire that I planned to mount within 6 mos. ..... if they will get a younger one ( for free ) do that ...... otherwise I wouldn't get cranked up about it ..... jmho ..... Mike
    Oct 2017
    I've reached out to Vulcan tire (via e-mail) about this.
    I will let you know when or if they respond.
    Gary
    1987 BMW K75s
    Aug 2019
    Stoughton, WI
    I'm guessing that tire/size wasn't in high demand. My Vredestein Q5 165/60R15's from TireRack were 2219
    2022 RT Sea To Sky
    Oct 2017
    I had the same experience when I bought the fronts from Tire rack.
    Tires were about 4 months from Manufacture date.
    Unfortunately Tire Rack doesn't carry the Q5 in the rear tire size.
    Gary
    1987 BMW K75s
    Well quite a few folks here are using the Q-5 in 205/60 -15 and / or a 205/65-15 ...... remember your NANNY has quite of bit of control over what happens when traction is exceeded ..... Mike
    Oct 2017
    Couldn't agree more. And per your recommendation I did buy the Q-5 in a 205/60-15
    My only concern in the OP was the age of the tire I received (3 1/2 years old)
    I guess it's not that big of a deal but will wait for Vulcan tires response before I have it mounted.
    Thanks Mike and all
    Gary
    1987 BMW K75s
