Results 1 to 11 of 11
    Active Member amusher's Avatar
    Apr 2015
    11 Mile/Spinney CO
    Default Headlight Shutters
    Has anyone be able to fix a stuck down headlight shutter and how did you do it??
    Thanks...
    Aug 2013
    SF Bay Area
    You must've replaced the bulbs and got the wires inside the shutter. Need to get back into the back of the headlight and clear the cable.
    2021 F3 Ltd , Magna Red
    Quote Originally Posted by amusher View Post
    Thanks...
    If you replaced those headlights with ...LED's .... a common issue is the LED's have more wiring and it needs to be carefully STUFFED into the rear housing .... it's likely the harness is interfering with the shutter mechanism as stated by flamewinger ..... jmho .... Mike
    I agree with Mike and when switching from halogen to LED headlights I had to readjust the positioning of some of the LED wiring to clear the shutter movement mechanism on one light. If you stuff an old halogen bulb in the socket and operate the Hi/Low beam switch you can easily see where your LED wiring cannot go to allow the shutter mechanism to work properly.
    The above have it nailed. I had my dealer replace the OEM with LED's on the 2014. I ended up with one stuck shutter. When I took it back for them to fix...it was actually easy. They had overtightend the connections on the stuck one.
    Apr 2015
    11 Mile/Spinney CO
    Nope, it came with LEDs and its been fine for over the year and half I've had it. I just clicked to low beam one night and it didn't go back up to high.. Wouldn't it have had this problem shortly after installing the LEDs and not this much time later?
    Yes it would. IMO of course.
    Mar 2013
    Unless the wire moved over time. I ran all the wires outside of the light housing after I had this issue from the get go. There is room behind the lights for this.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Check for a broken wire. The hi beam power activates the solenoid to open the shutter. If power doesn't get to the solenoid then there is no high beam.
    Apr 2015
    11 Mile/Spinney CO
    Ok, guess I'll plan on taking it all apart and checking things out.. Thanks for all the input.. Ride safe..
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    I developed the stuck shutter syndrome almost a year after I installed LED lights. Took the problem housing apart, repositioned the wiring, tested it before putting all the trim back in place and it's been fine for close to two years since.
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
