Results 1 to 18 of 18
Thread: Speed bleeders
    Active Member ris's Avatar
    Jun 2016
    N.H.
    Default Speed bleeders
    I have a 2015 RTSE6 .
    I'm looking for the part numbers for speedbleeers for the front and rear. I called the company and was told they don't have a specific part for the Spyder. That I needed to remove and measure the original bleed screws on my bike and they could match them. Bike is still in winter storage.
    Thank you in advance.
    Feb 2012
    Spring City,Utah
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Mar 2015
    forrest above Reno, Nv
    I just ordered them for my . They sent the wrong size [ SD8125L ] and are now in the process of sending me the 6mm size. The gal there was flummoxed about this, but was happy to fix it right away.
    2014 RTS , Circuit Yellow
    Very Active Member Big Arm's Avatar
    Jul 2008
    Sioux City, Iowa and Tucson, AZ
    Mine are in the mail as we speak......hope their the right ones.....
    ....and we're gonna ride, we're gonna ride.....
    ride like the one-eyed Jack of Diamonds, with
    the devil close behind,.....we're gonna ride....
    2008 GS.....PE # 2888
    Feb 2019
    Portland, Oregon
    My bike took SB6 125.
    Oct 2015
    Lynden, WA
    Thumbs up
    OK. Just got off the phone with SpeedBleeders.
    They are exchanging my order of SB8 125L for SB6 125L.
    I hope the clutch bleeder is the same as the brake cylinder bleeders.
    Great customer service.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Jul 2008
    So........what's the correct size for the ABS system on the GS and ST ?
    Feb 2019
    Portland, Oregon
    I'm guessing it's 10 mm, cuz that's what SB sent to me.
    Active Member Garf's Avatar
    Oct 2017
    Ortonville, Michigan
    Quote Originally Posted by Lew L View Post
    This company is fantastic. I too got the wrong size (M8) back in December. Went to install them today and realized they wouldn't fit.
    One phone call and the correct size (M6) are on the way. They are even including return postage for the wrong ones.
    Apparently BRP changed the bleeder size from 8mm to 6mm in 2013 and Speed Bleeder was not aware of it.
    They even went so far as to order a stock BRP bleeder screw and measure it to verify the correct size.
    Gary
    2017 RTL Asphalt Gray Metalic
    1987 BMW K75s
    Mar 2019
    NEBRASKA
    The speed bleeder folks are awesome
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Feb 2019
    Portland, Oregon
    I ordered from Speed Bleeder by phone months ago and the same thing happened. They sent a set of 6 mm right away at no charge. I told them to take note that the 8 mm ones are too large. They said they would. I guess the left hand doesn't know what the right hand is doing at SB.
    Nov 2018
    Waynesboro, PA
    Spyders 2008 - 2012 are SB8125L-M8- 1.25 - 32.54 and 2013 to 2019 are SB6100-M6- 1.0 - 28.80. According to the chart.
    My Spyder
    2012 RTL , Brown
    Active Member MrMagicFingers's Avatar
    Apr 2020
    Dartmouth, Nova Scotia, Canada
    You're gona love the speed bleeders. They make a somewhat easy job a brainless event.
    I change my brake fluid every spring and it just takes minutes now to do it. It's effortless.
    Tim
    Current - 2010 Spyder RTS
    1) Experience is something you don't get until after you need it.
    2) A closed mouth gathers no foot.
    3) IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU HAVE TIME TO DO IT OVER??
    ___
    Horsepower is an illusory mathematical equation; Torque is REAL, and is the source of all good things in the world.
    The problem is not the problem. The problem is your attitude about the problem. Do you understand?
    Please check out my pics!!
    Feb 2019
    Portland, Oregon
    And you don't have to yell...Honey come here and press the brake pedal for me, but only when I tell you.
    Idaho
    Just ordered a set. Their applications chart has the right numbers on it now, SB6100 for the calipers and SB1010 for the ABS.
    2014 Copper RTS
    Feb 2019
    Portland, Oregon
    It sure took them a while to get it right.
    Idaho
    I should have said for 2013 on, except Ryker. They show SB8125 for Ryker and up to 2012.
    2014 Copper RTS
    Nov 2018
    Claremore, Ok.
    I ordered a set, but if I can find them I'll check which size I got. It was probably a year ago. I was going to replace the brake fluid soon during this lockdown.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
