Results 1 to 11 of 11
    Active Member scwingman's Avatar
    Dec 2019
    Fair Play, SC
    Default Wiring a Bushtec trailer to a Spyder RT???
    Anybody have a Bushtec trailer and have it wired into your Spyder please help.
    Spyder have 4 wire plug and Bushtec uses a 6 wire. Spyder has turn singles and brake lights in same wire and Bushtec has them separate.
    Is there a plug and play for this set up. Haven't been able to fine any.
    Thanks for any suggestion
    SCWingman
    Mar 2013
    Marion, Arkansas
    I'm not familiar with Bushtec trailers but I had a Aluma trailer that had 6 wires also. What you need to do is find the convertor somewhere in the tongue area or somewhere on the trailer. All the convertor does is change a 4 wire trailer to a six wire. Remove the convertor and then you have to buy a 4 wire plug to match your Spyder and then solder the wires to the 4 wire plug. But you have to know which wires are what and I think a call to Bushtec is required or maybe their wiring is online. Good luck.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Active Member Cruising RT's Avatar
    Dec 2014
    United States
    I have a 14 RTL & a bushtec trailer. I had a wiring harness made by one of Spyderlovers Sponsors, Electrical Connection listed on the home page. I'm not sure which Bushtec you have but mine is a Roadstar and the brake lights & turn signals are separate. According to Lewis at Electrical Connection, there is NO adapter to convert the six wire on the trailer to the 4 wire on the Spyder or vise versa. Unless things have changed in the last couple years, Lewis is the mastermind that builds & designs the wiring for the bushtecs. I recently bought a F3 and wanted to keep my trailer so I contacted Lewis about a adapter or wiring harness & never could get him to commit to assisting with wiring, so......I have recently put my RTL & Bushtec trailer up for sale and will but another trailer to pull with my F3
    Nov 2018
    Claremore, Ok.
    Find the wiring diagram of the trailer and the Spyder, pics of the trailer(inside, outside and underneath) and send it to me and I'll figure it out. You might have to rewire the whole trailer and install different lights.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Quote Originally Posted by scwingman View Post
    If you're handy and comfortable doing electrical work maybe what I did a few years ago will help. I made my own harness to go from the Spyder harness to a trailer 5 wire harness. I suspect the 6th wire you have is either for backup lights or for a cargo light. Either way you can live without it. On my setup I ran a 6th wire for battery power to my trailer. The wiring info you see in this thread includes extra harness to add a high mount light with flashing option. If you have any questions about what I did ask away.
    https://www.spyderlovers.com/forums/...-lights-Part-1
    Active Member fjray's Avatar
    Aug 2015
    central oregon
    When I wired my 15 RTL to my bushtec turbo 2 I bought a premade isolator from ebay. big bike parts I think and it was plug and play on the RT end and I wired it to the bushtec 6pin with no issues. One of the 6 wires on the trailer is the interior light and is ganged with the running lights. I believe it's the blue one. from there it's just a matter of finding each circuit with a test light and the white is ground. shouldn't be rocket science if I can do it. was basicly the same when I went back to the wing.
    I should have mentioned that the wiring on the Spyder is actually a 5 wire system. When BRP changed their trailer wiring scheme, i.e., went from separate turn/stop lights to common ones, they made a harness with an isolator/converter that takes the 5 wire on-bike wiring and converts it to the 4 wire pigtail for the trailer.
    Dec 2019
    Fair Play, SC
    I found Big Bike Parts has a wiring harness for the Can Am Spyder RT for a 5 wire hook up and it is plug and play. I have in on order and will see how that works.
    Thanks for all the advice and info.
    SCWingman
    Active Member NorthAlabamaSpyder's Avatar
    Jun 2017
    North Alabama
    Bushtec wires are, if this helps:
    * Green - Taillights
    * Blue - Brake
    * Yellow - Right Turn
    * Brown - Left Turn
    * White - Ground
    * Black - Interior Light
    2019 F3-T and some extra stuff
    The main difference between the BRP Y harness and the BBP harness is the BRP plugs into the harness under the seat and makes use of the power lead built into the harness. The BBP harness has you connect the power and ground wires to the battery.
    Sep 2016
    Clifton Springs, NY
    SCWingman
    I put this one on my RT. It is plug and play at the tail lights but you have to run power for the module directly to the battery.
    Wayne Bishop
    2015 RT-S Special Series
    2017 F3 Limited
