Results 26 to 50 of 55
  1. #26
    Dec 2015
    Oakley Utah
    Anyone use these from Wolo? I'm presently using the Wolo Bad Boy and the Bad Boy Max together and they are great except together they draw 30 amps or so and have been known to blow 20 amp fuses.
    These from Wolo draw 15 amps. https://wolo-mfg.com/horns/motorcycl...litter-mc.html
    Cheaper elsewhere. These are from Amazon (easy returns) https://www.amazon.com/Wolo-415-MC-A.../dp/B000GKEZGE
    2014 RTL Platinum
  2. #27
    That's what I have on my 2014 RTS. Here are a couple of pics when I put them on my 2013 RT. The horn mounting is exactly same on my 2014, but the compressor install was a lot easier because there is much more room under the lower tupperware than was on the 2013. They are about as loud as any you will find anywhere. Having them out in the open helps with the sound level also. I used a separate relay connected to the OEM horn circuit. I also left the OEM horn in place and connected. The instructions say to use an air tube no longer than about 8" but in my case the the tube to the right side horn is about 2' long. I have not noticed any detectable delay or lack of pressure due to the longer than specification air tube.
    Annnnnndddd, I think they are neat looking!! I don't know why more owners haven't used them. The only downside to using them like I did is you have two holes in the tupperware on each side. To overcome that when you sell the bike is leave the horns on!
  3. #28
    Jun 2021
    Dunsford Ontario
    The stock horn on mine is loud enough.
    2019 F3 Limited Pearl White
  4. #29
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I bought the dual horns from slingmods. They are loud.
    2021 RT Base - Petrol Blue
  5. #30
    Mar 2021
    Maryland
    I installed the Motohorn 2.0 that Lamonster sells. Saved my A$$ a couple of weeks ago on 95 near Savannah.
    Had a cage not paying attention and started drifting into my lane to come over without a signal, hit the horn for a 2 second blast.
    You could visibly see the guy jump about 6 inches off of his seat and just about went off into the shoulder from overcorrecting, Well worth the money for the horn and the plug and play kit that lamonster sells, it saves you the time and the trip to the hardware store to get what is needed to do the install.
    2020 F3 SE6
    2020 F3 , Black
  6. #31
    Springfield, MO
    Quote Originally Posted by CloverHillCrawler View Post
    You could visibly see the guy jump about 6 inches off of his seat and just about went off into the shoulder from overcorrecting, Well worth the money for the horn and the plug and play kit that lamonster sells, it saves you the time and the trip to the hardware store to get whats is needed to do the install.
    Love the Motohorn. Glad it did the job for you.
  7. #32
    Dec 2015
    Oakley Utah
    https://www.lamonstergarage.com/moto...torcycle-horn/
    2014 RTL Platinum
  8. #33
    Mar 2021
    Maryland
    Here is a pic of it (motohorn) from my recent trip to the dragon at Tabcat Bridge. Worked out great and went in fast with lamonsters kit.
    2020 F3 SE6
    2020 F3 , Black
  9. #34
    May 2019
    Mt. Juliet, TN
    Anyone have this horn: Super Loud 131 DB Air Horn with Safety Relay from Spyder Boyz?
    https://spyderboyz.com/product/super...-safety-relay/
    I ran across this and want to install on 2020 F3-T. If you have one, is it an easy, plug-n-play install?
    2020 Spyder F3-T
  10. #35
    May 2019
    Mt. Juliet, TN
    Default Louder Horn
    2020 Spyder F3-T
  11. #36
    Nov 2018
    Waynesboro, PA
    My Spyder
    2012 RTL , Brown
  12. #37
    Sebring, FL
    Slingmods have a new horn out, looks like an easy install, about $70, not air horns, but loud.
  13. #38
    Aug 2019
    Stoughton, WI
    I think I'm going to add a 2nd Lamonster Motohorn for the left side
    2022 RT Sea To Sky
  14. #39
    Feb 2022
    New Zealand
    Thinking on fitting an OHOOGA horn to my Spyder. Mounting it in the void behind the grill in my F3. The cavity may work as an amplifier.
    Got one on my Jimny and people look around if I use it. So I guess its effective.
  15. #40
    May 2019
    Mt. Juliet, TN
    Default Still Looking for Louder (than OEM) Horn
    I know this has been a much discussed topic, but here's my dilemma. Found a dual horn I like but the install involves cutting a panel to accommodate the fitment. Do not want to cut (any) panels.
    Question: has anyone installed an aftermarket horn in OEM horn space on a F3-T that did not require cutting for more space needed?
    ps. Not interested in an side mount, bugle type air horn.
    2020 Spyder F3-T
  16. #41
    May 2020
    Walker, LA
    Following
  17. #42
    Active Member MNBK's Avatar
    Mar 2017
    Circle Pines, MN
    I put the WOLO Bad Boy horn on and did not have to do any cutting. Much better than the stock horn.
    Dave....
    2016 Red/Black F3T w/ Audio
    Bajha Ron Swaybar, BRP driving lights
    F4 Windshield, Ultimate Tallboy Seat
    BRP Passenger Backrest
    Custom Dynamics fender lights
    Tricled Rear Bag lights w/ Flashing Brake Modulator
    Wolo Horn, Lamonster's Bungee Buttons
    Spyderpops Bumper Skid
  18. #43
    Aug 2022
    I have used these on my last several bikes. Much louder than stock, plug and play, mounts in stock location with stock wiring and no new relay required. Not the LOUDEST thing available but reasonably priced. They are 133 decibels. when using only one choose the LOW note. https://www.amazon.com/FIAMM-72112-F...00DINKPQ&psc=1
    IN GOD WE TRUST
    "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin,1759
    "The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first." - Thomas Jefferson
  19. #44
    May 2019
    Port St. Lucie, Florida
    I bought the train horn from LaMonster, with his install kit. Very easy, and man, is it ever loud! Love it!
    -Carsong
    2018 F3t
    2018 F3T , Position 5/ full size Matt Black
  20. #45
    Active Member GRHorst's Avatar
    Mar 2022
    PA
    Quote Originally Posted by Steve W. View Post
    Have not yet changed anything on a Spyder yet, but have upgraded the horns on more than one 2-wheeled motorcycle.
    Even the stock twin "beep-beep" horns weren't good enough, so I went to Auto Zone and got a couple horns. These were horns that look much like Motorcycledave's Cadillac horns, not the flat type. Be sure to get a "high" and a "low" horn, they are about $15 each. A relay will ensure they get full power.
    I have as set of horns to install. You suggested a relay? Is there inadequate power to operate a set of standard-type horns? Or are you suggesting that the Spyder horn wire needs to activate a relay that gets its power from a separate 12v source (e.g. accessory line or battery direct)?
    _________________________________
    GR Horst - Reading, Pennsylvania, U.S.A.
  21. #46
    Quote Originally Posted by GRHorst View Post
    The concern is the horn button contacts aren't rugged enough to handle the current of bigger horns. The wires may be marginal also.
  22. #47
    Central Oklahoma
    2020 RT Limited , Petrol Metallic Dark
  23. #48
    Mar 2022
    PA
    The dual horn set I had purchased claimed to be 300 dB. But anyone familiar with sound knows that claim is BS. But, regardless, it is plenty loud. I ordered a
    FARBIN Horn Wiring Harness Relay Kit off Amazon for about $10. It simply uses the standard horn wires to activate a relay that feeds the dual horns power through it's own fused line from the battery. I now have plenty of horn volume and the dual-horn systems adds an additional dimension to the sound. I believe the horns are 410 Hz and 510 Hz?
    The wiring was the easy part. Getting my hands and tools up into the horn area to remove the standard "road-runner" beep-beep horn and attach the new horns was the difficult part.
  24. #49
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by Spyder2014 View Post
    I am searching for a very LOUD horn for my F3 and RT Limited. I am wanting to mount a air horn with more than 150 decibels. In other words a big car horn or a train horn. Sounds funny but it would get people's attention.
    Anyone know of anything like this?
    Motohorn from LaMonster
    2019 F3L , Covid Blue
  25. #50
    No you don't. Remember, you'll be sitting quite close to the horn. At 140 db and above you risk blowing out your eardrums. Check out this table. https://www.gcaudio.com/tips-tricks/...parison-chart/
Tags for this Thread
