Results 1 to 25 of 48
    Nov 2019
    Kansas
    Default Using ramps for oil changes
    So if I decided to do my own oil changes, will just using two front ramps to move the front higher be good enough?
    Meaning it wont be level, will most of the oil still drain because the back wheel will be on the ground?
    Nov 2015
    Myerstown, Pennsylvania
    If you don't mind laying on the floor you don't need the ramps. I don't raise mine up and have no problems. Plus I'm in no hurry so I let it drain for an hour or 2.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Clinton, MS
    It will work. Place the ramps so you are backing up onto them then the sloped part will be out of the way. It may be too low if you are planning to use a creeper but works fine if laying on cardboard or the floor. Don't forget to stuff a rag or two around the drain holes to keep any oil from getting on top of the panels.
    Jul 2019
    UK
    I use ramps without any problem. All the oil appears to drain correctly.
    Rule#2: Never argue with an idiot. He'll drag you down to his level & then beat you with experience.
    Rule#1: Refer to rule #2.
    Active Member HankD's Avatar
    Jul 2017
    Huntsville Alabama
    Quote Originally Posted by PinkRosePetal View Post
    Ditto. I just did mine and it worked fine with the front wheels backed up onto ramps. I put a small scissor jack at a safe place I found closer to the rear just to level it out a few inches (not anywhere close to completely level), but I doubt it was necessary.
    One day I will tell the story of how I first tried to back up onto 3 ramps (the 3rd one behind the rear wheel).....but the outcome still makes me cringe
    Sebring, FL
    Often wondered if that would work, now I know, good thread.
    …. However if the surface the rear tire is on is smooth traction might be an issue..... also almost any type of jack cam be used to raise the rear tire / frame etc. so the Spyder is level ….. unless the engine is at least warm. the longer it drains the better …. ONLY put 4.5 qts. in and then check it after you can get it up to Temp ….. running it slightly low will have No ill effects and you won't over-fill it ….. Mike
    +3! Works very well.
    Florida Swamp
    Using a platform scissor jack under the rear to bring it up level. Plenty of room.
    2019 F3-S , Black & Silver
    Apr 2016
    St. Charles IL
    I use ramps underneath the front wheels and a cinder block underneath the rear. Levels it out nicely!
    Bill W
    2019 F3 LTD
    Feb 2012
    Spring City,Utah
    I back up two ramps for the front, then jack up the rear to level things out and put a 3rd ramp under the rear wheel to keep things safe. I am glad to see I am not the only one who tried to go up 3 ramps at once. Very bad memories.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Clinton, MS
    Just have to use a running start
    SoFlo
    Never been a fan of draining oil when the vehicle is not close to level.
    On the Spyder, I either just leave it low and one the floor, or have the jack out. Raise the Spyder and place it on blocks or two ramps front and block in the rear.
    For our Spyder, driving up automotive ramps does not work. The trailer hitch mudflap scrapes the ground and will get torn off.
    Just what I prefer, but as you can see, many long timers have been using ramps forever.
    Jun 2014
    Schenevus NY
    Add me to the list of people that tried to drive up ramps. Results were not pretty.
    Now I use a motorcycle lift to raise the whole thing up, put stands under the front wheels, then lower the bike down on the stands. Real easy.
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    Mar 2017
    This Harbor Freight jack has an extremely low insertion profile and raises it high enough to do most work. Can be had for $60 with coupon.
    https://www.harborfreight.com/automo...ack-64545.html
    Oct 2014
    Fort Mill, SC
    Driving up the ramps in reverse can be a little hairy. If you go too far it will be a disaster. I raise mine with a lift, then put three ramps under the tires, then lower the bike down and remove the lift. When I'm done I can just drive forward, off the ramps. Just make sure those ramps face backwards. Much safer way to do it.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    If you look at the position of the crankcase and clutch cover drain plugs you can see they are located on the back, rearward side of the engine and, in my experience with my Spyder on my level garage floor, the engine drains fully with just the front wheels on standard car ramps. The proof for me is when I add 5 qt of fresh oil and then check the level with all three wheels back on the floor it is right where it's supposed to be on the dipstick.
    Jul 2019
    UK
    Quote Originally Posted by Grandpot View Post
    ....Just make sure those ramps face backwards. Much safer way to do it.
    Erm, why is that the case?
    May 2018
    Chateauguay, Qc, Canada
    Where do you lift at the back?
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Oct 2014
    Fort Mill, SC
    If the ramps face forward, you would not be able to drive down the ramps. The rear wheel ramp will hit the bottom of the frame.
    1998 Honda Valkyrie
    US Navy Veteran
    Quote Originally Posted by Eckhard View Post
    I place a 6 inch wide piece of 2 X 4 on my Harbor freight floor jack under the rear shock …. the wood is wider than the metal pieces that the rear shock bolt goes thru to hold the shock ….. this allows the bolt to be removed so the shock can be detached from the frame ….. Mike
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    I use my old craftsman mc lift. I like that better than ramps and it lets me get under good to check every thing else out while I'm there. I have to use the lift anyway to put her away in front of my wife's car at a 90 degree angle.
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    "One day I will tell the story of how I first tried to back up onto 3 ramps (the 3rd one behind the rear wheel).....but the outcome still makes me cringe"
    Been there, Done that! The military could use these as weapons. Fire one!
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
    Dec 2015
    Oakley Utah
    that's what I do.
    2014 RTL Platinum
    +1 and MOST IMPORTANT! If one attempts to lift the rear of the frame by placing the jack on the lower shock eye it will bend the bolt and one will have a difficult time getting the bolt out.
