SpyderLovers Founder
I had the same problem with my Hindle. I kept tightening it down trying to get rid of the exhaust leak and slip joint ended up out of round. I used Permatex muffler sealer and so far it has been holding. No leaks. I checked it again today.
Lamonster show us some pics, when you cut the slots and install it. I didn't even think of that. It's probably a mod I would like to do on the Hindle.
HAPPY SPYDER OWNER
GULF COAST SPYDERRYDERS
Hindle
Originally Posted by Lamonster
I just got my used Hindle today and I can't believe what I'm seeing here.
There is no reason to have a clamp on a end that can't be clamped. This is crazy, this is a slip joint not a clamping joint. If you're going to clamp something you need slots so the metal can give as you tighten the clamp. I see now why folks are having leak problems.
There's nothing wrong with a slip if it's done right, my Yoshi is a slip joint with no clamps and it doesn't leak. The problem I see with this being a slip joint is the material is too thin to hold form and yet it's still not going to clamp right even if it is thin with no slots.
So mine is a little banged up from shipping so I'm going to remove the ironing board looking heat shield and repaint the pipe. At that time I'll cut slots in the 90 so it can be clamped to the y-pipe.
YouTube - Broadcast Yourself.
You may want to try it before you cut. I installed my Hindle, torqued everything to specs, and I have never had a leak. I check for leaks with a candle in a garage where there is no air movement . Never even had the slightest flicker. I have my wife rev it up to 2.5-3k while I check.
WE DON'T QUIT PLAYING BECAUSE WE GROW OLD; WE GROW OLD BECAUSE WE QUIT PLAYING
....and we're gonna ride, we're gonna ride.....
ride like the one-eyed Jack of Diamonds, with
the devil close behind,.....we're gonna ride....
2008 GS.....PE # 2888
Mod Maniac
That's a fairly recent change, Lamont.
Version 1 of the Hindle used a slip joint gasket and was slotted. Version 2 (I have this one setting in the garage) used no gasket but was still slotted. That appears to be a Version 3.
I'm wondering if Hindle just messed up and forgot to slice them.
ata = allergic to asphalt
My mods: https://www.spyderlovers.com/forums/...ead.php?t=5753
There are two kinds of people: (1) those who can read, reason and apply the experiences of others; and (2) those who just have to pee on the electric fence. ataDude, 2009
My Spyder:
agree, I have the first, it is slotted.
Alignment Specialist
Bone Crusher
If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
candle
Originally Posted by Big Arm
REALLY ?????? How far away from the gas tank do you hold the candle ?
FAR ENOUGH OBVIOUSLY.
I just did a quick check and my Hindle is quite noticeably leaking. Since my dealer did the install and I'm heading there on Friday for the steering update anyway, I'll give them a shot at fixing it first before I mess with it. If they fail to fix it, I'll probably end up following your advice.
Thanks for all your tinkering Lamont. I just finished up the breather mod following your instructions and hopefully cleaned out the oil in my airbox for the last time.
Hindle
My Hindle has the same joint that Lamont showed in the picture. It does not leak. Maybe this was the improvement.
My Hindle is the same style as Lamonts and it leaks. I've used ultra copper rtv and it works for a while. Instead of a temp rating they should put a rpm rating on the tube since I keep blowing it out.
I used the proper procedure as well...goop it...slip it on....let it cure.....then torque.
P.s. my pipe went out of round also. Also having a pipe I think spitting and barking is just what they do.
Max
Originally Posted by Capt John
After reading these post. I sent an email to BRP. Questioning the change in style from the 1st version, 2nd version and 3rd version of the Hindle. I also questioned them about the problems with loose rivets. Maybe I will hear back from them in a couple weeks.
More likely you won't...but let us know either way...
I'm less and less impressed with BRP every day...
Bone Crusher
SpyderLovers Sponsor
Incredible! Actually, 2 Incredibles!
The first Incredible is that this slip joint is designed to clamp with nowhere for the clamping force to go (except to oval out the pipe-Now you're got an Oval to Round connection -That's REALLY going to seal well!).
I would think there needs to be at least 3 slots to make that joint seal. How many slots do the slotted versions have?
The 2nd Incredible is that this is actually working on some bikes! Don't see how that could be. If this joint does start leaking, how does BRP expect a person to tighten it up?
Hindle
Maybe the clamp installed at the proper torque is intended to help keep the joint round and prevent it from going out of round.
I also have what I guess is considered the newer version Hindle, and yes, same sputtering and backfiring issues. My dealer cut slots in my pipe with my approval a while back and then did the rtv stuff. The 20 year master mechanic at the dealership pretty much had the same response Lamont had when he saw how these Hindles come in. The "fix" worked for 1 whole day, now back to the normal of what is does. My newest Hindle issue is the loose rivets. I keep hearing this metal sounding whine and finally realized it was the heat shield vibrating on the Hindle due to loose rivets.
Not sure the fix for that yet, but after looking at the heat shiled setup on the stock muffler my wife has, I think I can just tap some threads in the ports where the rivets are now and just put some kind of screws in there like the stock has...anyone?
My rivets loose on shield but rest of hindle solid...if you have a safe and easy solution, please post pics so we can address as well...thanks...
Bone Crusher
Mod Maniac
...I would think there needs to be at least 3 slots to make that joint seal. How many slots do the slotted versions have?...
Four.
My Spyder:
Update: 15 min breaking in. 30 min. to cool. Leak on the housing is the same.
I just talked to the dealer that sold it to me....they were very cool about it. They said they will contact BRP on Wed. and get it figured out.
If this is "normal", other than a few loose rivets, my old pipe is functional and I have virtually no need for the new one, other than cosmetic issues and annoying rattles. geeeze IDK...
"My old self has been crucified with Christ.It is no longer I who live, but Christ lives in me. So I live in this earthly body by trusting in the Son of God, who loved me and gave himself for me."
Mod Maniac
Are you sure it's not the drain hole used to get rid of condensation? It's about at that same spot you identified but underneath. You will, in fact, get a small leak there... intentionally.
My Spyder:
