Results 1 to 13 of 13
    Nov 2019
    Kansas
    Default So 3 new kenda Kanines on my F3-T
    So I had all new tires put on. First off, the new Kanine's look great and my bike rolls down the highway in a nice smooth fashion.
    However, I have am issue
    If I put the bike in Neutral with the engine off, and go backwards, I hear an odd sound from the rear end. Almost like a squeaky door hinge. Didn't do this before the tire was changed out.
    So I guess I will bring it back to the dealership saturday and have them look at it.
    Quote Originally Posted by acdcking12 View Post
    So I had all new tires put on. First off, the new Canine's look great and my bike rolls down the highway in a nice smooth fashion.
    The squeaking issue ...when in Reverse … is actually very common , and started back in 08 ….. It has nothing to do with the tires …. Mike ……… PS that tire is actually spelled ….Kanine
    Nov 2019
    Kansas
    So is it harmful?
    So is it harmful?
    Had both 08 and 09. Both had squeeks when backing up. Over 40K miles. Neither bike blew up or self destructed. I am thinking you are okay.
    Oct 2016
    Sebring, FL
    Could it be the belt? Guess not, it would squeek going forward....
    Jun 2018
    Pa.
    Are dealers now offering these new and updated Kenda's for installation?
    Nov 2019
    Kansas
    Quote Originally Posted by JimH View Post
    I had to buy mine separately and bring them in. My dealer had them on order, but haven't received them yet. My bike was the first that they put them on.
    Active Member HankD's Avatar
    Jul 2017
    Huntsville Alabama
    What inflation pressures did they use? Just curious. I'm getting my rear Kanine put on as soon as I get a break in the weather.
    Sep 2016
    Chillicothe, Oh.
    I have had a light squeaking noise when rolling my RT and it was the belt. Clearances and tension were fine, turns out it was making the noise when the rubber teeth were meshing with the metal pulley. Another scenario is that the brake pads could be lightly touching the disc after the tire/wheel installation. Not an issue and may well go away.
    2015 RT , Black
    Bay of Plenty New Zealand
    Composite belts do NOT squeak and they do not have rubber teeth.
    The squeak did start back in 2008 that is correct and it was the rear brake pads but as the F3 series has different type of pad it does not happen very much, if you are so worried about it just get a can of anti squeak brake spray.
    Sep 2016
    Chillicothe, Oh.
    Quote Originally Posted by Bruce B View Post
    You need to come and have a conversation with my RT. I know what I heard and upon investigating I found where it was coming from. 50 years of wrenching for fun and for profit. I know how to find a noise.
    2015 RT , Black
    Mar 2017
    Belt alignment? Dressing?
    Nov 2019
    Kansas
    I took it to the dealer to look at it, and they re adjusted the belt protector. I guess it was rubbing against the tire.
    All re adjusted and all is quiet again.
